Old 12-04-2018, 03:06 PM   #71
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
Mspeed,
Thank you so much for taking the time to post your trailering adventure! The only question I have after reading the whole thread is, what was the bolt pattern for the trailer hubs? I doubt that it would be the case, but would be amazing if you could specify a 5x120 setup so that say a winter set of tires could be used on the trailer.
JD
JD_ is offline   Reply With Quote
Old 12-04-2018, 05:14 PM   #72
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
5 x 4.5
I had to use a 2" 5x4.5 x 5x4.5 wheel adaptor to fit the SSR rims.
http://www.performance-world.com/Whe...s-p/520116.htm
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 12-04-2018, 05:26 PM   #73
JD_
JD_'s Avatar
Originally Posted by mspeed1LE View Post
5 x 4.5
so essentially any wheel that will fit a late model mustang, given the correct offset... I will never get away from the mustang stuff
Old 12-05-2018, 06:38 AM   #74
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Just tell yourself that the Ford stuff is getting towed by a Chevy and you'll be fine
Norm
Old 12-05-2018, 06:58 AM   #75
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
That's funny Norm, and Happy Holiday's! I put 17x7 215/65/17's on my Mercury Villager as they would fit the Nissan Quest looking Villager. My neighbor's were amazed, ha.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
Old 05-02-2019, 09:47 PM   #76
mspeed1LE
mspeed1LE's Avatar
Finally did a 200 mile round trip maiden voyage with the trailer. Didn't even know it was there without looking in the side mirrors! LOL!
2005 NISSAN TITAN
Old 05-02-2019, 10:29 PM   #77
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Success... Well done for your situation. Lots more trips to come I'm sure with that tow vehicle biting at the bit
driven2exceSS is offline   Reply With Quote
Old 05-03-2019, 10:37 AM   #78
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Looks great! Having towed for years (and years), the amount of increasing and increasingly distracted drivers running into my trailer is the main worry now. I’m looking into one of these, too, but think I might go overboard on the trailer lighting just to give those distracted a bit more chance to see it especially at night.
Can you take a night shot or two with the trailer lights on? Thanks.
RUQWIKR is offline   Reply With Quote
Old 05-03-2019, 05:59 PM   #79
mspeed1LE
mspeed1LE's Avatar
I'll try to remember next time I have it hooked up and stay awake late enough! 🤣
2005 NISSAN TITAN
Old 11-21-2019, 11:46 PM   #80
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
Bump.. OP, how did you enjoy this setup? Anything you have learned by using it?
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Camaro ZL1 1LE (Red Hot)
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 11-22-2019, 08:27 AM   #81
LJenkins1LE
Drives: 2018 1SS 1LE
I have their mid-tier trailer, and I have had the same success as the OP. I travel about 500 miles round trip to DEs (4 total so far), and it tows very well. Don’t know about OP but I have hard backing it up because I can’t see it very well.
2018 Summit White 1SS 1LE, PDR, Black Bow Ties
LJenkins1LE is offline   Reply With Quote
Old 11-22-2019, 03:11 PM   #82
carguy55
carguy55's Avatar
Then there's those guys that just cram 4 race tires in the car
Old 11-22-2019, 05:09 PM   #83
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
You can get five if you put one in the front seat!
Towed last weekend for the first time in a long time (enclosed trailer). I have TPMS sensors with pressure and temperature readouts on all six tires (four on trailer plus two spares). Dill makes the set up for up to ten or twelve tires, and it uses bolt in OEM style sensors with an antenna built into each [versus screwing onto the end of a rubber pull through valve stem]. It has a small backlit display. Probably have versions that work on your phone. You might check into one for your tire trailers. Nice piece of mind. Won't help obviously with a sudden delamination type tire failure on the trailer.
Old 11-27-2019, 08:21 PM   #84
mspeed1LE
mspeed1LE's Avatar
Not with a cage! Hahaha!
2005 NISSAN TITAN
