#71 |
![]() Drives: 2018 2 SS Redline Join Date: Sep 2017
So update on what had happened to my car I took it to the dealer at the beginning of January I haven't really updated this much only because of time not because any lawyers or anything like that they told me that it was caused because of a manufacturer defect in the valve and it caused a rod to blow and the rod blew a piston and then the piston blew the the block and there was a huge hole in the block and that was the cause of everything they took care of my car and replaced the motor there was like 25k+ worth of damage but they got it all fix and I will be picking up my car on Monday
#72 |
![]() Drives: 2017 2SS Join Date: Apr 2016
Wow! What a mess. Glad they got it fixed up!
It seems you don't have time for periods and full sentences either.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
#73 |
Glad to hear it was taken care of.
#74 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Also not to be "that guy" but.. how does a valve cause a rod to malfunction? I'm failing to see the correlation there. The Rod is attached between the crank and the piston but a valve in no way touches it UNLESS the valve came in too deep somehow and the piston smacked it (which would indeed destroy your piston) causing your rod to bend due to the unexpected stress which may have cause the rod to backfire toward the crank and literally shoot out the bottom of the motor (explaining the loss of oil) ... but man... thats something there. |
#75 | |
![]() Drives: 2017 50th Anniversary Join Date: Dec 2015
Drop a value into the cylinder and watch the fun begin. Had that happen on a race car years ago. Same thing happened. Bounced around the cylinder until it bend the rod and poked a nice hole in the side of an old school 010 SBC.. |
#76 |
![]() Drives: 2016 Mosaic Black 2SS, NPP, A8. Join Date: Jun 2016
Glad to hear that they are taking care of everything and you'll have your car back soon.
#77 |
![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
#78 |
Drives: SS Camaro Join Date: Sep 2017
Good to know
#79 | |
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
2018 6 Gen 2SS camaro Gets Destroyed
My dealer swears it needs 6. My other dealer said my old 2014 needed 5. 2017 Camaro 2SS
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
#80 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
