Old 01-05-2021, 05:18 PM   #71
fxdxron1
Drives: 2016 Camaro 1SS
I have found a different location to mount the ground cable I removed the bolt from the water pump and added a 1/2" longer bolt to create a stud to mount the grounding cable on.
fxdxron1 is offline   Reply With Quote
Old 01-05-2021, 05:52 PM   #72
fxdxron1
I want to thank the original poster for getting this thread started for helping us with a problem that drives us all crazy.
Old 01-05-2021, 10:52 PM   #73
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
I like this ...
what length cable did you use 19 or 21 inch?
Racerman27410 is offline   Reply With Quote
Old 01-05-2021, 11:57 PM   #74
grampa_ss
grampa_ss's Avatar
I ordered a 21" with 3/8ths (3/8ths is perfect). Plenty long enough. My 21" was actually 22.5" end to end.
Old 01-06-2021, 08:01 AM   #75
Choda
Drives: Turbo 6.2
Im going to do this too. Thanks guys
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-06-2021, 10:23 AM   #76
fxdxron1
This is the cable from gen5diy 20" you can route the cable under the fuse box this cable is a good length to use. Also I decided to double nut the terminal lug see new photo and I will also put a larger Fender washer on it today to cover the whole terminal
Old 01-06-2021, 11:38 AM   #77
fxdxron1
Final pictures of connection with modified fender washer.
Old 01-06-2021, 01:40 PM   #78
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Well done and thanks for sharing another connection point for the engine ground. Happy hot starting! I must say this fix has given me new joy and confidence in my car. I no longer fear it will not start and strand me somehwere.
476 rwhp/440 rwtq (sold)
Old 01-06-2021, 09:59 PM   #79
MackSteelPrivateEye
And GM couldn't figure this sh!t out?
Old 01-06-2021, 10:00 PM   #80
MackSteelPrivateEye
Is that the original bolt?
Old 01-06-2021, 10:57 PM   #81
fxdxron1
That is not the original bolt. The new bolt is 1/2" longer.
Old 01-07-2021, 12:09 AM   #82
GrayLT1
Drives: Chevrolet Camaro
Good deal. I had the very same issue with a 1972 corvette. Body was all fiberglass, and after many years of not even wanting to go get gas due to being scared it wouldn't start I figured out that the engine was missing the main ground wire.... So after many years of stronger batteries, high torque starters, insulating gaskets under carburetor, etc... it turned out to be the missing ground wire... After that.. like you it started great no matter if it was hot or cold.. (usually started fine when cold, just not when it got hot).
I have a 2021, so not sure if this is still a potential issue for it, but good to know in case the car starts hard starting when hot.
GrayLT1 is offline   Reply With Quote
Old 01-07-2021, 08:53 PM   #83
MackSteelPrivateEye
So looks like the original bolt would have still worked if its just 1/2" longer.
Old 01-07-2021, 09:35 PM   #84
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I also have a 2021. Anyone know if Chevy has improved the starter and/or the ground wiring such that this is less likely to be a problem?
N Camarolina is offline   Reply With Quote
