Old 05-06-2020, 10:05 PM   #71
Cleancoupe
Drives: 18 ZL1 1LE
Question on the TTY bolts on the rear. Is it just the bolts that need to be replaced or nuts and washers as well? I’ve read through a million post already on this and I’m still confused. Sorry to beat a dead horse. Are you local sourcing the parts through your dealer or online?
Cleancoupe is offline   Reply With Quote
Old 05-07-2020, 07:08 AM   #72
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
Anybody know if the blue strut hat can be replaced with a conventional camber plate? Sure would make adjustments a lot easier than using the strut bolts. I did mine yesterday, and found it really tedious trying to make small adjustments. Vorshlag shows one on their website for non-MR, but I don’t think it’s for the ZLE struts. Need to give them a call.
m3bs is offline   Reply With Quote
Old 05-07-2020, 07:58 AM   #73
Exactly why I posted this for the tedious adjustments.
It's a great way to get another hand on it to move around.
Old 05-07-2020, 08:07 AM   #74
m3bs
m3bs's Avatar
Rotating the hats was easy enough. It was trying to make a 0.2 degree change with the strut bolts that was a pain.
I’m probably just getting frustrated due to lack of track time.......
Old 05-07-2020, 09:46 PM   #75
I didn't need the extra handle to rotate, but rather make the small moves to get the bolts to lineup.
We may be talking about different things though.
Old 05-07-2020, 10:16 PM   #76
m3bs
m3bs's Avatar
Perhaps so. After I rotated the hats I was at 3.0 left and 2.5 degrees on the right side. Final adjustments had to be made using the strut bolts to get to 2.7.
Old 05-19-2020, 12:01 PM   #77
modernbeat
Jason McDaniel
modernbeat's Avatar
Drives: Racecar
I received a request about this strut and Vorshlag plates. It's not possible.
The Multimatic struts have a unique ball on the top of the strut, that makes it part of an integrated spherical joint. We can't remove that ball to substitute a standard spherical bearing.
Take a look at this article in Car and Driver.
https://www.caranddriver.com/news/a1...l-its-secrets/
The ball labeled "007" in this cutaway causes the issue with trying to adapt any other top mount to these struts.
modernbeat is offline   Reply With Quote
