#71 | |
![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
#72 | |
![]() Drives: SS 1LE Join Date: Sep 2022
That said they helped me with missing parts over nighting what i needed multiple times to get me fully setup. Also they know answers to a lot of the technical questions i have vs most shops. The spline issue i felt was really minor granted surprising from mcs. Also had a knob on a canister disconnect and require reinstall out of the box. But the ride makes it all more then worth it so far.
2017-SS-1LE M6 416CI+MCS
#73 |
Had my first track day after installing the MCS 2 way coilovers, SPL front and rear endlinks, tension rods, and rear upper arm. This was at Autobahn Country Club full, my first time there.
I started at 8 compression and 9 rebound all around. The first lap out, I had a general lack of grip. I had extreme tire skip under braking as the slicks warmed up, significantly more than mag ride. Any amount of trail braking, the rear would step out. Even after fully warming the slicks up, I could not stomp on the brake pedal without the tires skipping. Brought down compression to 6 all around. Car felt much better under braking, but the butt puckering feeling on high speed sweepers was still there. Car also still felt floaty on quick left to right transitions. The rear didn't step out on trail braking as bad. Increased compression to 7 and rebound to 10. Car felt much better, and my lap time shortened by 6 seconds. Much less butt puckering feeling on high speed sweepers, and didn't feel as unsettled on quick transitions. Tire skipping on heaving braking compression on 7, but went away after the slicks warmed up fully. Trail braking was also a bit more compliant. I was pretty happy with how it felt at the end of the day. I will need to start reading more advanced literature on suspension setups to tweak further. It is definitely like learning how to drive a new car. I will approaching 1.2 G's very quickly on the new setup, and I won't get thrown around in my seat like mag ride. How much I was moving in my seat was more or less my tell for determining limit since slicks don't squeal unless it's fresh pavement. Interestingly, the outsides of my tires were shredded. This is the opposite of mag ride, my insides wore much faster. I am nearly down to the wear dot, and this was only their 2nd day. Normally I will get 3-4 days of a pair. Overall I am much more happy with how the car handles. I have Road America coming up in a month, and I will be able to directly compare lap times, although it's a much less corner heavy track so gains may be limited.
#74 |
![]() Drives: '22 2SS 1LE Join Date: Nov 2023
#75 |
-3.1 F, -2.1 R camber. 7.6 degrees of caster. 0 toe front, 1/32" total toe out rear. I am on the GTS package; 700 #/in Front / 800 #/in Rear
#76 |
#77 | |
When I called Vorshlag, they recommended the GTS if the car was track only with factory, which mine basically is. It's possible the SPL front tension rod's anti dive spacers is making everything stiffer, so the settings needed to go down a bit. The GTR package is for a big wang and a splitter. I wanted to try compression at 6 and rebound at 11, but I ran out of sessions, and I was thinking I may introduce jacking down with that big of a spread. The curbs at autobahn are pretty rough, but I can straddle curbs at Road America much better.
#78 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
#79 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
On OEM roll bars? One of the first mods I did was a Hotchkis ft bar set in the middle position. It made a huge difference, kept the rear end behind the front, allowed for much more aggressive trail braking and the rear end didn't tend to step out and hit cones as much in autox. I think GM made the car a bit loose from the factory, now my car feels much closer to the GT4R car in sim, which can brake really hard into the apex. I also put in a ZLE rear bar, I've tried soft and medium positions and would like it halfway between the two, but feel like the middle setting is better balanced overall. I think the ZLE bar in the middle is pretty close to the OEM FE4 bar though. On my shocks, I'm at 12 clicks front and 9 clicks rear from full soft, both comp and rebound for track. I use less for autox but it depends on the venue. And my alignment is 4 deg ft, 2.5 rear camber, zero toe ft and 1/16 toe-in rear. Tire wear is very even and some testing with a pyrometer shows even temps across the tires running an 18x12 square setup.
#80 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I run into this on my GT4, I have to run at least 8 on compression (9 is even better), even though that takes some of the compliance out in order to keep the rear-end planted under hard braking. This is where MRC really is better than a passive damper as it can actively stiffen up when needed to keep weight transfer at bay. As far as rebound, I have to run 9 at a minimum for good chassis control, 10 is even better , but that is too much bumpy street use. What canister pressure are you running?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#81 | |
Holes for splined bolts need to be kept to a much tighter tolerance, they really need to be drilled and then reamed, and then checked with a gauge to confirm they are the correct size. This takes a bit more time but not THAT much more time, and it's not exactly rocket science to properly size a simple hole. For what they are charging not being able to achieve proper tolerance is unacceptable, and dismissing my input on the matter as if I'm an idiot is also unacceptable. I have a ME degree and specialize in manufacturing, I probably have a lot more experience on this particular subject than anyone at Vorshlag and most folks at MCS.
#82 | |
I run a lot less damping for bumpy autox venues... it improves grip but makes the car harder to drive. Damping adjustments on RR2 adjusts both low and high speed damping together, you can see that on the curves MCS supplies.
#83 |
Yes FE4 bar. I cannot find anywhere to buy the hotchkis bar. From what I have seen, this thing can take a year to get delivered. I thought about getting the FEA bar, but I thought the FEA bar at full stiff was the same as the FE4 bar. I can't find the thread, but I remember reading that the FE4 bar was made stiffer to compensate for mag ride being more compliant.
#84 | ||
Yeah, I needed the weight transfer to keep the front tires in contact with the ground, otherwise it was just skipping. At 8 compression the car would basically just slide instead of braking. I will do some more research on suspension setups to adjust the rear independent from the front. I just wanted a baseline of I can drive this car at a track before I got to Road America. Quote:
I am non-remote so I cannot adjust canister pressure.
