#71 | |
![]() ![]() Drives: 2017 Camaro 2SS - M6, NPP, MRC Join Date: Jan 2010
I agree with SnakeEyeSS, if you're going to "put the past behind us" to the point that the SS badge goes away, put an end to the Camaro name while you're at it. |
#72 | |
#73 |
#74 |
#75 |
![]() Drives: SEARCHING Join Date: Apr 2010
They should have Pininfarina style the next Camaro.
#76 |
The manual transmission was a part of the Camaro heritage and it’s going away because of better technology in the automatic, the same thing will happen to the large V8s , they will go away . Since most people don’t know how to shift their own gears it’s no big deal , but let’s see what happens when the V8s go away to smaller faster engines that are coming, and some even may be hybrids . I myself look forward to the future of Camaro , and with the new technology the heritage will live on another 50 years.
#77 |
#78 | |
![]() ![]() ![]() ![]() Drives: 66 Chevelle SS Join Date: Mar 2013
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
#79 | |
There's also the packaging issue - as has been argued with the Mustang faithful for years, smaller-displacement engines - including V8s - do not necessarily make for smaller physical dimensions - not as much of a problem in a truck or large SUV, but in a sports/pony/muscle car, that does create design and performance tradeoffs. The same is true for a 6 cylinder (almost certainly DOHC & twin turbocharged) you need to compact that enough to fit it under a hood low enough to maximize aerodynamics. To retire the V8, you need to create an alternative which is a significant improvement in all those regards, otherwise there's no point in doing so because you'll be spending huge amounts of money for R&D on a different engine merely as good as existing technology, while infuriating your core customer base. At present no such alternative has been developed at a price point where it's reasonable in the pony car segment. |
#80 | |
Price point will be an issue with the gen 7 and they won't be going down in price but i think they could offer new smaller engines with great results ,HP is not going to continue to go up in certain price points ,sooner or later it has to go the other way . What can keep going up is the performance of the car using technology , there is a huge difference in the GM-TH400 to the GM-A10 the engines are going the same way . If the gen 7 Camaro has a 455HP V6 it will out perform the 6th gen SS LT1 and bring new faces to Camaro . Camaro won't survive on the core base it has now it has to push into new technologie. The Camaro V8 buyers now are the smallest group , T4s and V6s are the bulk of sales , it just makes sense to give them more . |
#81 |
#82 | |
You're assuming a lot saying a V6 with equivalent power to the LT1 will outperform the V8. You might see a slight improvement around a track from a minor improvement in weight balance, but using the ATS-V and its engine as an example, how much gain do you really get there? 0.1 seconds faster to 60? The LT1 created a half second improvement over the LS3, so I'm not impressed (and the ATS-V engine has an extra 9 hp over the LT1, so it's not even exactly the same as what you're proposing). V8 buyers are the smallest group (not a new development), but that is and always has been overwhelmingly a matter of PRICE, not preference for 6 or 4 cylinders over 8 - be honest, how many people have you EVER heard of who'd say with a straight face that all other things being equal they'd take an I4 or V6 over a V8? And you're not giving those buyers more by offering them another sub-8 cylinder engine option but with a price tag that makes the LT1 seem like a bargain - they'll keep buying the base engines like they always have. A forced induction V6 is newer technology, for sure. But that doesn't automatically make it better technology by any stretch of the imagination. You seem to be taking it on faith that it must be so and therefore something to bring about as soon as possible, because you seem to only offer the old parental standby of "because I said so" as your supporting evidence, and that just won't cut it |
#83 | |
#84 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Ok just going to toss this out there. Forget the 3.6TT from the ATS-V. I don’t see GM putting a far more expensive engine in the Camaro that will perform no better than an LT1. I had this same discussion years ago with Target Juechter and that was basically his conclusion, except his challenge was trying to get better FE.
However, the replacement for the NA 3.6 L V6 in the CT5 is a 3.0 TT with the same 330ish HP BUT 400 lbft of torque. That could be a nice addition to the middle ground and certainly be more than competitive with the Mustang.
