Old 04-03-2019, 01:44 PM   #71
Move_Over
Drives: ISO ss 1le
The poke isn’t too bad with some camber dialed in anyway
Move_Over is offline   Reply With Quote
Old 04-03-2019, 01:47 PM   #72
Move_Over
Drives: ISO ss 1le
F’n A cotton sorry about the upside down photo.
Old 04-03-2019, 02:16 PM   #73
Bluebarchetta
Drives: 2017 SS 1LE
Thanks for the Pic anyway, can’t believe this forum has such a problem with iPhone and iPad.
2 questions
1. Is that the +22 with 305’s squared? tried zoom, but couldn’t read sidewall
2. Is your decision (and anyone else for that matter) running the EC7 vs SM10 strictly a cost differential issue? Sounds stupid, but after years of tracking, I tend to look at ease of brake dust removal. Not concerned about cosmetics, just keeping corrosive pad material off. Wheels get enough abuse as it is
Bluebarchetta is offline   Reply With Quote
Old 04-03-2019, 02:57 PM   #74
Move_Over
Drives: ISO ss 1le
2 questions
Hi, yes it’s a 305/30/19 setup.
For the 19” I really liked the EC7, always have loved that wheel. But in my 18” setup i went with an SM10 after seeing them on mustangs/camaros.
Old 04-03-2019, 03:08 PM   #75
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Originally Posted by FNxR3DNECK View Post
^^^What he said^^^
I didn't realize that the offset was 35 on the "Camaro" 19x10.5s. I have to agree 100% that you would be better off with the "BMW" ones that are 22 offset. The rear poke is negligible, and personally I think it gives the car an even better looking stance with the slight poke in the rear.
Tough I agree with Alex about running spacer not being as "scary/sketchy" as a lot of people make it out to be, I'd rather run the hub rings on the BMW spec wheels and a 5mm spacer than no hub ring and a 20mm space on the Camaro spec wheels.
I really don't understand why people would have voted for 35 offset on the square setup.
Also as Provoste said somewhere in here the "poke" in the rear widens the track widths and makes it more stable and the rear feels absolutely planted!
I have been waiting for the release for Camaro specific and have to say i am disappointed by the offset choices offered..i guess the BMW set is still the best option...
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 04-03-2019, 03:10 PM   #76
pbsinternet1le
Seems to me like they should have made a 17et offset to solve that issue..
2017 1LE Hyper Blue
Old 04-05-2019, 10:51 AM   #77
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I asked Apex why they didn't have the ET22 in the group by. Answer was:
To run a rotatable 305 square setup, you will want to use our 19x10.5" ET35 wheel with extended studs and a spacer up front on your SS 1LE. 19x10.5" ET22, while it does fit up front with less spacer than the ET35, pokes out substantially in the rear. 19x10.5" ET35 actually fits the rear of the vehicle, and since both offsets require a front spacer, ET35 is the way to go.
Old 04-05-2019, 11:03 AM   #78
carguy55
carguy55's Avatar
Since you have to run spacers no matter what, you can always get custom spacers made to avoid having to use rings on the BMW wheels.
For example custom 5mm spacers from these guys are about $35 each
http://www.motorsport-tech.com/wheel_spacers.html
Old 04-05-2019, 11:46 AM   #79
Move_Over
Drives: ISO ss 1le
ET17 would be pretty pokey in the rear. Mexiflush!
Old 04-05-2019, 07:09 PM   #80
pbsinternet1le
Aye carumba!
2017 1LE Hyper Blue
Old 04-06-2019, 07:23 PM   #81
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
I don’t think Apex fully realizes how agressive OE offsets were from GM. The 10.5 et22 rear is no more aggressive than the ‘12 wide ZL1 1LE. Remember, the ZL1 has the same rear quarters an an SS, only the front fenders are wider. The 10.5 with et22 on the rear is a “flush” fit, with only -1.7 rear camber. It looks perfect if you ask me. And YES, wider rear track only aids stability.
Provoste is offline   Reply With Quote
Old 04-07-2019, 08:30 AM   #82
pbsinternet1le
For a track use square setup would a 17 et be perfect? Seems like the et 22 with rings and 5mm spacer is still the best choice? No?
2017 1LE Hyper Blue
Old 04-10-2019, 07:29 PM   #83
Chevy1LE
Chevy1LE's Avatar
Drives: 2019 Camaro SS 1LE
Seeing a lot of pictures of cars on track with MRR wheels. They seem to make a direct knock off of the OEM 1LE wheels. Can anyone comment on the quality/durability in using them for track?
Chevy1LE is offline   Reply With Quote
Old 04-11-2019, 11:48 AM   #84
Jimbeau11
Jimbeau11's Avatar
Drives: '18 Black SS 1LE; '01 Corvette Z06
No personal experience but multiple comments in various FB track-focused Camaro groups about these wheels getting bent at the track.
Jimbeau11 is offline   Reply With Quote
