Old 12-12-2016, 09:19 PM   #71
Sooks569
Originally Posted by Eric SS View Post
Does the oil cooler really have a 5qt. capacity? wow. I was thinking maybe 1/2 qt between the lines and cooler.
I actually could be wrong. I could've sworn I read that there was a 5qt capacity for that oil cooler, but I can't find anything on the capacity now.
Sooks569 is offline   Reply With Quote
Old 12-12-2016, 09:22 PM   #72
Sooks569
Originally Posted by Modshack View Post
They make a low profile, long approach ramps.
I just bought a set of split Race Ramps (the rear portions pull out for clearance). They are 67" long and provide a 10" lift!
Old 12-12-2016, 09:33 PM   #73
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Race Ramps are awesome but so darn expensive! One day I will have a set
Eric SS is offline   Reply With Quote
Old 12-12-2016, 09:37 PM   #74
Sooks569
Even with 4" of play room I still got a little nervous. I just did a test roll so far, I'' doing my first oil change myself on my SS this weekend (I let them do the first 2 since they were free). Royal Purple all the way!
Old 12-12-2016, 09:52 PM   #75
Sooks569
I could've sworn I saw someone post the torque values for the Drain Plug and filter. What is the filter torque? And where do I find those values to verify?
Old 12-12-2016, 09:59 PM   #76
Eric SS
#becauseracecar
Eric SS's Avatar
Post 49. 18 lb/ft for the drain plug.
Old 12-13-2016, 03:34 PM   #77
Sooks569
How about the filter?
Old 12-13-2016, 04:04 PM   #78
Eric SS
#becauseracecar
Eric SS's Avatar
Not sure you'll be able to get a proper torque reading putting on a filter. How would you attach the torque wrench? I just lube the gasket with a little oil and then spin it on relatively tight by hand. Been doing that for 20 years and never had an issue.
Old 12-13-2016, 04:06 PM   #79
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I agree, oil gasket and tighten by hand. Never had a problem doing that. However if you want to use a torque wrench the k&n filters have an extension on the bottom that'll take a socket.
Old 12-13-2016, 05:15 PM   #80
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
The nut and grips and ridges etc are for removing the filter.
Unless you are disabled in some way, there should be no reason to tighten with anything other than your hand.
Old 12-13-2016, 06:14 PM   #81
Sooks569
I haven't done my own oil changes in a while, but I always used the filter socket with a wrench when I did. That's what the Nissan service manuals said to do (I believe it was around 25 ft-lbs) when I had a couple Altimas. When the filter is being torqued it doesn't care what the main purpose of the socket is for. I worry more about over torquing since the tube you're screwing onto is hollow.
Old 12-13-2016, 08:05 PM   #82
cellsafemode
Unless you're using a torque wrench, the best way to ensure you aren't going to overtorque the oil filter is by installing it by hand.
Old 12-14-2016, 01:20 AM   #83
Sooks569
I will be using a torque wrench!
Old 03-26-2017, 08:18 PM   #84
dorifto65
dorifto65's Avatar
Drives: 2016 Camaro 2SS, Black
I was a master level technician for many years before I started doing mechanical design work. Never heard of anyone using a torque wrench to tighten an oil filter. Just spin the filter on hand tight after lubricating the gasket. No need to over think it.
BTW: 25 ft-lb's is way too much torque for the oil filter!
dorifto65 is offline   Reply With Quote
