Old 09-05-2020, 08:09 AM   #71
Dagstar
Dagstar's Avatar
Drives: 2016 Camaro SS
I took the plunge and added the same muffler to my setup (headers, no cats, borla s-type exhaust), and wow, it made a greater difference than I anticipated. Cold starts are uneventful now and sound very comparable to Sakudog's video. It did take some of the raw sound out of it, which I did like, but it's more enjoyable for me to drive now that it doesn't sound like I'm flooring it when giving only a little gas. Plus the supercharger whine isn't drowned out anymore.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc...
Dagstar is offline   Reply With Quote
Old 09-06-2020, 05:58 AM   #72
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '16 Camaro SS 6 spd manual transm.
Question
Originally Posted by alssiri View Post
I removed the resonators.
Ahmad
Does it sounds stronger than the stock NPP exhaust sound?
No crackle and pop sound or droning?
'16 Camaro SS
Prior cars:
'14 Corvette C7 Stingray Z51
'14 Camaro ZL1 w/. Recaro seats
'11 Mustang GT 5.0 w. track package
'02 Porsche 911 Carrera
'05 Infiniti G35 coupe sport
Bosse'sBoss is offline   Reply With Quote
Old 09-16-2020, 03:39 PM   #73
Repman
Drives: 18 Black ZL1-1LE
Originally Posted by Sakudog View Post
(Scroll to the bottom for pics)
Recently had a set of Kooks 2" long tubes headers installed to complement the Magnuson 2650R to build a reliable/safe track-focused power band. The results were exactly what I wanted, the car makes ~700 rwhp through the automatic and the power delivery is super smooth. Nothing tricky about the setup, just a 2650R on an all-stock motor with LTs, 93 octane, through the A10.
All of that was great, but it was just too damn loud for me, my neighbors, likely any track with any type of noise restriction, etc. To maximize my enjoyment out of the car, I needed to make a change. After some careful research, I settled in on adding a Magnaflow X-pipe muffler where the factory X-pipe was, replacing it with the Magnaflow X. I kept reading people trying to resonators to remove the high pitch rifle shot sound when mixing NPP and LTs but the effect being minimum on DBs and tone.
https://www.magnaflow.com/products/1...rmance-muffler
The end results are FANTASTIC and exactly what I wanted. The car has a mild startup, the ear-piercing BARK when the car roars to life is completely gone. That sound was okay I guess when the car was 100% stock, but after the LTs it was really difficult to live with for me and my 3 year old.
The car now has a much more mellow note and until you add in a lot of throttle, the car is actually really reasonable. Once the exhaust gas picks up speed, the X-Muffler can do less to lower the DBs but the tone is still deeper. So the exhaust, under load still gets VERY loud, louder than stock. However, now you can take a drive in the car and have a regular conversation with a passenger, listening to music or talk on the phone no problem, actually better than stock in that regard.
I realize some of you WANT your cars to be very loud and you enjoy that part of your car. Coming from an 1100 rwhp TT ZL1 and a Buick Grand National before that, loud and fast don't go together for me like it does for some of you, that's a personal thing.
In addition, now that I'm a total track ratt, listening to an ULTRA loud car @ 100% throttle for 20 minutes a day, 6 times a day, isn't fun, even with my helmet on.
(Some may ask, why to keep the stock NPP muffler and I'll give you my 2 reasons. #1 the aerodynamics of the car is affected slightly by removing the suitcase muffler and adding aftermarket mufflers. A void is created where the muffler once sit, disrupting airflow. This may not be an issue for you on your track, but COTA is a high-speed track and after 130mph to about 160mph the rear bumper shakes violently as air pressure catches the bumper cover and tries to pull it off, buffeting it and making it shake, causing lift and slowing the car down. Once you go away from that muffler, you end up adding a diffuser to cover the gap it left, that was a bunch of steps I didn't want to take to make my car even loud. #2 "weight savings isn't there" the stock NPP muffler by itself actually doesn't weigh that much, weight savings is typically negated w/a stainless system, unless you're going to a FULL race setup, which means no muffler and as you could guess, that isn't going to work for me, most track, my wife, child or my neighborhood. )
I hope this helps some of you who, like me, thought the exhaust note was TOO loud for Track use or just wanted it to be quieter but still enjoyable.
Start-up videos:
Outside
Inside
Partial throttle, higher RPM, light pulls:
Sakudog , I just wanted to say thank you for the idea of using the Magnaflow X-muffler in the perfect size for our tunnel. I have the Borla s-type with Kooks long tubes no cats ( melted green cats at the road course)and it was raspy and too loud this tamed it down and brought out the sound I was looking for. Great discovery! I am so pleased with my setup now, well done
I can put it in stealth and leave early mornings 5 am for track days without the neighbors up in arms and in track mode it is the perfect balance of sound level and tone .
Repman is offline   Reply With Quote
Old 09-18-2020, 09:26 AM   #74
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Super glad to read this, it makes the time I spend sharing my ideas/plans worth it!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 09-18-2020, 04:35 PM   #75
L78toLT1
L78toLT1's Avatar
Hey Repman, get that ZLE on e50 - e60 and keep your cats alive.
Baby Blue
Old 10-16-2020, 11:42 AM   #76
Deputy Dog
Drives: 2017 Super Sport Cam.
Start-up videos:
Outside
Inside
Any external Driveby videos?
Deputy Dog is offline   Reply With Quote
Old 10-16-2020, 11:44 AM   #77
Sakudog
Sakudog's Avatar
None
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 10-16-2020, 01:54 PM   #78
Deputy Dog
None
Will you do any?
Old 11-29-2020, 07:42 PM   #79
Rpmofatlanta
Drives: 17 camaro zl1
Thanks so much for posting this.. I have a whipple, long tubes, cam, no cats and a full atak and it is too loud.. I just ordered the muffler you have and am picking up a stock suitcase from a forum member on Friday.. I'll let you know how it turns out
Rpmofatlanta is offline   Reply With Quote
Old 12-05-2020, 05:57 PM   #80
Rpmofatlanta
Unbelievable difference with just the magnaflow on a full catback borla atak, long tube, no cats.. sounds great.. I can finally hear the whipple.. THANK YOU for finding this option and sharing it
Old 12-05-2020, 06:02 PM   #81
Rpmofatlanta
Old 12-05-2020, 06:03 PM   #82
Rpmofatlanta
https://postimg.cc/gallery/jJ0wHQK
Old 04-28-2021, 09:03 PM   #83
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
I’ll do another +1 for this. Thanks to OP and others for posting. I added 2” TSPs and hiflow cats into stock suitcase. WOT sounded like it should be measured on Richter scale instead of decibels. This made the car livable again.
Eric10905 is offline   Reply With Quote
Old 05-25-2021, 11:09 PM   #84
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Bringing this back alive... I just removed my cats, its loud .
My Setup
2" Kooks Headers
3" Borla Cat back w/Stype Mufflers
My question is, what kind of fabrication is needed to fit the magnaflow in place of the 2x pipes that come with the borla kit for each bank? Almost seems like by looking at the lenth of the magnaflow and the straight pipes it might be a simple swap?
If anyone has similiar setup let me know. Thanks.. I have the magnaflow in the garage.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
