Old 03-25-2019, 03:40 PM   #71
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Originally Posted by Move_Over View Post
GarageTherapy has one of my thermal imagers for a few days and will be doing some data collection at VIR this week.
I hope they actually can obtain good data.
Check this video https://youtu.be/nfZNdzi3J10
Rotor will heat and cool so quickly taking a "snap shot" at the end of a track session for example is not going to yield any good data.
Still in for results but very curious how they will be doing this comparison.
thescreensavers is offline   Reply With Quote
Old 03-25-2019, 03:48 PM   #72
ScaryFatKidGT
Drives: NGM SS 1LE
Originally Posted by RUQWIKR View Post
Ask them why they necked the 3D-printed duct adapters down 15% vs. the cross-section of the stock duct outlet. No thanks. Their design may help more than stock with the concentration of cooling air, but, I’ll go a different design route if I do something similar.
I think they should either make something to cover it, vs going inside or, how hard is it to get in and replace that factory outlet?
Also can it be confirmed this duct is only for passing air to the brake cooling deflector and cooling the brakes and not anything else like the hub/caliper or for fender air pressure/aero dynamics?
ScaryFatKidGT is offline   Reply With Quote
Old 05-14-2019, 06:31 AM   #73
Rutkowski
Rutkowski's Avatar
Drives: 2017 SS 1LE Hyper Blue
For some reason I cannot find the duct kit on the KNS page, and the link only opens the home page itself. Does someone have an item number to search for? Much appreciated
Rutkowski is offline   Reply With Quote
Old 05-14-2019, 09:16 AM   #74
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I believe they posted on Facebook awhile ago that their 3D printer was broken. Haven't seen an update, but that's probably why they don't show the kit on their website.
Old 05-14-2019, 09:31 AM   #75
Move_Over
Drives: ISO ss 1le
Yeah spoke with Jordan and his 3d printer is down, so they said another 3 weeks or so before their next batch
Move_Over is offline   Reply With Quote
Old 05-14-2019, 10:10 AM   #76
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I don't see it on KNS's website anymore either, but it's on Garage Therapy's website: https://garagetherapync.com/product/1
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-14-2019, 06:02 PM   #77
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
The kit just barely fits in the SS 1LE. Has less of a finger clearance at full power on lock when on the ground. This is on a stock setup. We did get it where the tire wouldn't rub by using extra tie wraps and ran it over a track weekend on 2 cars without any issues. Didn't take any temp measurements and was running with track pads instead of stock
Old 05-17-2019, 03:22 PM   #78
carguy55
carguy55's Avatar
We thought we didn't have a rub issue but after I did a close inspection there is a rub issue. Evaluating the options
Old 05-18-2019, 01:49 PM   #79
Move_Over
Drives: ISO ss 1le
Most aftermarket brake kits will rub at full lock on any car. My e46 kit (which was 2x the cost of this kit) rubbed like crazy at full lock. You shouldn’t be at full lock on a road course anyhow, so just watch the full lock turns in the paddock.
Old 06-25-2019, 02:05 AM   #80
Q8yZL1
Q8yZL1's Avatar
Drives: 2017 ZL1 (M6)
can't wait for the new batch! i'm just a click away from buying.
Q8yZL1 is offline   Reply With Quote
Old 06-25-2019, 07:06 PM   #81
carguy55
carguy55's Avatar
The brake duct hose is a consumable on the SS, maybe not on the ZL1. Avoiding full lock on track is a no brainer, but it does happen occasionally off track. I've worked on it to minimize any rub
Old 06-26-2019, 08:31 AM   #82
TheRealJA105
Drives: 2013 C6Z06
Why would it be any different on a ZL1? Same suspension, tires, and rim offset...
Maybe the ZLE has more room,but it also has wider rims/tires.
Old 10-26-2019, 11:44 AM   #83
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Garage Therapy Brake Duct Kit
They are no longer offering this kit. Anybody know where to go for a good brake duct kit?
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 10-26-2019, 11:53 AM   #84
carguy55
carguy55's Avatar
I sold my duct kit and switched to the SS track deflector and splash shield kit GM 84433357. Also now using Ti shims
