Old 06-03-2020, 02:39 PM   #71
TrackClub
TrackClub's Avatar
Originally Posted by glamcem View Post
I might be wrong but it looks like car begs for more front tire and understeers quite a bit. I would try and see how the 305/325 with good camber feel and maybe use more trail braking to rotate the car at those tight corners. I really wanted to come to the Area 27 and VIMC this year and even signed up for an event then they closed the borders
Hey Cem that's an old vid from last yr when GMG had his alignment walk all over the place, so proly not ideal to draw too many conclusions from. Cheers!
Old 06-03-2020, 02:39 PM   #72
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
New PB!
Rotating the front tires helped getting more life out of the SC3R tires and I noticed I corded both inside and outside this time ..it's after about 15 sessions though so I am not complaining.
driver side
and Passenger side
The fact that it corded first on the driver side again (both inner and outer edges), even the Ridge has CCW configuration made me think that my alignment might be off a little bit.
I had my guy install the new set of tires for front wheels but he was busy so I couldn't have him check the alignment. I attended another event yesterday at the Ridge and improved my PB by 1.2 seconds. I feel that on a better day and/or with less traffic I should be able to take it below the 1:50 mark. My friend with a Z06 and R7s was doing 1:47.9 yesterday for the reference .
and the video from the event:
glamcem is offline   Reply With Quote
Old 06-03-2020, 02:45 PM   #73
glamcem
glamcem's Avatar
Oh ok , I didn't know the story apparently I missed that part
Old 06-03-2020, 03:11 PM   #74
TrackClub
TrackClub's Avatar
Haha NP GMG had major issues because of incorrectly mounted tires and what looks like a blower leak...
Very unlucky for a first day out :(
BTW a nice lap man! Congrats on a new PB! Seems to me you've changed your driving style a bit including feeling the tire with more active steering corrections too.
Great stuff!
What was the ambient and what did your GS friend run?
What seems weird to me that even with rotations the tires still look very different L vs R. Any idea why?
Cheers!
Old 06-03-2020, 05:39 PM   #75
OhioRiderAaron
Drives: BMW M3
Really nice lap glam, almost to the point of being a little boring (in a good way lol). I saw oozk's video with the Z06 as well, only a few seconds behind him!
OhioRiderAaron is offline   Reply With Quote
Old 06-04-2020, 09:57 AM   #76
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
driver side
and Passenger side
Congrats Cem, but regarding the cording, this still looks like the rubber is just delaminating on the edges from overheating judging by the amount of rubber left on the center of the tire. Nothing against you and this seems very common, but i think this is a very big reason that keeps a lot of us from just blowing crazy money on these G3Rs. If you can swing it more power to you, but I bet with some cool down laps mixed into your sessions you may not have this delamination problem.
I still have my $100 used set of 4-285/35/20 G3Rs to try at some point this year. Not sure whether i should mount them inside out or not as the 5th gen guy did 2 days on them so they have some outside wear. I'll try to remember to get a pic of them.
Old 06-04-2020, 01:15 PM   #77
TrackClub
TrackClub's Avatar
I'd agree: something wonky is going on here as no other pix of corded G3Rs show delamination. So either the alignment has walked significantly, or the G bar is too stiff and causes too quick a weight transfer overheating the tire? Fyi that's what happened to me when i upgraded the bars on my C5Z a few yrs back. An outside F NT01 was gone completely in a *single* day. Food for thought in any case. Cheers!
Old 06-04-2020, 02:21 PM   #78
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
this issue is a fairly common issue with G3R on track, i have experienced it myself. I dont think its alignment related. There definitely is an issue with inside- inside (literally the 1/4th inch of the inside) edge wear with the way the ZL1/E runs and the tire wears. I think GY should should do some R&D here and address this issue.
Zl1+911 is offline   Reply With Quote
Old 06-04-2020, 02:46 PM   #79
TrackClub
TrackClub's Avatar
You mean cording (common) or delamination (never seen it before). Cheers!
Old 06-04-2020, 03:09 PM   #80
Zl1+911
i am not sure of the technical term here, so pardon my ignorance, but the first picture above and the inside wear is what i have observed - it seems to be something very specific impacting the tire inside on its edge and i have also seen that in some other threads prior.
Old 06-04-2020, 05:23 PM   #81
glamcem
glamcem's Avatar
Great stuff!
Cheers!
Thank you! Ambient temps are about 5 degrees lower than the last time.
Friend with the GS was faster that day but only slightly I guess, I was able to follow him for 3-4 for laps without losing him from sight. He wasn't timing.
I believe he ran 1:48ish with R7s in the past though.
I called my mechanic and hopefully we can check the alignment soon. Will keep you posted
Thanks!
Old 06-04-2020, 05:26 PM   #82
glamcem
glamcem's Avatar
Thanks ! I think you're right, I listened to your advice at my last event at the ORP and tried a few cool down laps so hopefully it will help a bit . At the Ridge , however, we have no option for a cool down lap as it's very hard to get a good clean lap without any traffic and sessions are technically 16 min long (unless there's no interruption with oil spill, crash etc) .. so we have to be very strategic there :/
Old 06-04-2020, 05:33 PM   #83
glamcem
glamcem's Avatar
Not surprised actually, it sounds counter-intuitive since one could think (like me lol), having more roll resistance (ARBs) and more camber should help with outer edges since body roll is limited and so the stress on the outer edges.
However, by getting rid of body roll it's much easier to reach the limits of the tires since we get faster and faster also means more heat generated on the tires. I think delamination is proof to that. My only concern is in both times it happened on the Front driver side, even though I drove them with different configuration .. I cannot wait to see the alignment numbers hopefully it will solve the mystery
Typically softer compound tires always give up faster, that's the tax of using a more aggressive compound/ faster tires. I highly doubt R7s would last any longer than these, RRs on the other hand seem like they will last longer but they're a bit slower (not too much Though). I will try RRs again on a better day and when they go bad, I wanna try Hankook Z214s ..but I keep buying SC3Rs since the extra grip is addicting we'll see about that
Old 06-05-2020, 01:54 AM   #84
TrackClub
TrackClub's Avatar
Yep agree with your response to me. The balance gets much finer and the tire loads up much faster. Yet i didnt see you overdrive, so...
Hope it is just alignment. Cheers!
