Old 12-07-2020, 01:19 PM   #71
Choda
Drives: Turbo 6.2
1:58 Lol
https://youtu.be/ELzLcuSn23o
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 12-07-2020, 07:52 PM   #72
parish8
Drives: 17 SS a8
Originally Posted by Choda View Post
Call me nuts.
To be fair I wouldn’t have considered it if I hadn’t broke my 6.2. I will be funny if it is one of the quicker cars with a budget build 5.3.
Old 12-09-2020, 09:35 PM   #73
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Originally Posted by parish8 View Post
Call me nuts.
Do you have the intake port cross sectional areas, exhaust port cross sectional areas, runner and collector lengths? I can run a simulation of what you have and come up with cylinder pressure numbers, temps, and some other info in DynoSim.
I am also working on a simulink engine model to back up the DynoSim numbers, but simulink/matlab is dedicated to engineers and scientists, so there is zero user friendliness and you can drive yourself insane trying to stablize models and debug things.
Also i'll need your compressor maps and stuff too.
I would love to have a in cylinder transducer as well, I remember 10 years ago how people were starting to do things themselves like that back then and how they promised in 10 years we will have it made with cheap sensors and all this. It seems like things have gone nowhere, its insane how all the parts still cost just as much as they did back then.
cmitchell17 is offline   Reply With Quote
Old 12-09-2020, 09:48 PM   #74
parish8
Drives: 17 SS a8
I don’t know any of that.
Old 12-10-2020, 08:22 AM   #75
cmitchell17
It's not really that crucial, I can estimate it from the LT1 head I tried to measure. Do you have a compressor map though?
Old 12-10-2020, 09:10 AM   #76
gtfoxy
Drives: '21 Wild Cherry ZL1
He posted this a while back in this thread.
https://www.borgwarner.com/matchbot/...6_wrsin=92044&
Maybe it has changed though.
Old 12-10-2020, 09:37 AM   #77
parish8
Drives: 17 SS a8
Precision doesn’t show their maps. That turbo in matchbot is my best guess for the right map.
Old 12-10-2020, 06:32 PM   #78
cmitchell17
Here is my first go at it. For some reason it isn't making boost until 6000 rpms and only hits 7psi at 7000 rpms, I'm not sure how much more you'll be spinning it. I've never really messed with turbos or supercharges too much but I'm using the built in map for a BW 8374. This is also with the optimally calculated MBT timing which is realistic, I turned it down to 18 degrees like you mentioned, but it didn't make any torque, I need to figure out what is causing it to limit boost.
Anyway, at 7000 rpms it hits 7.5 psi and peak cylinder pressures of a little under 2000 psi, seems kind of low?
Old 12-10-2020, 09:05 PM   #79
parish8
Drives: 17 SS a8
After I cam it I am thinking 7500ish rpm but really don’t know. I am able to build 20psi+ at 4000rpm now, boost building is not an issue. Not really sure what all is going on with your software, looks interesting.
Old 12-12-2020, 11:58 AM   #80
cmitchell17
I have something wrong in the A/R ratio or the turbine diameter, I am using a generic BW compressor map (they don't have Precision built in):
I'm using a 76mm turbine (2.992in) and a .91 A/R, since its looks like thats the closest the BW software solved for (but apparently it didn't solve to the correct solution since it says that all the dots have to converge to one A/R/diameter line:
Old 12-12-2020, 12:17 PM   #81
gtfoxy
Attachment 1052733
Attachment 1052732
Doesn’t your turbine side say 1.05?
Also try cranking the timing & leaning it out below 4K rpm.
Old 12-12-2020, 12:20 PM   #82
cmitchell17
Your turbine side says 1.05.
Yeah you're right, either way I guess its either any one of these 3:
I can make it build boost if I put in a smaller turbine size, here is a 1.850in (46mm):
This program isn't really open source, so I have no way of knowing exactly what its doing, I believe it uses a good bit of empirical data (I believe this makes it more accurate and definitely more user friendly and geared towards non-engineer/non-scientific people. I believe it simulates like an actual dyno operator would run a engine dyno, where its loaded down and allowed to step up through the rpm range and dwell a little at each step to reach steady state, so that's why you see the boost curve has to be built up since I think the initial conditions it starts with is the turbine/compressor is at zero rpms.
Here is the timing it uses (when its set to calculate optimal timing):Name:  Capture5.JPG
Obviously this probably isn't realistic timing, even with E85, so here it is with the 18 degrees I think you mentioned earlier in the thread:
You can see torque and peak cylinder pressure have dropped significantly. The "optimal" "MBT" timing this calculates is not going to be accurate, it requires 3D CFD analysis to come up with that and is impossible to get accurate in 1 dimensional analysis.
Old 12-12-2020, 12:26 PM   #83
gtfoxy
Attachment 1052734
Attachment 1052735
See my edit & try it again.
Also, his dots are close to the 74mm/.92AR. Turbine maybe try that as well.
Old 12-12-2020, 12:37 PM   #84
cmitchell17
Here is a 74mm/.92 A/R:
I can control AFR to whatever I want, unfortunately I can only ramp in a timing advance and then set it to a constant at a certain RPM, not sure why they don't offer that functionality, but I guess its the old school way of controlling timing just by a ramp and a peak like a distributor setup. You can still have it set to calculate with "optimal" but then again it might not be realistic ie.(30+ degrees).
