10-27-2018, 03:24 PM | #71 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Sounds like good advice oldman- I also bought a new inch/lb wrench (not from Harbor Freight!) just for this job, but I will still be listening to my hands and head when snugging everything down.
Thanks for your input- |
10-28-2018, 02:53 PM | #72 |
Matt you mentioned I won't be re-using the metal shim/gasket that came with the stock TB. The MSD comes with its own metal and adhesive backed rubber gasket for a TB to mount on their IM.
I'm guessing I am to use these pieces when assembling the 95mm to the MSD, correct? I don't remember seeing any mention of these parts in the instructions, so what order am I looking for? Stick the rubber gasket to the TB, then the metal gasket on the MSD side? That's just my best guess- please advise. Thanks! |
10-28-2018, 03:56 PM | #73 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
What do you think the gains would be on a Procharger Stage 2 car? Significant like the OP or less so?
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
10-28-2018, 06:30 PM | #74 |
Drives: SS 6 speed of course Join Date: Jan 2016
Think it will be much less, usually pumping losses in the intake are easy to work around by upping the boost a tad. Say it is worth less than 1 PSI lof boost, the smallest pulley changes are 2 PSI.
10-29-2018, 07:15 AM | #75 | |
Drives: All GM Performance Join Date: Jul 2011
10-29-2018, 07:18 AM | #76 |
The reply about pumping loss is correct. I would not use the MSD under boost because I think it would leak. I also never liked using a FAST manifold because of that issue.
10-29-2018, 07:48 AM | #77 | |
Here is my last one: I know you said the RotoFab air inlet tube would stretch over the 95mm TB, I've got the GM cai. Will it stretch over also (maybe with a little hair dryer heat to warm it up)? Thanks again! |
10-29-2018, 09:25 AM | #78 |
It will stretch right over. You shouldn't need any heat to make it go on.
10-29-2018, 09:51 AM | #79 |
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC Join Date: Mar 2018
Looking forward to impressions
10-29-2018, 02:34 PM | #80 |
Me too!
11-03-2018, 02:45 PM | #81 |
Started under way with this install Matt, but I can't get that brake booster line to disconnect at the "T" under the A/C line.
What's the secret for this connection? Thanks in advance! Uhmm.. never mind, I got it. But I'm sure I'll be back with something else, LOL! Last edited by Ventmaster; 11-03-2018 at 03:13 PM. |
11-05-2018, 10:55 AM | #82 |
Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
With such a flat powerband up top to these like to be revved to 7 or is the fall back from a 6500 fine?
I like my woman like my milk shakes, THICK!!!!
11-05-2018, 12:32 PM | #83 |
Drives: 2018 2ss 1le Join Date: Jan 2018
has any one used the weapon x ported 95 on stock ported i/m and their adapter plate...
I also have rot fab dry and a tune if so did you go from 87 ported to 95 or stock to 95 and what were you're impressions.. I don't know if I should start another thread for this or not.. I don't want to go msd for a couple of reasons... low end loss and possibility of pro charger in the future |
11-05-2018, 07:05 PM | #84 |
Well she's on! Gonna wait for a first impressions drive in the morning...
Had a few "gee, no one has mentioned that" moments during the install, but overall it was pretty straight forward. And BTW- if anyone is looking to pick up a stock IM or TB from a 2017 SS with < 9K miles for a good price, drop me a PM! 1st impressions tomorrow, I promise... got a stretch of old highway with 3 jurisdictions covering it- IOW, nobody! Good times! |
