Old 08-16-2016, 08:32 AM   #827
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Is Pobst's best time in the C7 Z51 still 1:38.2?
To my knowledge yes. I believe it was when he lapped it in a 3 way head to head against the 911 and F12. I'm almost certain that the 1LE is ahead of the Z51 due to the wider stickier tires that its running. I'm sure the e-diff and ptm is incrementally improved as well since its the latest version.
Old 08-16-2016, 09:01 AM   #828
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Are there GT350 (non R) times for Pobst at Laguna? I thought there was, but Google is failing me.
EDIT: Seems at the Best Drivers Car testing Pobst ran a 1:38.3 in the C7 Z51...so maybe a 1:38.2 or 1:38.1 for the SS 1LE?
Old 08-16-2016, 09:12 AM   #829
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Humm, I don't know...that would possibly put the SS 1LE in the high 1:37's...that is what the Z/28 ran if I recall...
Correct the Z/28 ran a 1:37.82
No GT350 times to my knowledge. Only a GT350R in the comparison with the Z/28 on another track. We'll see what the GT350R does this year as its also in the competition. I do not know its lap time.
Old 09-12-2016, 09:55 PM   #830
dw760
Drives: C3
Yes I know the numbers and I know this as fact. I would supply the numbers but I don't want to be rude since I told the guy who told me that I wouldn't mention it. It will become public knowledge as soon as the Motor Trend Best Drivers Car comes out in October.
It this the normal Motor Trend Oct issue coming out on the news stand now, or a special once a year issue ?
Thanks Dale
dw760 is offline   Reply With Quote
Old 09-26-2016, 10:43 AM   #831
dw760
Drives: C3
MT Results
4th place overall, pretty awesome for $45K . Wish it had lower gears or closer ratios in the trans though. Maybe I will have to do a rear end update some day.
Looks like the car can be ordered sometime in Oct.
Cheers
Old 10-14-2016, 11:57 AM   #832
dw760
Drives: C3
Hi Mjk
I have the identical Summit White SS1LE on order as of a week ago. I'm at 3000 as of Oct 11th. Hopefully they don't get stalled with any back ordered parts like my C7 Z51 did.
Cheers........ Dale in Yerington NV
Old 10-15-2016, 05:27 PM   #833
chrisvr6
Drives: suzuki
Old 11-07-2016, 10:18 AM   #834
chrisvr6
Drives: suzuki
http://www.autoblog.com/2016/11/07/2...#slide-4261272
Old 11-09-2016, 08:00 PM   #835
Richie Carbone
Richie Carbone's Avatar
Drives: My work van for now
Looks like the paint on these calipers won't hold up under extreme temps.
Richie Carbone is offline   Reply With Quote
Old 11-09-2016, 10:16 PM   #836
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Looks pretty typical to me!
A little bit of discoloration, maybe some texture....it means you're doing it right!
Old 11-09-2016, 10:49 PM   #837
Master357
Master357's Avatar
Drives: 2017 1LE
In the CTS-V world, the guys that road race consider it a badge of honor that their factory Silver Brembos are now Burnt Bronze Brembos.
Master357 is offline   Reply With Quote
Old 11-10-2016, 06:14 AM   #838
6spdhyperblue
Drives: 2SS 1LE
Is it just me or is the paint messed up right next to the bleeder screw?
Brake fluid melts paint...they probably change the fluid out a lot on that car
Old 11-10-2016, 06:39 AM   #839
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
If it's even just an occasional track car, bleeding at least the dirty fluid out should be part of the preparation for each event. Plus, I've heard/read where sometimes tiny amounts of fluid can weep out when everything down there gets really hot. Not something you'd expect from a purely street driving basis.
Norm
Old 11-10-2016, 11:31 AM   #840
cdb95z28
cdb95z28's Avatar
There will be fluid still residing within the bleeder after you close it. You must remove that fluid, either by blowing it out with Brakleen or sucking it out. If you do not remove it it will cause troubles in the future by corroding the bleeder making it difficult to remove, even to the point of breaking the bleeder. There will also be fluid within the threads, Brakleem helps here also. I believe this is what you are seeing in the above picture.
"KEEP THE FAITH"-Fbodfather
2016 camaro, 2016 camaro 1le, 2017 camaro, 2017 camaro 1le, 6th gen camaro 1le, camaro 1le, camaro 1le 6th gen, camaro forum, camaro forums
