04-06-2023, 01:18 PM | #71 |
Nice update! I like your attention for details!!
2016 NFG 1SS A8
04-07-2023, 07:07 AM | #72 |
Petro-sexual
04-10-2023, 09:41 AM | #73 |
Petro-sexual
Update - 04/10/23:
Just a small update on a couple things.
So - more farting around. I haven't played with fueling like this before, so I'm reaching in the dark some. I think the LOW SIDE tuning is complicating it further for me because of my lack of knowledge, and this is probably easier than what I'm making of it. But - hopefully I can get closer with some more fine-tuning. This is a great excuse to drive the car though
04-10-2023, 10:59 AM | #74 |
@radz28 Have you thought about using the method I used just to compare?
I was able to get things fairly close pretty much in the first tune. Bad wiring aside lol Maybe it would make a fun comparison for you to do?
04-10-2023, 12:07 PM | #75 | |
Petro-sexual
I have only little more motivation for my little project. I just thought I'd give it a shot. I know of at least one more person that was interested in seeking an alternate method, along these lines, so I thought I'd give it a go. I'm impressed with what you're experiencing though. I'll be jumping into that CLOSED LOOP pool soon
04-10-2023, 02:42 PM | #76 |
I looked at the data last night from HPT from my earlier run. The lower "perceived" cyl airmass messes things up a little for spark and maybe some other things, but in a practical sense... everything is working well. Moving 10% out of PE, adding that into the MAF using the spreadsheet method Mike described, and bumping the torque in the EQ Torque table seems to have made most stuff just "work"...
Now cyl airmass and maf lbs/min/etc are all skewed low by about 20% in the HPT log from ECU... but if I take logged readings for say... cyl airmass... and multiply by 1.2... then I get the (calculated) values I would expect to have seen there from before.... hopefully that all made sense. Never having been on a dyno... my main way of seeing if changes were working was cyl airmass and maf readings. So validating that reflex + e92 still add up in the log was very satisfying. I know it'll get messier once I pulley down... I'm just 1-for-1 right now... taking the existing curve and splitting it 60/30 essentially... but the pulley change will shake it up a little. Overall... the "torque model" seems okay. It's manipulated... but it seems to have just worked out. Which I'm sure is why Mike recommended it
04-12-2023, 10:05 PM | #77 |
Petro-sexual
This is a placeholder for leaving notes, while I consternate, and before I forget what I've been thinking about, lol... I'm going to polish this as I have time to really let this stuff sink in. I'm not a tuner, so I don't do this every day, so it's not easy to keep track of where I was, where I am, and where I want to go with a lot of these settings. Having consistency on the street is also very difficult, and traction can be an issue, not to mention trying to be "safe" is just an illusion. Bottom line: I'll stay with this method until I stop getting progress, or it just isn't working, as I can understand it. Having little formal training, and learning from people here that share, and reading and reading and reading any relevant posts has been my education. I've paid for a few specific topics here and there, but no whole courses.
To start: This method is, almost, portrayed in training as simple, IMO. Perhaps it is for a person more knowledgeable than I (and I don't have a lot, lol), and someone who does this kind of thing more consistently, but that isn't the case for me. This is my first foray into fuel system tuning, and that tripped me up on this side of the injector tuning, as I see it. What this method, seems to me, is a recharacterization of the DI INJECTORS. Essentially - you consider about where you expect/want the PI to come in, and try to report they flow a higher volume of fuel than they do around those conditions. So - you increase the PROFILE 3 MULTIPLIER [33355] enough such that you retard fuel volume from the DI by about the same percentage you're trying to bring in from the PI. That makes sense. BUT - if you're in a state of understanding like me, understanding what is commanding from what is reacting, can be difficult to decipher. But - it seems like I'm seeing some consistency in how many of these changes influence how the E92 responds. It's a delicate balance.
SUMMARY: Obviously - if you were to try this, that is your choice, and I'm not responsible for what happens. I'm not sure I'll include tune & scan files here, because I'm not trying to make a tutorial. When I'm more confident in everything, I'd be happy to PM those to anyone interested for comparison, but I'll show screenshots soon. I'm probably about 95% (04/13/23) of as far as I have the ability/knowledge to take it, and that will finalize after some driving in CLOSED LOOP with the REFLEX. I think this method IS a good alternative for adding PI, and if I had experience with the fuel system prior to this endeavor, this wouldn't have taken as long. The bad weather until recently didn't help either. I tripped up a few times, and think I learned, and have made progress. I haven't had to alter my E92 airflow model for the added fuel, which was my goal, so my TORQUE should be okay. I do have some polishing to do in my TORQUE MODEL though, because I had to make up the E85 VTT. My tranny is shifting too hard in some instances, so I'll be smoothing those out. I added somewhere close to about 80-TQ over what my gasoline models were, so I might try pulling those down a little until I start seeing TMA kicking in. I might have some TCM adjustments I could make, too, but other than some shifts that are a little too harsh at lower throttle, it seems okay, and I'm not getting any weird slip in the SCANNER CHANNELS. This has been pretty fun. My wife complains I don't drive the car enough, so this makes a good excuse to. He LOVES the E' though. SHEESH. That's too be expected, and totally fine. I like the cleaning power of the E', too. Good stuff.
04-26-2023, 12:24 PM | #78 |
Petro-sexual
04/26/23 - Notes/Update/Remblings:
I've been running at about 75% E' for a while now, and I'm not sure if it's because of the volume needed, AND me continuing to ask too much of the OEM high pressure fuel system, is causing continued fuel pressure woah's... I have a feeling it might be that, and because of the method I'm continuing to try to develop, that I'm trying to get the high pressure side to do more than it can, though, there are conflicting observations I think I'm seeing. I could be completely wrong in my interpretation of the data, but I'm still, seemingly, finding some improvements - that also seem to lead to more struggles elsewhere. I like ice skating uphill, I suppose...
I THINK I'm SO close with this method. If the SOI/DESIRED PRESSURE changes don't influence things how I want, I'll have to think long and hard about the magnitude of these particular issues matter. I'm not going to drive/race starting in 4th gear at 1500-RPMs. As stated already: maybe this is a sign I'm not using the REFLEX enough, and I need to seek adjustments to utilize it to a greater percentage. Knowing this is an issue, as it stands right now, irks me, but I don't know if it's enough to abandon this method yet. I still recognize the prevailing method is completely fine, and can fall back on that any time I want. I can drive the car, as it is right now with this complication, and not worry about anything, so I have that going for me, too. Testing and trying to fix these new complications is, also, a good excuse to drive the car, so there's that, too. I'm still having fun, and this damned billet lid is SO GREAT!!! The extra blower noise is as perfect as I could imagine I wanted.
04-27-2023, 06:34 AM | #79 |
Good read. Love the detail! I like that you are bringing new info to the forum. This is NOT a criticism, but just a comparison... My own build seems very straightforward in terms of the tuning following Mike's method. For me, getting things dialed in after i pulleyed down is the more complicated part, but so far still just mainly fueling and MAF adjustments in E92 and Reflex, and getting shift points right with the added boost from the pulley. There are some things going on with my low side fuel pressure, but nothing I'm super concerned about. Ill post more on my thread when i get time.
Learning's the fun part.
04-27-2023, 08:20 AM | #80 | |
Petro-sexual
I'm hoping I found a culprit... In comparing logs, I see that since adding the PI, I've been adding to the E92 MAF, in these areas of the curve, all this time. In fact - I was up to 20% fueling in the E92 than I was before adding the PI. I think I should have been adding to the REFLEX instead, and I'd been adding it to the E92 this entire time (I'm not sure what the rational was...). Maybe it was to keep IPWs in the range I was shooting for? I forget now because it's been so long, but I'm going back to where my E92 MAF started, and am just going to add fuel to the REFLEX instead - which is what I probably should have been doing. I'm going to find out soon enough, LOL!
04-27-2023, 11:47 AM | #81 |
FWIW it’s very easy to strip out the rail pressure at mid range, as a matter of fact I’d say it’s easier than high RPM! The cam is spinning less RPM leading to slower stroking of the HPFP coupled with peak torque can be tough to fuel DI only, and if you overspin your blower (not happening in your case Rad) it makes it even worse. It’s common to see rail pressure drop on the hit and then recover as RPMs increase.
04-27-2023, 12:29 PM | #82 |
Petro-sexual
Ah! Interesting. Thank you Josh!
04-27-2023, 02:16 PM | #83 |
Torque requires more fuel than horsepower.
2016 NFG 1SS A8
04-27-2023, 03:06 PM | #84 |
I know your method is different than mine, but my thought would be to continue to balance the E92/Reflex MAF at the same time to keep the 30%/70% split... and not just add to one or the other.
I would think changing only in E92 will affect torque model more than splitting the difference between the E92 and Reflex... or not at all if you only add to reflex... but then... I feel like it would just make things wonky for tuning if you only add to reflex. Then again... you already started with a valid torque model... and haven't changed that right? The E92 still thinks you are doing the exact same thing as before, it just thinks it needs to run the DI less because it thinks they flow more fuel... I recombine the E92/Reflex curves to a total value in a spreadsheet... do my fuel adjustments to the combined number and then split back out 30/70 (actually 20/70 because of the 10% PE ->MAF, lol)... confusing to explain. I haven't gotten to the point yet where I need to go above 30% in the reflex, but I decided that I would probably recombine the curves and do a 35/65 split or whatever I need instead of just increasing the Reflex. Although effectively that's what would happen right I guess my point is that in my completely uneducated opinion... I'd keep splitting the same % across the entire range and not unbalance by adding more to one or the other unequally. Good times indeed. I have no basis for my opinion, lol. Other than it makes me feel better. Jump then look right
