07-10-2020, 11:19 PM | #71 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I blew both front bushings in one twenty-minute session at Charlotte Motor Speedway today. I'm going back to stock.
07-11-2020, 01:43 PM | #72 |
Drives: gas powered Join Date: Jan 2019
you did say BMR didnt you...
07-12-2020, 09:40 PM | #73 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
A few autocrosses in and so far the bushings are still okay. But a little searching pulled up this Addco aco-65-615-0w, which appears to be a very solid billet bracket with a wider bushing. Just thought I'd throw this in here in case anyone wants to try it...or as placeholder in case I need to.
Matt Miller
2020 SS 1LE |
07-13-2020, 01:00 AM | #74 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
As a matter of fact, i feel they should simply issue a recall and supply a proper fix to all customers, before somebody wrecks. Just imo. |
07-13-2020, 12:55 PM | #75 |
Drives: 2013 C6Z06 Join Date: Nov 2016
SCCA Regional Time Trial at Nelson Ledges completed yesterday, with a new PB, and no bushing issues!
07-18-2020, 08:26 AM | #76 |
Drives: 2018 Camaro SS 1LE Join Date: Mar 2020
Mine went after 1 day of autocross passenger side split like everyone else's it looks like the consensus is correct about the grease tab shearing off and taking out the bushing.
I'm going to try the billet saddles and a new set of bushings with the tab removed but still waiting for the parts and had an event this weekend so I gently cut the stock ones off my factory bar and drilled a second set of holes in my factory bracket (to clear the bushing stop on the BMR bar) and we will see how it works out today. There was no way I was missing a whole weekend of racing because of this! |
07-18-2020, 08:46 AM | #77 |
Drives: 2017 SS 1LE Join Date: Mar 2016
Have you thought about switching to the Hotchkis bar? I think that's what Coby runs and don't think he's had any issues.
IG: @NC_M1SS1LE
07-18-2020, 10:23 AM | #78 |
Ryepile figured for the SS 1LE with G3Rs or better, the trick setup is Hotchkis front bar and BMR rear with BMR endlinks. SPL now has some great looking, but expensive links
https://www.splparts.com/2016-6th-gen-camaro/ |
07-19-2020, 04:46 PM | #79 |
I am amazed that nobody is screaming for heads to roll at BMR and for full refunds to be issued.
Seems folks have a completely different tolerance levels for aftermarket parts...which unfortunately doesn't lead to good results. Just my 2 cents. |
07-19-2020, 06:16 PM | #80 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I'm thinking of getting the Hotchkis front sway bar and BMR rear bar now that I'm using SC3R tires at the track... I assume I need BMR end links for both the front and the rear sway bars or is it just the rear?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
07-19-2020, 06:51 PM | #81 | |
aka BeastZL1
Just a warning the BMR rear end links will hit the rear spindle in the full-soft position, which is 36% stiffer than stock ZL1. You have to go 55% stiffer (middle) or 77% stiffer (inside hole). This makes it a bitch to tune for more understeer.
07-19-2020, 07:44 PM | #82 |
Unless you run a square set up, there likely is no reason for them. Imo.
07-19-2020, 11:29 PM | #83 | |
I’ll look into SPL end links as per the above post https://www.splparts.com/2016-6th-gen-camaro/ Interesting, based on that thread from early this year that we went back and forth on, You seemed to strongly believe I should be increasing sway bar because of the SC3R tires...Or do you feel that because I already have stiffer springs that this is not needed?
07-20-2020, 09:37 AM | #84 | ||
BMR... BMR... Bueller??? |
