#71 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Ha ya. Always log It was cold tonight, probably coldest night since when ive had all work done, plus tires were showing cool and rears of course needed heat which i didn't do. I still wasn't expecting to go sideways at 80 in 4th.Mat temps were like 75F lol.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#72 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
ABL, always be logging haha. Especially dialing in the ethanol. Nice temps!
#73 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#74 |
Good call by logging in the cooler weather. Always log the coolest temps you plan to run the car in. PD and Centri have no boost regulation. The cooler the air the more boost they will make. If it wants more fuel then it's trying to make more power.
#75 |
Fuel pressure issue fixed.
The dw300 pump didn’t have a check valve in it, looks like they re-designed the pump. The pump was replaced with a holly 12-170 100GPH pump, with a check valve. Other pump without check valve wasn’t building pressure fast enough. I guess that’s what happens when the fuel flows backwards ![]() Holds a constant 80+ psi even with 40+ % ethanol At around 840rwhp.
