#71 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Sorry to bring this back from the dead, but I'm in the market for some new summer tires, and am going the 555 RII on the rear, what do you suggest for the front? Kind of want to steer clear of going different brands and models but you mentioned as long as their not in the front, so i'll need your suggestion for something else.
#72 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Above a post mentions this: KamZL1 - I have now had: 2 sets of PS4S (315) 1 set R888R (315) 1 set NT555R2 (305) and in my honest opinion R2 blows both of these out of the water. in many different aspects. PS4S is an expensive tire that will not offer you any kind of real-world straight-line performance. If you plan on using 2nd 3rd or any kind of hard launching, you will just spin these things. even the 315s when I was stock. Better in rain and great cornering but not worth it IMO. R888R - I bought into the hype and tried these (10k miles out of them maybe less btw) These weren't exactly cost effective either but hey a lot of people run these they must be great right? sort of. I did the 315 and was initially happy. I was stock at this time also. To really make these shine, they HAVE to be warm. And I mean HOT. which to me was the biggest drawback and reason not to go with these again. They already do not come with a lot of depth. couple that with having to do a pretty good burnout every single time you want them to really work, these really wear out very quickly and are one of the most expensive tires you can buy for this platform. They are also quite loud, the mud tire analogy is not an exaggeration. Also, once they are close to the end of their life, they fall off of a cliff. I think the 345 is where these tires shine and have gained their reputation on really high hp stuff. But if you are normal working person like me and cannot justify changing these every 5-10k miles along with the other issues mentioned, skip on these. 555RII - Been having these for about a week now at about 750 hp. Very impressed so far. Did the G2s on the front and like those as well. These things WORK. No need for the excessive heat cycling, they just hook and book. Obviously heat makes them better but seriously the stability and traction at lower rpm launches now is night and day. Point and shoot. No observed sway at high speeds either. These things are awesome AND they are the cheapest of the three options by quite a significant amount. Have not tried rain yet so can't speak on that but I can say this thing turns good as well. not a soft sidewall. This is by far the best all-around performance tire and bang for your buck out there right now for our platforms in my opinion, and it's not really close..
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#73 |
#74 |
#75 |
![]() Drives: Z06 Join Date: Oct 2021
#76 |
will take a look at those, thank you fellas.
