#71 | |
#72 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
#73 |
![]() Drives: 2024 Camaro ZL1 Join Date: Aug 2023
My employer provided work truck is a Ford. I leave it parked out front so people will realize there is nothing worth stealing here.
#74 | |
![]() Drives: 2019 ZL1 Join Date: Sep 2018
I don't own a ZL1 anymore but this is a major problem with TRX owners. I initially had Ravelco installed after my purchase (it's still there) but I now have IGLA and like that system much better. Do some searches on Ram TRX stolen or IGLA. A TRX owner recently had his track stolen WITH Ravelco and has camera footage of them driving away. The benefits of IGLA is they can't see it, they can't delete your key or create a new one and you set your own PIN code using steering wheel buttons or carry a small key fob to start your car.
2019 Black ZL1 - A10
#75 |
#76 | |
![]() Drives: 2018 Camaro 2SS Join Date: Jan 2021
#77 | |
#78 |
#79 |
![]() Drives: Chevy Camaro ZL1 2021 Join Date: Mar 2025
Horn Disabled after attempted theft.
Folks, they tried to steal my 2021 Convertible ZL1 2 nights ago. Something must have scared them off. They cut the top and somehow disabled my horn in record time. I cant even figure out where its disabled. The fuse is good and i hear it clicking near the fuse box when i have my son hit the horn. Any ideas would be appreciated.
#80 |
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I'd like to see car thieves get the ultimate penalty for their antics.
#81 | |
![]() Drives: 2023 Radiant Red ZL1 Join Date: Aug 2018
Current 2023 Radiant Red ZL1 1992 Z28 Previous 2018 2SS Redline Edition 1992 RS |
#82 | |
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
![]() Now most importantly make sure you have some good anti-theft devices on the car, and I am not talking about the factory alarm, immobilizer or OnStar. None of these will prevent your car from being stolen. There are many options out there and I would review the threads on this forum that discuss the various options. My personal recommendation is to take a look IGLA, but again there are other options that can be effective. Though I would recommend not going down the pull/replace fuse/relay route, there thieves that know about these and are ready to deal with these. The above is important as depending on where they tried to steal it from, there is a very high probability there are going to try to steal it again. As for the clicking, it sounds like a relay engaging, which is probably the horn relay. Though I am not sure if this is a separate relay as isn't listed on the diagram I looked at. The only other thing to do is get a multimeter and see if you can check for continuity and/or voltage going to the horn as needed, and try to locate where the connection is broken. |
#83 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#84 |
![]() Drives: 2017 ZL1 Coupe White A10 Join Date: Feb 2017
What about these OBD port lockouts? One
company claims OBD port will be damaged if thieves try to remove it. Damaged port, but still keep car. |
