Old 12-06-2020, 09:53 AM   #71
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Originally Posted by supercab78 View Post
Red Loctite ; Does high heat melt it, then take if off as usual ?
It might, but it also probably melts the seals and grease in your hub.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 12-06-2020, 10:46 AM   #72
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Had the same issue with my Z06, I thought I had a huge problem and thats all it was
pauly1119 is offline   Reply With Quote
Old 12-13-2020, 01:05 PM   #73
KMPrenger
KMPrenger's Avatar
So pulled my wheels off today to check the axle nuts on my car. I also checked the retainer bolts due to this thread (https://www.camaro6.com/forums/showthread.php?t=499904). Everything seems fine. The nuts on my car are crimped into the groove in the axle. Mine also has blue, pink, and white paint markings. I think there was one other person in this thread that said theirs was the same. So I think I'm good to go.
My car is a 2016 SS. Very early build... Was in the 2nd or third build week for the 6th gen. It was one of many cars held back for some reason(s) and checked over before they would release it for transportation. To this day I have no idea what they did to these cars, if anything. Wonder if this was part of that? My axle retainer bolts also have other markings on them that I'm not seeing on other pictures on another thread.
Old 12-13-2020, 01:18 PM   #74
cdb95z28
cdb95z28's Avatar
Your nuts aren't going anywhere. This is how the Gen5 was done. Once they are "staked" they are held.
"KEEP THE FAITH"-Fbodfather
Old 12-13-2020, 02:23 PM   #75
KMPrenger
KMPrenger's Avatar
I wonder why mine are different than many others in this thread, especially it being a very early build? Don't get me wrong, I'm happy they are this way.
Old 12-13-2020, 11:41 PM   #76
cdb95z28
cdb95z28's Avatar
Not sure, cost cutting measure, who knows? Seems the nuts that can't be staked are more trouble in the long run.
Old 12-26-2020, 04:11 PM   #77
SHRFT
SHRFT's Avatar
Drives: 2017 Camaro 2ss 50 aniverssary vert
Originally Posted by appleman22 View Post
No sir, pretty sure the manual quotes for 200 foot pounds of torque
Turns out 45 degrees of turn after an initial 57 foot pounds is about 200 ft pounds.
SHRFT is offline   Reply With Quote
Old 02-13-2021, 08:04 PM   #78
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
Finally got around to check the axle nuts. Set the torque wrench to 200 lb-ft and both sides were just fine.
The stake mark was gone. Thanks all for the info!
lcd550 is offline   Reply With Quote
