View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.88%
2017 57 33.93%
2018 77 45.83%
2019 4 2.38%
2020 4 2.38%
2021 1 0.60%
Voters: 168. You may not vote on this poll
Old 09-08-2021, 06:10 PM   #841
Rnovrit
Drives: 2018 NFG ZL1-1LE
The stress finally got to me. LOL! Ordered a Katech pump to replace my pump. Car has 2400 miles on it with a build date of 12/17. Engine and pump are still running perfect. Figured I would take care of this at my leisure rather than have a pump fail and possibly damage the motor. A longtime friend of mine that I can totally trust, who owns and runs a race shop will be doing the swap once all parts arrive. I thought about doing it myself but would rather have a pro involved. This might be a total waste or it might be a genius decision. The piece of mind for me is beyond worth it and I don't trust the dealer to treat the car the same as my close friend or I would. I understand it is under warranty for a while and it will be covered if the pump fails in that time period. Problem then is the question of did debris get into the motor? Is there going to be other issues do to the pump failure and low oil pressure? You just know it will fail at the most inopportune time as well. I figure if I change the pump now with a much stronger unit, this (in my mind) practically eliminates the possibility of the failure occurring. It also ensures my engine sees no related future issues and the car sees no chance of abuse or accidental damage from the dealer.
Rnovrit is offline   Reply With Quote
Old 09-09-2021, 09:54 AM   #842
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
If I owned a 2017 /2018 LT4, I’d feel exactly the same way. So, I couldn’t agree any more, with all of your points. Clearly a genius decision
I especially like the fact your friend is doing the work, that’s key.
Old 09-09-2021, 02:25 PM   #843
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
My car was produced only 4 weeks before the 19's went into production. I seriously doubt the those cars have a different pump. When did the pump change? Or did it?
pauly1119 is offline   Reply With Quote
Old 09-09-2021, 07:58 PM   #844
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Katech says there have been 6 upgrades to the pump, but none of them fixed the root problem (stated in my previous post above)
I know Katech has a vested interest in selling oil pumps, but I'm not sure why they would lie about this - if it's all true, my opinion of GM took another hit
ZX-10R is offline   Reply With Quote
Old 09-09-2021, 08:36 PM   #845
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Well they've done something as there's been no reported failures that i know of on 19+ that would raise any flags.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 09-09-2021, 08:43 PM   #846
Chutzpah
Chutzpah's Avatar
I’m sorry, I don’t have good / solid answer for you. And that’s the problem in a nutshell. There’s been a ton a pump revisions, opinions from people here and a competing pump vendor making unverifiable claims. I don’t disagree with the timing of your build / perhaps having the latest revision pump. I’m not certain anyone here really knows, and that sucks. We all have a lot invested in our cars…
Old 09-09-2021, 09:06 PM   #847
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I agree with that, I still have a little over 3 years with bumper to bumper protection but like you said who knows. Most of the failures seem to be 2017 builds which would still be 2018 cars and early 2018 builds for the most part but is that just because of the miles on older cars?
Old 09-09-2021, 09:19 PM   #848
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Doubt it, so many were failing with very low miles. Its almost 2022.
Old 09-22-2021, 10:36 AM   #849
Rnovrit
Just a quick update. Katech has their pumps back in stock. I received mine yesterday. The pump looks very well designed and put together from what I could see without taking it apart. No date set yet for the actual swap.
Old 09-22-2021, 07:29 PM   #850
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
So now that i have verified the oil pump was replaced in March 2021, is there something i should be on the lookout? I've only put about 1k miles on the car. I would also assume they did an oil change and a coolant flush when they did the oil pump replacement?
Sent from my moto g(7) power using Tapatalk
Old 09-24-2021, 09:58 PM   #851
ZX-10R
ZX-10R's Avatar
I know this is the dry sump pump, but discusses some of the upgrades with the Katech
Old 10-13-2021, 06:15 PM   #852
JFWJR179
JFWJR179's Avatar
Drives: 2022 Camaro ZL1 Convertible A10
Has there been any failures/problems with Katech's LT4 wet sump oil pump ?
https://store.nexternal.com/katech/g...pump-p918.aspx
Sorry if this question has been answered previously.
JFWJR179 is offline   Reply With Quote
Old 10-13-2021, 06:41 PM   #853
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
The Katech pump just recently came to market so I lightly doubt there has been any failures.
Old 10-29-2021, 11:04 AM   #854
Camaro18&67
Drives: 2018 Chevrolet Camaro ZL1
new member, first post and what a post to respond too.
Count me as part of the group with a destroyed oil pump at 13K miles.
No problems whatsoever, brought in for an oil change and after the oil change the oil pressure was non existent......So for a week they tested and tested and finally determined the oil pump wasn't working.
Pull the engine and what do you know, the words they used was the "oil pump was destroyed in pieces."
2018 Camaro ZL1
Build Date 5/1/2018
Camaro18&67 is offline   Reply With Quote
