Old 10-31-2020, 12:41 AM   #71
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
I appreciate those who have been early adopters for the LT2 IM. I’m strongly considering the LT2 IM but I am also indecisive since most prefer to opt for MSD. What are some of the main reasons you’ll chose the LT2 over the MSD because it appears based on GPI your can port the LT2 but it will be very thin at the snout and it won’t be a “true” 103 mm even though it fits versus the MSD it’s not a problem and it can handle boost if you want it down the road which is a trade off I assume
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 10-31-2020, 01:53 AM   #72
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
This link below will answer your questions, check it out.
https://youtu.be/rZSprqJHA9I
The price, real Dyno gains, LT2 with cover looks way better then the MSD IMO made me go for the LT2 manifold. Plus I am just the type that likes to fiddle and do stuff that others will not. I did the 103mm on my 2016 and really wasn’t satisfied with it. So I decided to go with the LT5 throttle body this time.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 11-01-2020, 05:47 AM   #73
s346k
s346k's Avatar
Drives: like an old lady
the biggest reason to go LT2 over msd is price. but hell, if the vendors and sellers push the prices above $500... might as well get an msd. you can buy a used msd for a few hundred more. the LT2 manifold is the LS6 manifold to the LS1. people will inflate its value right out of a reasonable area. i bought an LT2 cheap, i won't ever sell it just because i think they are cool... and i know they are legit.
with all of that being said, hopefully my car will have a ported msd on it next weekend. then i'll have a used (unported) msd to sell. no one needs 4 intake manifolds haha.
Old 11-01-2020, 05:58 AM   #74
Purplt1
Purplt1's Avatar
Drives: 2020 ss
Or can just shop around so you dont have to pay some of the vendors pricing. I have about $250 in mine. Only cost about $30 to modifiy it and can port it yourself.
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm
Purplt1 is offline   Reply With Quote
Old 11-01-2020, 06:40 AM   #75
s346k
s346k's Avatar
yes, same. but people are paying the prices so vendor price will only go up.
Old 11-01-2020, 08:46 AM   #76
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
Got Mine from GPI and one from Rock Auto $185.00
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 11-01-2020, 03:51 PM   #77
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
I have the GPI one also.
How do you remove the line at the back of the OEM intake? I can't figure it out.
I'm assuming that hose plugs into the one that GPI drilled in the back of the intake?
JTRATX is offline   Reply With Quote
Old 11-02-2020, 09:11 PM   #78
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Push the red ring in (towards manifold) and wiggle the hose out.. I found it easiest to follow that hose and disconnect it where it ties into another hose and pull the manifold out with hose Still connected. Then u can disconnect it from manifold while it’s on bench
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
Dvs510 is offline   Reply With Quote
Old 11-03-2020, 07:42 AM   #79
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Wow Dvs510, your set up looks is so very close to my plan with my 2021 LT1 that is being built this week (11/2). E85, LT2 intake, secondary delete, Borla s Mufflers, custom tune by Jannetty, 180 stat, moded or RF intake, Solar 91mm TB. Did you ever dyno your car?. Curious how much RWHP you ended up with.
lt4camaro is offline   Reply With Quote
Old 11-03-2020, 07:47 AM   #80
ItsoverSS
Drives: 2020 1SS Camaro
Originally Posted by BlackbeastSS2 View Post
Revised #3
Didn’t like the Camaro covers on there, going back to no covers on side. I really think the coil relocation kit and different valve covers is the way to go.
Uffffff😉
ItsoverSS is offline   Reply With Quote
Old 11-05-2020, 02:01 AM   #81
Dvs510
Dvs510's Avatar
Na , haven’t had a chance. Hopefully in the next couple weeks tho
Old 11-05-2020, 07:28 AM   #82
lt4camaro
lt4camaro's Avatar
Could you let me know??? don67gm@gmail .com
Old 11-06-2020, 06:37 PM   #83
madkat7134
Drives: 2016 camaro 1ss
I have non ported 95 mm tb and rotofab cai and the lt2 intake non ported should I be worried about running lean?
madkat7134 is offline   Reply With Quote
Old 11-06-2020, 06:49 PM   #84
BlackbeastSS2
Did you port the LT2 opening to match the 95mm throttle body? If you didn’t port the opening the 95 mm is acting like an 87 mm. So no check engine light don’t worry then.
Get a AFR gauge to be safe.
