#71 |
![]() Drives: 2019 2SS 1LE Join Date: Apr 2020
#72 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
#73 |
So i just installed a DSX flex fuel kit and also got the i-dash to read ethanol. I have not got a tune yet but I'm i suppose to see the ethanol % at least? Or do I need the tune so it shows up on the gauge. I know I can't run E yet but I figured it will still show up.
#74 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
#75 |
#76 | |
So when the time comes and you do turn on the sensor you should be reading 15% or less this time of year running 93. Yeah it’s 40% when not installed correctly. https://www.camaro6.com/forums/showthread.php?t=538796 When I did my install I was anxious to get HPT loaded to make sure I didn’t plug into the wrong pin location.
#77 | |
#78 |
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
where did you guys tap into for switched 12v, finishing up AEM install... Thx
#79 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I know this is an old thread but I am planning on buying this Banks iDash SuperGauge and want to mount it in the defroster vent of my 2020 ZL1, how are you guys routing the cord down to the OBD plugin from the defroster vent? Is it pretty straight forward? Thanks for any help!
#80 |
Coming from that location in the dash I can’t say from experience if it’s a straight shot down to the OBD plug. However, I can say to just pop off the side cover, grab a flashlight and look up in that general area to see if there’s a path. There’s some sheet metal that you will need to fish the cord through but it’s not tedious or space limited.
Lethal video might help. https://m.youtube.com/watch?v=vUF98fULV00
#81 |
![]() Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
The Aeroforce gauge has a menu item called "controls" that allows you to run the IC pump by itself, the fan by itself at high or low speeds, or both at the same time. It's basically a cool down mode. This is done with ignition on/engine off. I use it all the time at the track to cool off the IC coolant and HE plus radiator and intake. It's one of the best features. I watch the MAT (not IAT) temp on my LT4 on the gauge and when it gets below 120 deg F I know I'm good. During the run I watch knock and MAT temps and a couple others and that's all I need to know that I'm not pulling timing due to heat.
#82 | |
Dyno Show Queen LOL
'I'm not sure the banks has a formula built in to it to take HG and convert to psi.. Under pressure I've tried the following.. Boost/vacuum absolute manifold pressure MAP sensor pressures
#83 |
Moderator
No problem reading boost on my iDash...
#84 | |
https://www.camaro6.com/forums/showp...6&postcount=49
