#8457 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
DO NOT TRY TO TAKE AMMO THROUGH THE TSA CHECKPOINT. IT MUST BE IN CHECKED LUGGAGE.
Also, print out that airline's rules about firearms and ammo and take with you. The employees might not be in the know but you'll be able to show them. Here is what the TSA says: Ammunition Ammunition is prohibited in carry-on baggage, but may be transported in checked baggage. Firearm magazines and ammunition clips, whether loaded or empty, must be securely boxed or included within a hard-sided case containing an unloaded firearm. Read the requirements governing the transport of ammunition in checked baggage as defined by 49 CFR 175.10 (a)(8). Small arms ammunition, including ammunition not exceeding .75 caliber and shotgun shells of any gauge, may be carried in the same hard-sided case as the firearm. 49 CFR 175.10 (a)(8). (8) Small arms ammunition for personal use carried by a crewmember or passenger in checked baggage only, if securely packed in boxes or other packagings specifically designed to carry small amounts of ammunition. Ammunition clips and magazines must also be securely boxed. This paragraph does not apply to persons traveling under the provisions of 49 CFR 1544.219. Basically, leave it in the box you bought it in or get a different factory ammo box. |
#8458 | |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
#8459 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
#8460 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
#8461 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS/RS M6 Commemorative Join Date: Apr 2014
Not sure if Springfield is releasing a new rifle "Night of the Saint" or if I am just missing the clue?
But there are some hotties in the video ![]() https://www.defendyourlegacy.com/NOT..._hsmi=44862972 Last edited by Tenring; 03-14-2017 at 12:54 PM. |
#8462 |
They did release a new gun. They got into the AR market and this is their marketing to get the name out. It is a competition to see who wins.
The hype leading up to them releasing the new gun was marketed well. The day they released it was going to be an AR I was bummed and disappointed I played into the hype. Every one has AR's. Wanted to see something new like the Fostech Origin. Maybe a new style or something other than we are getting into AR's I guess. |
#8463 |
Yes - I remember the hype and new Saint AR.....was not sure if this was a different one. Just marketing, got it.
#8464 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
So... I bought some .50 bmg AP reloads from a local dude. Figured I'd be okay since he's local. Sat on the ammo for awhile, finally shot a round. It hanged a bit in the chamber while loading, but not too bad. Fired the round and there was no sign of impact anywhere! The rifle was sighted in with LC M33 ammo, was shooting well under 2moa at 200 yds easy, so I should have at least seen an impact in the dirt back stop!
Afterwards the bolt was frozen closed. I used a lead hammer to get it unlocked, but the bolt handle has a shear pin for these circumstances to keep from wrecking the bolt handle. I lubed the bolt and barrel with penetrating oil, and tapped the bolt open through the barrel with a 3/8" steel rod, it dropped back surprisingly easy compared to the pressure I put on the bolt. All this happened about a year ago. Just recently I opened a can of the ammo to mic it and the sweet smell was really strong! (I don't think the dude resized the brass, and used old powder.) I know old powder can create higher pressures and dangerous rounds, does anyone know why the rounds were way off the paper? I'm talking WAY off! That round was fired within 75 yds with a sighted rifle. The back stop is a 5 ft high pond dam, if it shot low it would hit water, if it shot high it would have shook the tree branches. Nope. I don't have neighbors within a mile in that direction, but since the .50 is still a wrecking ball at 5,000 ft. it spooked me.....
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#8465 |
Wow, I never trust anyone's reloads........... had not heard powder could create high pressures with age.
#8466 | |
The problem with .50 is it takes the big press and I don't shoot it enough to justify that purchase. I've heard older powder not stored properly puts off a strong odor and can give higher pressures. If that isn't true I'll feel much better and can check that off the list of reasons why that round didn't fly straight..
#8467 |
![]() Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
To me I detect an ammonia smell when I open a can of bad powder. It will also have a rusty, red dustiness to it. And have seen the inside of metal cans corroded as well. I have never heard of bad powder exhibiting higher pressures with a safe/proper charge.
Wonder if You couldn't just find someone to pull the ammo down, toss the powder, resize, recharge and reseat the original bullets? Someone maybe on one of the fifty cal forums? I'm not set up for fifty, or I'd help You out. Largest rd I load is the .416 Rigby. |
#8468 | |
Even though, my last buy I picked up some 2016 fresh LC M33 for $320 per 100 shipped.
#8469 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Gun powder does deteriorate in the can and even in the casing, which is why we don't shoot a round that's been sitting around for 10-15 years. When gun powder deteriorates, the flash point becomes lower making it unstable and will create very high pressure when used.
The "sweet" smell you described is a 100% sure sign the powder is old and beyond it's usage. When gunpowder first begins to deteriorate it will give off an ammonia smell, at this point some say it can still be used if used at lower charges but it's best to throw it out. If left untouched and allowed to further deteriorate, gunpowder will then start giving off a sweet smell. At this point it is 100% not safe to use and is best to be used as fertilizer. |
#8470 | |
During firing, it was like a magic trick, the bullet just disappeared! Checked for squib, nope, barrel clear. After firing, the bolt is bound up. I've never had an excessive pressure problem before, but some say that's a sign. BUT, the primer appeared normal and the brass wasn't distorted. .... I dunno
| Tags |
| camaro gun |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Firearms section? | monstertodd | Site Related Announcements / Suggestions / Feedback / Questions | 23 | 06-10-2010 08:32 PM |
| Removing Swirl Marks using a Flex and Meguiars M105/M205 | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 05-22-2010 10:36 PM |
| The COPO of Today | The_Blur | 5th Gen Camaro SS LS LT General Discussions | 48 | 01-31-2010 07:00 PM |
| Laws Protecting Consumers for Aftermarket Parts | strauchpete | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 01-17-2010 08:31 AM |
| IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
