#71 |
Maros_eat_Stangs
Drives: 2010 Blk/Blk 2SS/RS M6 Polished 20s Join Date: Oct 2009
Any Magnum round .357 and up will do the job. I personally use a S&W .44 mag and love it. The .44 Mag is the best balance of knockdown power and followup shot accuracy IMO. All of the magnums can be used for hunting but thats the 8" barrel and up variety. You need a short barrel w/ built in compensator to reduce muzzle climb and a Crimson Trace Laser Grip isn't a bad idea (for fast target acquisition). Hornady is a good ammo company. They don't offer a FMJ but a .44 mag hollow point will have enough penetration and do enough damage to bring down a bear. You gotta hit him in the right spots though (head or chest) don't wing him. You do have a better chance of being struck by lightning and most bears will run if they see or hear you coming but there is always a risk. Better to be prepared. If the bear is starving your gonna look like a meal and smell like trout LOL.
'95 Camaro V6 Purple/Grey
'96 Camaro RS V6 Blk/Blk '97 Camaro Z28 V8 Red/Red&Blk '99 Trans Am V8 Red/Blk |
#72 | |
BOOOOOM MF'R!!
Drives: to Chipotle daily Join Date: May 2009
#73 |
A ***'s Headache
Drives: Everything Join Date: Aug 2009
Ok after alot of research I have found the right answer.. All you need really is a knife. No seriously. When you go fly fishing, just take Junkie with you and a knife. When you see the bear, stab Junkie in the leg. He'll start yelling and jumping around, drawing the bears attention, and you slowly walk to the truck climb in and drive off. Remember you don't have to outrun the bear, just the slowest runner.
#74 | |
BOOOOOM MF'R!!
#75 | |
![]() ![]() ![]() ![]() ![]() Drives: Dodge Ram Megacab & Cobalt SS Join Date: Sep 2008
#76 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
Ruger Alaskan, perfect backpackin wheelgun.
Nothing smaller then .44mag either. I love S&W, but if you get one, do the lock delete thing. Horror stories abound about that gizmo locking up on the big bores after the first shot and making the gun a paperweight. |
#77 |
Maros_eat_Stangs
Not true. FMJ's are made for max penetration while HP's are made for damage. There are really 2 kinds of HP's. One type (more lead) is made to mushroom bigger and faster as it penetrates thus doing massive damage on the way in and transferring more kinetic energy to the target (knockdown power). The other type (more coppernickel or other harder metal) is made to splinter upon entry going in multiple directions (shotgun effect) causing massive damage and transferring more kinetic energy to the target. Both cause massive and quick bleed-outs. The FMJ's only slightly deform as they go completely thru the target and rely more on compression to transfer energy. Since they pass thru the target with little resistance they don't transfer as much kinetic energy. FMJ's are more ideally suited for long distance situations where good penetration is needed. Don't get me wrong FMJ's cause alot of damage on their way through the target but I pictured his situation as him being charged at close range by one pissed off bear. In that case penetration isn't an issue. Both types are excellent rounds but for different situations.
#78 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
The thing is that bears have tons of fat,muscle, thick skin and bones to get through, so you would not want a hollow point, you want the most penetration possible to take it down. FMJ FTW
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
#79 |
![]() ![]() Drives: 2010 Aqua blue 2SS/RS M6 Join Date: Jul 2009
Ok, I know someone already said this but I checked with my gun supplier and he said with out a doubt go with the S&W 500 .50, It is a "bear Rated" gun it even comes with a video to show how to kill a bear with it. However; it is a gun to be revered, he said he shot this gun twice and that was enough for him almost broke his wrist. I watched myth busters last night and happened to have a story of several guys losing a thumb when firing this revolver. They proved it COULD happen because of placement of thumb too close to revolver when it is fired. Also it has a bad ass kick, the guy firing it on T.V almost hit himself in the forhead with it! So, with that said this is a "bear rated" hand gun that you wanted. Be careful!
#80 |
![]() ![]() ![]() Drives: 2010 2SS/RS Black Join Date: Mar 2009
I carried a 6" S&W 629 Classic Hunter in Alaska as my anti-bear gun.
Used 300 grain jacketed rounds in it, but any heavy-duty .44 magnum or larger pistol with heavy-duty bullets should do the trick. You may want to consider NOT going overboard with a REALLY large handgun though, it'll get uncomfortable very quickly and may cause you not to carry it when you need it.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure! Folding@home Stanford's Research DC Program. |
#81 | |||
![]() ![]() Drives: 2010 Camaro 2SS/RS, VR, PW, WR Join Date: Jul 2009
![]() Quote:
Its not hard to find pictures of revolver gas jet injuries if you try. Nasty stuff. When I got my wife her .357, I only had to show her once and she never tried to grip around the cylinder again. With a proper grip, the compensated models don't have a just a huge muzzle flip. I'd describe it as a big push rather than a sharp kick. I actually find them easier to shoot than a .44mag and much much easier to shoot than a .454casull....
2010 2SS/RS, M6,VR,White Rally's,Polished Wheels
Mods: skip shift eliminator (hey everybody's gotta start somewhere )crappily painted engine cover... |
#82 | |
As a side note I carry the SW .357/.38 PD hammerless revolver for my concealed weapon in my purse, the .357 will hurt me (gun only weights 12 oz.empty!)so I use the .38 instead. My hsuband has the same plus laser sight he uses the .357 in his. All good guns! |
#83 |
Guest
Don't have time to read all post. Maybe it was already said. If you don't buy a smith and wesson .357 your crazy. Best all around hand gun made. I you don't think that is enough(which it is)go with the .44cal.
#84 |
Missing my SS :(
Drives: 2012 Ford Explorer [ :( ] Join Date: Nov 2009
You can always buy the trojan armor suit. It was tested on a grizzlie bear and has two magnetic strips for what ever gun you use.
| Thread | Thread Starter | Forum | Replies | Last Post |
| question about camaro affordability | ChevyCowboy | Canada | 8 | 01-08-2009 06:02 AM |
| Exhaust question | ElManny | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 01-02-2009 09:41 PM |
| 2SS exhaust, 2 part question. HELP!! | 2SS is mine!! | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 11-16-2008 06:51 PM |
| IRS question | 454lsxss | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 08-30-2008 09:06 PM |
| Noob Camaro Question | goose7919 | 5th Gen Camaro SS LS LT General Discussions | 13 | 09-23-2007 08:26 PM |
