#71 | ||||
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
To refocus, I'm re-quoting the statement to which I originally responded:
Matt Miller
2020 SS 1LE |
#72 | ||
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
Seems like we're pretty much on the same page. I'm enjoying the conversation as well lol.
The easiest way I've found to visualize this is as follows: picture driving down a brick road. You've got lots of sharp/jagged inputs of displacement at the wheel. Focusing on one individual spike, initially there's some pretty significant deformation of the tire during the initial impact that typically builds a ton of force at the point of contact but doesn't create any significant motion due to the inertia of the system (especially if the suspension was already in rebound travel as the hit the bump). Now, with the force imbalance between the tire force pushing up from the road and the spring force pushing down and instantaneous motion = 0 (meaning no damping force) the corner assembly starts to accelerate in the compression direction. Here's where F=ma comes in; with a lower rate in the spring the delta force between the contact patch and spring stays higher for more time/suspension travel which equates to a sharper acceleration curve and therefore higher velocity. It's not a huge change in velocity, maybe 5%-7% max from data I've seen, but over the life of the damper it's a non-negligible decrease in life. An undamped system would see higher changes in velocity, but since the damper is doing more work the velocity change isn't necessarily huge. A change like that should still be enough for the driver to detect, but if left alone it can shorten life more than 3σ below the nominal life of the damper when looking at the distribution curve. Quote:
Not going to happen with lowering springs alone unless they're complete garbage and very unlikely to happen on a 6th gen Camaro in general, but still technically possible
2017 SS 1LE.
#73 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
So, ideally, aftermarket springs are not a "one-size-fits all", but are specific to the exact trim. Sometimes aftermarket springs will "seem" to be, but then when you go and compare against the same product for the different trims/models, the part number is the same, so they are just blowing smoke up your a$$. I went through this with my BMW, there were readily available springs, but they were the one-size-fits-all, I had to import specific ones from AC-S that were relatively hard to get, to properly do it for my BMW (which was used in conjunction with a damper upgrade). This is another compounding factor about why lowering springs can be bad. You can end up under or over sprung due to this.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
#74 | |
2017 SS 1LE.
