Old 07-26-2017, 01:16 AM   #71
Pyrobano
Pyrobano's Avatar
Drives: 2017 SS 1LE summit white
Just want to say, thanks to everyone for posting. Mine started making the clunk noice after hitting a pothole. Immediately I thought something had broken but found this thread and was given a peace of mind. I went straight to the drivers side swaybar link and sure enough it was loose. I will try JusticePete's suggestion. We don't live in a perfect world I guess.
K&N filter, Mishimoto cc, Vittesse tc, Secondary Cat Delete, Gorilla wheel locks, NPP.
Pyrobano is offline   Reply With Quote
Old 08-01-2017, 12:50 PM   #72
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
you're welcome
glamcem is offline   Reply With Quote
Old 08-01-2017, 01:43 PM   #73
Tommy G
Tommy G's Avatar
Drives: 18 1LE/1SS, 08 G8 GT, 13 GTI
Just found I have this issue as well. The noise started during, and after an autoX event. Just 1500 miles on the car. Dealer is replacing the links, so they must have gotten some damage to the threads. The noise was the loudest front end clunk I've ever heard. Made me think something was going to come loose and break off of the car, but it still drove ok so I wasn't too worried.
I have a fair bit of experience working with BMR stuff, so if I have any more issues I'm definitely going to upgrade the links!
Tommy G is offline   Reply With Quote
Old 08-10-2017, 09:09 PM   #74
Wildman77
Drives: 2017 Camaro SS
Iv got a 2017 2SS and mine started today. Found this thread and took both front wheels off to check. Drivers side front sway bar end-link was loose on the bottom. The other 3 bolts on the front were fine. Thanks guys for the post
Wildman77 is offline   Reply With Quote
Old 08-14-2017, 03:16 PM   #75
MoreSpeed
MoreSpeed's Avatar
My 2017 ZL1 started clunking at just over 6K miles. Turns out the upper right sway bar link was only hand tight! Thanks for the thread!! I would think there would be a more proactive reach out on this by Chevy.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 08-14-2017, 09:13 PM   #76
JusticePete
Drives: Camaro Justice
Red LocTite and Nordloc washers are your new best friends.
JusticePete is offline   Reply With Quote
Old 08-18-2017, 11:00 PM   #77
MaroMayhem
Drives: 2017 Hyper Blue 2SS
I have the same "clunk", I can`t find 12mm Nord-Loc on the Fastenal site.....does a 1/2 inch one work??
MaroMayhem is offline   Reply With Quote
Old 08-19-2017, 11:54 AM   #78
IrocTodd
Drives: 18hyperbluzl1/22C8
when I got my 2018 zl1 that's one of the first things we checked was the sway bar links and sure enough mine was not tight either with 3 miles on it right off the car carrier had the dealer fix it no other problems so far.
IrocTodd is offline   Reply With Quote
Old 08-19-2017, 12:14 PM   #79
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Red LocTite? Will you be able to get it loose when needed?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-31-2017, 12:56 AM   #80
mr965
mr965's Avatar
Drives: ///M3
I took Pete's suggestion and got the NordLoc but no LocTite. So far so good. No rattling. Thank you Pete!
mr965 is offline   Reply With Quote
Old 09-04-2017, 09:33 AM   #81
Infern0
Bring It
Infern0's Avatar
Drives: In Between
This seems strange to me. It appears most are stating this will repeatedly break loose, and the GM bulletin is simply re-tighetning it, which is just a bandaid on the symptom versus fixing the issue. So it's GMs intent to simply re-tighten this thing until the warranty expires or what?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 09-04-2017, 10:40 AM   #82
Mlbraptor
Drives: 2017 SS 1LE
My car has 1500 miles on it. Rattling is getting worse. Thanks for the info guys..
Mlbraptor is offline   Reply With Quote
Old 09-04-2017, 12:33 PM   #83
finney84
Drives: 2017 ZL1 A10
How do you fit the 18mm socket on with the 6mm Allen key in the way holding the stud?
finney84 is offline   Reply With Quote
Old 09-04-2017, 01:09 PM   #84
bkircher
Drives: 2016 Camaro 2SS Garnett Red
I had the same issue on mine, took it in and they got it tightened up no problem. 2016 2SS.
bkircher is offline   Reply With Quote
