Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
View Poll Results: Z/28 pricing?
Cheaper than the ZL1 45 27.44%
More expensive than the ZL1 119 72.56%
Voters: 164. You may not vote on this poll
Old 03-30-2017, 09:37 AM   #71
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
That four inches difference in width could be very significant.
Especially when you consider that there were rumors the Alpha platform originally wasn't designed to accommodate an engine the size of a V8.
How wide is the Twin Turbo 6 in the ATS-V?
Old 03-30-2017, 10:58 AM   #72
whiteboyblues2001
whiteboyblues2001's Avatar
Not sure how wide the LF4 is, but it is a 60 degree V as opposed to the 90 degree V of the V8's. That would make it narrower, BUT there is also additional plumbing that goes from the turbo up over the heads to the intake manifold.
whiteboyblues2001 is offline   Reply With Quote
Old 03-30-2017, 12:24 PM   #73
Mr. Wyndham
Good point 60º v 90º
Old 03-30-2017, 05:09 PM   #74
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
I never recalled hearing that alpha was not originally designed for a V8.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 03-30-2017, 06:51 PM   #75
Mr. Wyndham
It was very very early in the development, and only a rumor...that it was going to be designed for Cadillacs and V6s only. Which didn't make very much sense then, as a V6 is just as big as an 8, if not larger in some respects.
But the point I brought it up to make, was simply that the architecture is compact. A tight fit. The C7's 7-speed manual didn't fit in the tunnel, as an example.
Old 03-31-2017, 08:14 AM   #76
whiteboyblues2001
I think that was a rumor that "the pill" started. It wouldn't make sense for the Alpha chassis to not be designed for a V8, since the Camaro was planned to be on that platform from the beginning, AND the Cadillac was going to have a V8 anyway (CTS-V).
Old 03-31-2017, 08:42 AM   #77
Mr. Wyndham
Could've been.
Old 03-31-2017, 09:39 AM   #78
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
"the pill"
Is he here? I had my fill of him on MUSTANG6G.
Old 03-31-2017, 09:45 AM   #79
Mr. Wyndham
Definitely not.
...we...ended the relationship...
Old 03-31-2017, 10:11 AM   #80
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by hjdca View Post
It does not seem like there is that much of a difference... Here are the specs of the new Mercury Racing SB4 7.0 (small block – four valve) motor with 750 hp... 29 inch width...
LENGTH (FROM BACK OF BLOCK TO FRONT OF ENGINE - CRANK PULLEY) (IN/MM)27.1/688
WIDTH (ACROSS TIMING BELT COVER) (IN/MM)30.25/769
WIDTH (ACROSS REAR OF CYLINDER HEADS) (IN/MM)29.1/740
HEIGHT (FROM CRANKSHAFT CENTERLINE TO TOP OF THROTTLE BODY MOTORS) (IN/MM)17.1/435
WEIGHT (WITHOUT ACCESSORY DRIVE) (LBS./KG)498/226
I found the LSA CTS-V engine dimensions which are 26.57" width (across heads) and 29.13" length
Nice find, and for your info there is lots of room to fit that in the car, there is 5+" per side on the LT1 to strut tower, and all you will need is to remount the over flow tank.
when you look at the car that is hard to believe.
2SSRS@Gen5diy is offline   Reply With Quote
