#71 | |
https://www.lingenfelter.com/PROD.ht...5#.YnmNwejMJMs I do not see a 42% on their site, but I'm probably just missing it.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#72 |
LPE rates their fuel lobe in MM. The 7.85mm is 42%.
#73 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
Is it Ok to use 2900PSI with LPE big bore? The homepage is saying "Never exceed 15 Mpa", 2150psi.
#74 |
![]() Drives: 2019 Camaro 2SS Join Date: Aug 2020
The LT1 pump is rated for 2175 I believe and the LPE is based on it. I’m not exactly sure what all they do but I believe it’s bored out and maybe machined deeper for increased stroke. Folks on here have ran them at higher pressures and I haven’t read of any failures but always a chance of pushing things closer to that edge.
However I haven’t seen anyone get good results cranking the pressure up, flow drops off. The LPE pump flows 10% more at 2150psi then the LT4 at 2900psi. So ideally you’ll want to run at the rated pressure. Just have to make sure you have enough injector at the lower pressure if that makes sense. Example an LT4 injector at 2900 psi may flow similar to a +30 at 2150 psi. That’s why I bought +30 with my LPE pump. Figure I’m going to need that overhead at some point. I’ve seen some folks run 2400-2500 psi to help injectors that are too small get more flow, but you’ll sacrifice some flow from the HPFP. Trade off I guess.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
#75 | ||
Moderator
![]() You really need +30 injectors at a minimum, and preferably +52/+65 injectors to take full advantage of the LPE BB HPFP.
#76 | |
So it comes down to what parts are being used. LT4 injectors are based around 2900psi. So the LPE hpfp really needs turned up for them. Not sure how they would act with less pressure but my guess is it would be a waste of time. You really need larger injectors to run lower psi. FIC +30 gen 1's will run @ 2900 psi. The gen 2's will misfire. At least that has been my experience. XDI +30's will handle 2900 psi. I ran them @ both LT1 and LT4 pressures with no issues. XDI +65's want no more then 2600 psi based on the spec sheet. Not sure if they will handle more psi without misfiring or not.
#77 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
King my other vehicle has an LT1 pump and L83 injectors. I bought LT4 inj early on before I started getting schooled here. So would it basically be a waste of time to install the LT4 inj without the LT4 pump or BB? Also for a lessor hp would Lt1 inj be a work around to keep my pump and skip the LT4's?
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror ![]() |
#78 | |
#79 |
Old badass
Thanks King and maybe if I did do the BB I would clear my Whipple manifold without grinding since it's based on an LT1 pump? No reply needed if that's correct sir. Many thanks!
#80 | |
![]() Drives: Camaro 2SS 2017 Join Date: Jan 2022
LT4 intank plus booster 32% cam LT4 hpfp Fic 30s How will this do? Should I go with the LPE pump instead and dsx aux also? Goal would be going e65.
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT 2Forge 19" wheels daily, Forgestar D5 17" for track |
#81 | |
Side note: The gen 2 FIC +30's we used would not run LT4 rail pressure without misfiring. The gen 1's would however. You need 2900 psi for the LT4 hpfp. I would do: XDI +30 LPE HPFP pump +42% cam lobe This will allow you to run less rail pressure(2175psi), have plenty of fuel for E65, and the low side will extend out a bit further and you might not need any additional low side upgrades aside from the LT4/JMS combo up to 13-14psi of boost.
#82 | |
#83 |
Yeah we didn't neither. First set of FIC worked fine at 2900psi. The second set no bueno. Yes the LPE hpfp is designed around lower pressure so it will work. We recently installed a similar high side setup on a ZL1.
FIC +30 LPE HPFP JMS booster Runs E60 @ 13.5psi of boost with headroom to spare.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 05-21-2022 at 05:41 PM. |
#84 | |
