#71 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#72 | |
#73 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Convertibles without the eLSD still have the bog. You can hope in one hand and crap in the other.......see which one fills up first.
#74 |
![]() Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
When we were pushing all that data to Travis in 2017, we felt that it was part of the algorithms associated with Torque Management. But we did hypothesize eLSD could be a factor. See his threads covering this for reference...hope it helps!
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
#75 |
![]() Drives: 2019 ZL1 1LE Join Date: Jan 2019
Sorry if I missed it, but do new vehicles have this calibration built-in from the factory?
#76 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Anyone done it yet? Noticed anything?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#77 |
And so did my '16 standard SS M6. And there it is not the ECU either.
#78 |
![]() Drives: 2017 Red Hot ZL1 Join Date: May 2015
I'm sure it's going to take a moment to gather data but for those of us with a tune I'd like to see if this is a worthwhile "update".
#79 |
![]() Drives: 2017 ZL1 A10 Join Date: Nov 2009
This Friday I'll bring my car back into work and get the programming done. Also going to the track that night too since it will be in the low 50s, high 40s. About the same temps and DA I ran my 11.2 this past November. If it 60' in the 1.6s, I would be pretty happy.
#80 |
Sweet! please keep us updated
#81 |
![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
Any Updates?
#82 |
Looking forward to your results.
#83 |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
I originally thought the eLSD had something to do with the bogging problem, but I quickly abandoned that theory. By the time I had finished researching, I was convinced there were two primary causes.
1. A design flaw in the traction control logic 2. Slow recovery from torque management The traction control system uses a percentage to quantify the wheel slip. At really low speeds, a very small amount of slip can result in a very high wheel slip percentage. This is where I believe the algorithms were falling short and causing most of the drive-ability/launching issues. As the clutch is released, if the tires slip even a little, the wheel slip percentage spikes which triggers the ECM to basically kill the engine to regain traction. Of course, if the front tires are turning at 0.5 MPH and the rear tires are turning at 2 MPH, that's only 1.5 MPH of slip which isn't really a problem. However, as a percentage, that's 400% which was causing the traction control system to respond. I confirmed this problem with data logging and there is no doubt in my mind these cars have an issue. I was told that GM contracted the traction control system for this vehicle (from Bosch maybe?). Since it wasn't something they had developed in-house, this complicated the process for getting a fix developed. Ultimately, some bean counter decided it wasn't worth it so they just took the position that their customers simply needed more practice with the clutch... which is a lot like saying a person needs more practice in order to make money playing video poker. It's impossible to beat the software. On the off chance you get a great start to a launch, you've maximized the stresses on the driveline. The additional stresses on the driveline would just increase the counter response from the torque management system. Of course, the driveline protections are nice, but I always felt like the biggest problem was how slowly the car would recover. It seemed like it took forever for the engine to work its way back up to its full power potential. I doubt anything eLSD related would fix the problems that I investigated, but there's always a chance other problems could be addressed as part of this update. I'm glad Chevrolet is at least giving us something to try, and I'm hopeful we'll see some measurable improvements in 60' times. Personally, I've moved on from trying to launch the car and I won't be installing the update. I've since been enjoying the car on the road course where I feel it really shines. |
#84 | |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
FWIW, your insights and research are always appreciated.
2018 ZL1 1LE sw/PDR
