#71 | |
Brian is the man. Great guy to deal with. For my first HPDE weekend, he emailed me video of him going through the track to help me prepare. Back on topic, I will be calling RRT tomorrow for a status update on the spring rate testing. I'm not expecting anything new (they were very upfront about their workload), but maybe some attention can help speed things along.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
#72 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Thanks, appreciate it.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
#73 |
NP!
Called RRT...they'll get to testing the spring rates early next week. Will post the rates then and I'll also update my spring rate thread.
#74 |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
I may have missed it but if you order this kit with the car is it a factory installed option or does the dealership install it?
I only ask for the autoXing factor. Would not be legal for FS if it is a dealer installed option. |
#75 |
This is not a factory option. You need an actual 1LE if you are going for an event with those kind of restrictions. This is just a GM Performance parts kit to retrofit some of the 1LE parts to a Camaro SS.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#76 |
#77 |
Update: spring rates have been tested but since I'm on a business trip I can't get the results as soon as I'd like. Mike at RRT will email me the charts. Once that's done I'll post it all up. He did say that the rates are very consistent (linear) and the one spring measured around 180. That's the front spring for sure and would be a 43 ft lbs increase over factory SS and 20 over Eibach. More to come!
#78 |
188/539 front and rear
Will post plots next. These are the rates the spring is at for most of its compression. https://flic.kr/p/SNnvV3 front https://flic.kr/p/SNnvU1 rear
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor Last edited by F1FTY; 03-29-2017 at 06:54 PM. |
#79 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
#80 |
![]() Drives: 2017 Camaro 2SS Nightfall Gray 1LE Join Date: Mar 2017
Go to your local dealership's website and look the part up under accessories. They will almost all list a price for the part and installation.
I ended up choosing a different dealership because the guy I was trying to work with was an A**. So I took my money to the dealership I bought the car from in the first place. |
#81 | |
#becauseracecar
#82 |
They said it would take at least 7 days to get the parts. I have somewhere around 5 more business days before the parts arrive and then I still need schedule the install.
So I should be able to get before and after wheel gap measurements. Understand it will be at least another week before I could post new wheel gaps. |
#83 | |
#becauseracecar
Also, installation is cheaper than I was expecting! I found one in Phoenix here that's around $366. I was expecting it to be around $1k for installation. |
#84 |
#becauseracecar
