Old 08-26-2025, 07:16 PM   #71
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Originally Posted by 65ffr View Post
Well if you mod a GTD and it beats the ZR1X, one can then mod the ZR1X to beat the GTD again, and probably still stay way under the GTD's sticker price.
Edit: a driver mod would probably be all that's required
It would also seem easier to turn up the boost on twin turbos vs a supercharger. The car would most likely put the extra power down better because of the mid engine layout.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Evansa22 is offline
Old 08-26-2025, 09:36 PM   #72
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. Twin 76mm turbos have a good bit more upside than a 2650 blower. And also agree on the mid engine layout traction advantage.
Joshinator99 is offline
Old 08-27-2025, 10:27 AM   #73
MisterMarauder
MisterMarauder's Avatar
Drives: 2023 Radiant Red ZL1
Negative. The list has times for both lengths and the AMG is still faster than both the ZR1X and GTD despite the significant power handicap.
https://en.wikipedia.org/wiki/List_o...eife_lap_times
The AMG GT Black series completed the 12.944 length in 6:48.047 with a professional driver.
The ZR1X completed the same length in 6.49.275 with an experienced production engineer.
I assure you, that if Maro Engel were driving the ZR1X, it would be faster than the AMG.
Current
1992 Z28
Previous
2018 2SS Redline Edition
1992 RS
MisterMarauder is offline
Old 08-27-2025, 12:57 PM   #74
Joshinator99
Moderator
And if the AMG had 520 more horsepower it would again be faster, correct? See what happens when you play make believe?
Old 08-27-2025, 01:48 PM   #75
MisterMarauder
So? What a straw man argument.
The AMG GT Black Series has the power that it has, just like the ZR1/ZR1X.
If the same driver for both (Maro Engel, the one who set the record with the AMG GT) put down a lap, the ZR1X would be faster.
Current
1992 Z28
Previous
1992 RS
Old 08-27-2025, 03:16 PM   #76
Joshinator99
Moderator
Straw man? You’re literally playing make believe with a driver that didn’t drive the car. When your driver finally posts the faster lap time (with 520 more horsepower) then you’ll be right. Until then, that’s why we have the leaderboard with real world times that actually happened.
Old 08-27-2025, 05:03 PM   #77
Cardiak
Drives: Boat
Yeah, you can give it more power but it's still limited by it's mechanical grip and the GTD has more of that than the ZR1..which is the point I've been making.
Cardiak is offline
Old 08-27-2025, 05:19 PM   #78
MisterMarauder
I'm playing make believe that there's some common sense in this forum.
Current
1992 Z28
Previous
1992 RS
Old 08-27-2025, 05:39 PM   #79
Joshinator99
Moderator
When you have the facts, pound the facts. When you don’t have the facts, pound the table.” <—- You are here.
Insulting fellow board members isn’t going to help. I see you don’t post often. If that’s all you’re able to come up with, maybe that’s for the best.
