Old 06-25-2022, 10:25 AM   #71
Camaroking98
Drives: 2019 ZL1
I would probably get the car back and go elsewhere. Drive over and see exactly how much work he's done. Which shop is it?
BTW, since the OEm TB will support 750-800 hp, a 103mm is not needed.
Under pressure performance COS
Camaroking98 is offline   Reply With Quote
Old 06-25-2022, 10:33 AM   #72
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Camaroking98 View Post
I'm gonna walk in monday if I have time. And yes, I don't think the 103 was needed either. I just opted for it because later down the line I was gonna add more power.
I just don't like how one minute he said the stock would be fine and the next it wasn't.
I would go with CAI, headers, 10% lower, and cam. Just as a reference number, mine made 723 wheel with OEM TB and SC (untouched)
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-26-2022, 12:19 AM   #73
Camaroking98
Drives: 2019 ZL1
I like those numbers. Means mine should make at least that much if not more if they can tune it properly.
Out of curiousity...how long did that build take for you?
Old 06-26-2022, 08:26 AM   #74
JSH
JSH's Avatar
Drives: '20 ZLE
Is this still where you are?
Texas Speed 2' Long Tubes With X Pipe
Texas Speed Cam Kit
Roto Fab Big Gulp CAI
2.5' Pulley (to get stock levels of boost back here at altitude)
103MM Nick Williams Throttle Body
Tune
Does your cam kit include everything from cam thru valves, and p/p heads?
If yes, it probably will not make 725 unless you go a 10% lower. I believe the OEM upper is 2.5".
HPE did mine in a week.
2020 ZL1LE A10.
Old 06-26-2022, 02:59 PM   #75
Camaroking98
Drives: 2019 ZL1
Texas Speed Cam Kit
Tune
So mine is 2.3 pulley & now the supercharger is being ported. The heads were machined and the kit came with all springs and such.
Damn...one week...I'm pretty disappointed at how long this is taking.
Old 06-26-2022, 03:07 PM   #76
JSH
JSH's Avatar
Drives: '20 ZLE
Ah, you've changed it since your first post. It'll be fun regardless of what it makes.
2020 ZL1LE A10.
Old 06-26-2022, 03:10 PM   #77
Camaroking98
Drives: 2019 ZL1
yeah the pulley they ordered was the 2.3
the porting of the supercharger was just decided because they said the 103MM throttle body was "choking" on air. Idk if I buy that...but that's what they said. They said porting the blower would get everything to work properly.
They decided on the machine work for the heads and stuff too...that wasn't explained to me at first either...but they said that's how they do their cam builds so I just had to accept it.
As long as the car is built properly and runs like a champ, I won't care. I'm just really annoyed that it's turned into basically a month without the car.
Old 06-26-2022, 04:00 PM   #78
JSH
JSH's Avatar
Drives: '20 ZLE
Which shop?
2020 ZL1LE A10.
Old 06-26-2022, 05:16 PM   #79
Camaroking98
Drives: 2019 ZL1
Which shop?
under pressure performance
Old 06-26-2022, 06:47 PM   #80
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Looks like UPP does mostly import turbos, not domestic superchargers. Their reviews suggest they are competent at welding, but not tuning.
I'd give them a fair chance to get things right. If they fail and won't or can't address the failures, then cut bait.
Old 06-26-2022, 06:50 PM   #81
Camaroking98
Drives: 2019 ZL1
yeah I did notice that. I did ask the guy if they could do what I wanted done since I didn't want to go turbo route...he said they could. I'm just anxious now.
If the car doesn't run right when I get it back I have a backup tuner on standby in denver.
Old 06-26-2022, 08:13 PM   #82
JSH
JSH's Avatar
Drives: '20 ZLE
I wouldn't worry about tuning because you know there's good LT4 tuners in Denver. Unless you know they have LT4 experience, I would worry about the wrench work. LT4 valve train work has its inevitable nuisances learned the hard way.
2020 ZL1LE A10.
Old 06-26-2022, 08:18 PM   #83
Camaroking98
Drives: 2019 ZL1
He said they have worked on some. Wasn't gonna let myself be an experiment if i could help it.
Old 06-27-2022, 08:45 AM   #84
KamZL1
KamZL1's Avatar
Drives: Z06
they sound full of shit tbh with you, sorry this is happening. stories like this make me feel very lucky to live in houston
KamZL1 is offline   Reply With Quote
cai, cam, headers, mods, street build
