#71 |
For some of us that may have slight case of OCD..just to clean the rims.
#72 | |
![]() Drives: 2019 Zl1 Join Date: Aug 2016
I just installed my new wheels and tires and I tourqed them at 140. It's not really that much effort to do.
#73 |
![]() Drives: 2020 SS Join Date: Aug 2020
Yesterday I put the stock wheels and tires back on. The dealer had installed the w/t currently on the car and they use an impact driver to install without checking the specs.
All of the bolts were over torqued, I'd guess I had to stand on about have of them. |
#74 |
![]() Drives: 2021 2SS Join Date: Jul 2020
I for one, lubricate my wheel studs.
Anyway, I have had my share of nearly snapped studs and seized lug nuts due to corrosion. Using anti-seize on the wheel studs has eliminated any difficulty with working with the wheels (and the hub-to-wheel interface). Note, I live in the midwest so I deal with salt and all that fun stuff. When you lubricate, torque will REDUCE by about 25% with Anti-Seize adjusting for the nut factor. So instead of 140 ft-lbs, you are looking at about 105 ft-lbs. I have done this on multiple vehicles and never had a lug nut back off or require to be re-torqued. I always double check my wheel torques a day or two after any work and never had to snug anything up. Nuts come off so easily with no galling or other issues. Most people will be worried about lubricating wheel studs, but it makes things easier. You still are achieving the proper load on the bolt, but due to lower friction, you don't require as much torque to overcome that friction. But dry or lubricated, I always check a few days after to be sure everything seated and is properly torqued again. Last edited by Invertalon; 09-11-2020 at 08:22 AM. |
#75 | ||
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
#76 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I've never seen anti seize be required unless you have open end lug nuts or Ti nuts or something. If you put a closed-end nut on a dry stud there shouldn't be an issue. Using dry studs is the most reliable method because there IS more friction in the threads, this isn't an area you want that friction reduced like you do with engine fasteners because of the nature of the load and also engine studs are torqued to a much higher % of their yield strength, so torquing them dry is unreliable.
If you're going to use anti-seize the best way to figure out torque is to measure elongation of the stud, although using the same angle is probably better than guessing on how much to reduce torque by. Anyways, I'd recommend NOT using any lubricant on wheel studs, clean and dry is best imo. Regards, another engineer.
#77 | |
I'll be switching over to longer studs and open-end nuts in a bit, and I'll be curious to find out the torque value after lightly coating the threads with anti-seize and tightening to the same angle. I'll try to remember to report back.
Matt Miller
2020 SS 1LE |
#78 |
To clarify, yes, anti-seize only on the thread (lightly) and wipe any excess.
As far as torque reduction, I used to design industrial equipment subject to thermal, vibration, etc... Spent a lot of time researching threaded fasteners, gasket sealing and various fastener types. It's not easy to specify and often you are just "close enough" with your final torque value. Endless references out there for what occurs with dry vs. lubricated threads and how it affects the "K factor". So while 10% reduction may be right, so can 20-30% depending on application and factors. Here is a good reference for those curious by Fastenal: https://www.fastenal.com/content/fed...t%20Design.pdf Also, a tool they have for torque values based on size and dry/lubricated: https://www.fastenal.com/en/83/torque-calculator If you pop in the 14x1.5 bolt size and 10.9 class, they give a torque of 148 ft-lbs. Close enough to what Chevy requires. Lubricated, 111 ft-lbs. Actually comes out to the same reduction (25%) as I had pulled from my excel calculators I had put together as design tools for work noted in my original post. Also, you can find the K factors of various anti-seizes on different types of threaded fasteners published by manufacturers. Such as: http://www.adhetec.net/wp-content/up...adherentes.pdf Lots of references though! But it can vary of course, there is a lot of factors to the perfect torque spec. Last edited by Invertalon; 09-12-2020 at 08:04 AM. |
#79 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
#80 | |
If you're going to do it, it would be interesting to compare the result of dry vs the k-value Invertalon posted just above in the last link. I can see using anti-seize if you're going to longer studs w/ open end lugs. With closed-end lugs, the ends of the +1" ARP studs I installed up front are still rust-free, I cut the "nose" off of them so they work with or without a spacer while still being able to use closed-end lugs. I was going to paint them then thought I'd wait and only do it if they rust, but they haven't. So, I don't see the need for anti-seize and I do believe the greater friction in the threads is an advantage in this application, but using open-end lugs changes all that because of exposure to the elements.
#81 |
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Man this is serious... So adding a twist.
I was bored and bought some sweet titanium kit nuts from Katech made for the camaro. Light and look nice too. |
#82 | |
IMO... the risk of galling makes this questionable on cars you don't change wheels on frequently...
#83 | |
Matt Miller
2020 SS 1LE |
#84 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Applying a light coating of lube/antisize to threads only is absolutely not an issue. You just have to reduce your torque spec appropriately. This has been debated for decades.
Spend more time ensuring your hub and wheel mounting surfaces are clean and free of grease. Also you should not use a 0-150ft/lb torque wrench for our lugs. 250ft/lb wrenches are going to be better suited for 140ft/lb as it's right in the middle of the tools range. |
