View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.88%
2017 57 33.93%
2018 77 45.83%
2019 4 2.38%
2020 4 2.38%
2021 1 0.60%
Voters: 168. You may not vote on this poll
Old 09-04-2021, 03:04 AM   #827
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Originally Posted by MakCamaro View Post
Yes but how come this info didn't show up on Carfax? I'd like to know as I imported my Z from the US and the Carfax was clean.
This is also my question as stated in my post... I wonder if this is why the old owner got rid of the car. If I recall, the repair date for the oil pump was close or similar when the car went back to the market for sale.
Sent from my moto g(7) power using Tapatalk
Old 09-04-2021, 05:41 AM   #828
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Not unusual. When I bought my 2019 ZL1 -6300 miles- in April of this year it had an oil change but nothing showed other than a sticker on windshield and 100% on OLM and wore out tires.
Old 09-04-2021, 05:45 AM   #829
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Damn... At least you don't have to worry about an oil pump failure anymore
Old 09-04-2021, 01:45 PM   #830
Wuiquen
Wuiquen's Avatar
Well this is more understandable. Anyone can change the oil, write on the sticker and reset the OLM.
But if GM did the repairs are part of warranty, i would expect that to be included. Shady business most people that don't know about this issue probably will steer clear of a car that shows oil pump replacement, maybe that's why they didn't report it?
Old 09-04-2021, 03:19 PM   #831
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Yeah the Oil Change was at a dealer in Tampa.....where I bought it.
I don't even know ithe ELSD fluid was changed.
Old 09-05-2021, 05:37 AM   #832
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Well apparently my car already had the oil pump replaced at 10,100 miles. 2018 ZL1 Build date 8/17
I guess i don't have to worry about it anymore
How can that not show up on the carfax of the car?
Does anyone here work at a GM dealer? If so, please let me know if you would be willing to assist me in getting a repair history from GM. My dealer did not want me to keep a copy of it. I was able to read it and that's how I see that the oil pump was replaced.
See if you can take a picture of the paperwork with your phone. Convert that to a pdf and then you’ll have some documentation. BTW, you can always request from any Chevrolet dealer a copy of any/all warranty work done for your car. I’ve always asked for an updated copy any time I have service done, including an oil change.
george is offline   Reply With Quote
Old 09-05-2021, 02:43 PM   #833
el_d3sconocido
Drives: 2018 ZLE
Went the Katech route just for piece of mind. I spend most of my time on track with this car so to have a failure happen there is not ideal for me. Also strengthened the heads while I was at it plus I removed the VVT and installed the DOD.
el_d3sconocido is offline   Reply With Quote
Old 09-05-2021, 05:50 PM   #834
SirArioch
Drives: 2017 Camaro ZL1
Add another to the oil pump failure. Went to zero at idle, but still had good pressure over 2,000+RPM, drove the last 5 miles home fine, just keeping RPMs up. Replaced the oil pressure sensor and still have the same problem. Going to call and have it taken to the shop on Tuesday (Monday is Labor Day). Good thing it should still be under warranty. Build 05/2017, only 22,900 miles, had it since zero miles and also serviced at the same dealer.
SirArioch is offline   Reply With Quote
Old 09-05-2021, 06:47 PM   #835
Snowwolfe
Drives: CTV5 V Blackwing on order
Because a Carfax report is not worth the paper it is printed on.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 09-07-2021, 11:06 AM   #836
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Talked to Dan at Katech. He says the eccentric "slider"/gear portion of the pump that results in variable pressure is manufactured of low carbon steel and prone to cracking - he says this part is unchanged 19+, so he expects failures will continue. This part is manufactured of billet in their upgraded pump
He also told me their upgraded pumps are produced in batches and currently on backorder. He recommends that the engine be removed to replace the pump so it's probably ~$2k in labor
Class action against GM coming?
1:30 in
ZX-10R is offline   Reply With Quote
Old 09-07-2021, 01:00 PM   #837
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
1:30 in
Thanks for the info.
I won’t be concerned until I see more than a few 19+ LT4’s have issues.
Old 09-07-2021, 11:56 PM   #838
Wuiquen
Wuiquen's Avatar
Does the replacement of the oil pump extends my bumper to bumper warranty on the engine/powertrain?
Clearly there was a failure inside the engine. Isn't there the potential for other things to break as the result of that failure?
Old 09-08-2021, 10:37 AM   #839
Nope. As far as I know, flaws do not extend the warranty coverage period, all the warranty covers is their resolution, parts and labor. An extension may be granted at GM's discretion, but it isn't automatic.
Old 09-08-2021, 05:16 PM   #840
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
Correct, only the replacement part gets covered from most manufacturers. So a oil pump replacement would get a 12 month or 12k warranty if the factory warranty was about to go out.
Revalot is offline   Reply With Quote
