Old 06-14-2017, 06:50 PM   #71
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Cem-
You didn't use the new nuts included? They clearly had a locktite coating- they were taped to the top of the box. Thanks again for the info, easy swap at the track!
Old rotors still good spares, no cracks to any edges. New ones felt pretty amazing. Original rotors had 14 total days on track. 1 full set of DTC 60's, 3/4 set of OE pads. 90% track use.
Old versus New
Provoste is offline   Reply With Quote
Old 06-14-2017, 06:54 PM   #72
TrackClub
TrackClub's Avatar
Very impressed how long OEM components last on this car given its weight. 14 days is awesome, especially given your pace Provoste!
Old 06-14-2017, 06:57 PM   #73
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I know :/ ORP is like a stress test on tires and brakes. I've looked at the bottom of the car to see if I could do something to improve the factory ducting It may be beneficial to find some sort of plastic ducting (like rectangular shape) to feed more air. I do my best to avoid the ducting hoses as I ran into so many rubbing issues with them in the past
glamcem is offline   Reply With Quote
Old 06-14-2017, 07:05 PM   #74
glamcem
glamcem's Avatar
Originally Posted by Provoste View Post
Cem-
Old versus New
You're welcome.
I did not, I've seen the nuts included in the box but wanted to use the OEM nuts to match with OEM bolts. They also didn't easily become loose when I was untightened them.
14 days out of the stockers is amazing for sure. My rotors after 6 events definitely look better but cracks are visible. Did you get a chance to take a look at the temp paints on the rotors?
Old 06-14-2017, 07:15 PM   #75
Provoste
Provoste's Avatar
Originally Posted by glamcem View Post
You're welcome.
Crap! Completely forgot. I was busy with two students at Mid Ohio, never thought to look when I hurily rotated tires at the track. BTW, I should get some brother of the year award.... my brother's 997 had an issue with a rear toe link, so I let him borrow the 1LE to run at Grattan (Michigan) this coming weekend! I already warned him he's prolly gonna sell the 997 sooner than later after having the Camaro over a track weekend.
Old 06-14-2017, 07:31 PM   #76
glamcem
glamcem's Avatar
No biggie you can even check them with the wheels on them. I've been putting the car in neutral and slightly move it between sessions. Supposedly it helps getting rid of the heat that is trapped in the caliper
I am very surprised with his decision on moving to 1LE from a 997 but it's glad to hear that. It sounds like we made a good decision. I personally never owned a Porsche since the ones that I want (GTs) are always expensive :/ Another benefit of having these cars is with the upcoming ZL1 1LE package we can even make this car more track focused with all OEM parts in the future (like suspension kit, aero, even GM head and cam package if it ever feels like it may use more power)
Old 06-16-2017, 06:16 AM   #77
SaphfireSS
Drives: 2017 Camaro 1LE SS
My rotors look about the same as Provost's does after 5 track days and a USCA outing with DTC-60 pads 1/3 wear and 90% on the stock pads. It's time for new rotors for sure. I was wondering if you switched to the ZL1 front clip could you do some better cooling efforts? Anyone know if someone has done this yet? I've seen a couple 6th gen SS's converted to ZL1 front clips.
SaphfireSS is offline   Reply With Quote
Old 06-19-2017, 02:45 PM   #78
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
I am going to ask another brake question: Is the clutch fluid reservoir and the brake fluid reservoir shared/linked? Another way of putting it, do I have to worry about anything but the brake system when I flush and fill the brake system. Thank you in advance.
Uncle Sam is offline   Reply With Quote
Old 06-19-2017, 02:56 PM   #79
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Both share the master cylinder reservoir.
2017 SS 1LE (sold)
Nightfall Gray
Th3Beast is offline   Reply With Quote
Old 06-19-2017, 04:04 PM   #80
Uncle Sam
Thanks.
My last car had a shared master cylinder and I usually did the clutch bleed at the same time but you had to watch carefully to keep the clutch line opening covered with fluid.
The Camaro with these 20 inch wheels looks like you can bleed the brakes without taking off the wheels, great for the track.
Old 07-03-2017, 08:08 PM   #81
glamcem
glamcem's Avatar
I figured it would be a good idea to give some update on the new rotors.
The new rotors feel and look pretty good after two events. I have to note the last two events were definitely warmer than the first two.
and here's how to OEM rotors looked after two events
Old 07-05-2017, 12:49 PM   #82
Provoste
Provoste's Avatar
Attachment 883100
some track data from the last event:
I placed some caliper temp stickers and noticed that they reached 430F degree after the event. I will place some stickers in a better place (facing to the wheels right above the pistons) for more accurate reading next time.
And here's how the thermal paint on rotors look like:
according to this guide the rotors temp reached somewhere between the yellow and white colors which means at around 570-580 C degree (about 1050F). As I mentioned before, this track is very abusive on the brakes and I will find a way to feed some air into the knuckle/rotors area to keep the temps in check
I didn't notice any fade issues and ST47/ST45 combo seems to be working just fine. The initial bite and modulation a bit different than the ST43s though
Looks like I never saw the rotor temps you have previously. This was after 2 days at Mid Ohio in the upper 80's to low 90's using Hawk DTC 60's and SRF fluid. I'm super pleased with the brakes.
Old 07-06-2017, 02:53 AM   #83
glamcem
glamcem's Avatar
Good to hear, I love them too
I think I wouldn't see those temps either if it was either Ridge, Pacific Raceways or PIR but ORP has always been the hardest on the brakes. Since it's club events with open track format I get tons of seat time on a single day at the ORP . Track layout also doesn't allow too much time to cool down the rotors. I'd say 2-3 days on other tracks is almost equal to 1 day at the ORP because of that.
Old 07-06-2017, 12:40 PM   #84
TrackClub
TrackClub's Avatar
Very pleased with the brakes as well after 3 days at an intermediate track with 2 4th gear straights followed by fairly slow corners and open track format. Still running everything stock except for fluids (wilwood racing dot3 for brakes). Incredible package right out of a box! PS very impressed with the tires too btw.
EDIT: Provoste you don't street DTC60s - correct?
