Old 05-23-2017, 05:58 PM   #71
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
The 200A means that particular circuit is current limited to 200A. It doesn't mean that 200A is constantly being drawn from that circuit. It means that up to 200A can be drawn from that circuit. It would be interesting to know what that 200A circuit goes to so that we'd know exactly how much current gets pulled and why. I doubt though, that even under WOT on a track that 200A is being pulled from that circuit. I also doubt that anybody would have a sound system with a sub pounding at max 60A draw at the same time.
Make better sense?
Originally Posted by brianhj View Post
Here's what I'm not understanding:
You guys are adding another 60+ amps (depending on the size of the subwoofer aftermarket amp) to another fused circuit? That's potentially 260A on a circuit designed for 200A, correct? Shouldn't the sub amp have it's own wire directly from the battery terminal?
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 07-22-2017, 03:09 PM   #72
Zzzato
Bigg Balls
Zzzato's Avatar
Drives: 2024 Red Hot 1SS
Hi guys (first post) I noticed the wiring diagram pictures are no longer working. Does anyone have a copy of these for the non bose amp? Thanks a ton! Now Ill o over to the newb thread and introduce myself.
Zzzato is offline   Reply With Quote
Old 07-22-2017, 09:12 PM   #73
wal-dog
Drives: 2016 Garnet Red 1SS
I fixed them in the first post. Photobucket sucks. Not free no more.
wal-dog is offline   Reply With Quote
Old 07-22-2017, 10:21 PM   #74
Zzzato
Bigg Balls
Zzzato's Avatar
Awesome, Thank you.
Old 07-30-2017, 01:29 PM   #75
Zzzato
Bigg Balls
Zzzato's Avatar
Hey guys once again bringing the thread back up. I just installed my lc7i 4 channel amp mono amp and a sub. Sounds great but m getting all the anc noises are very loud through the speakers. I have the black connector to the left on the factory amp unit disconnected. Is there something I am missing?
Old 11-12-2017, 02:16 PM   #76
River
Drives: RS
For the record 2 is Positive, 1 is negative.
River is offline   Reply With Quote
Old 12-05-2017, 08:12 AM   #77
Redlinez
Shifts under load
Redlinez's Avatar
Not sure if this was posted, but here's that harness http://********.com/Chevrolet-GMC-Cu...ess-clone.html
22 Suzuki GSX-S 1000GT blue
Old 12-18-2017, 01:09 PM   #78
Joel2702zzz
Drives: My Dad's car is a '16 1SS 6MT
Where is the remote turn on wire?
Joel2702zzz is offline   Reply With Quote
Old 12-30-2017, 11:07 PM   #79
Darth Martel
Darth Martel
There is none as far as I know. If you use a LOC that should have a remote on output.
Old 03-14-2018, 04:37 PM   #80
Maroman17
Drives: Krypton green
So does anyone who didn’t use a lc7 have no lows?
Maroman17 is offline   Reply With Quote
Old 06-16-2018, 02:36 AM   #81
cruz1996
Drives: Camaro RS
Originally Posted by Hyper1SS View Post
Here is my setup all installed using the Sub by Thumps plug-n-play wire harness. I use the factory ground locations for the AudioControl and Kicker amp. I ran the power to both at the battery. Everything sounds clean and the amp is receiving a clean signal from the AudioControl unit. I used the front speaker signal to get a full range signal to not choke the bass. I might end up installing some 200hz bass blockers to the door speakers to let the sub do all of the bass work.
Just curious why do you have one12v on the lc2i going to the fuse box and the other to the battery. I’ve been confused wouldn’t it still work if there was just one 12v wire going straight to the battery? Also on your remote wire did you use remote out?
cruz1996 is offline   Reply With Quote
Old 08-09-2018, 05:58 PM   #82
LiveWire195
LiveWire195's Avatar
Drives: 2017 Camaro 1SS
Exactly what I was looking for! My 2017 1SS appears to be the same, so this means is project time!
LiveWire195 is offline   Reply With Quote
Old 09-02-2019, 12:40 PM   #83
wal-dog
Did some work this weekend cleaning up my install. Everything still working fine.
