#71 | |
![]() Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
#72 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Speaking of maximum power, I know Thomas at Hendrix engineering has said he got over 900 whp out of a 2.3 on a 454 and if I remember correctly they were not using any cooling brick at all because it was a drag car and never ran more than 10 seconds. I don't know if I fully agree with the concept that the inlet port restriction is the main power limiter on the supercharger because we observed a similar phenomena of boost rise directly related to intake 2 temp increase when we were feeding the supercharger with preboosed air from turbos in my compound boost set-up. The supercharger inlet could not possibly be the limitation when the air at the supercharger inlet was under boost. Yet no matter how we tinkered we really could not get much more than 1000whp through the supercharger in a true compound set-up using a heartbeat supercharger. I then pulled the supercharger off and the car instantly made 1200 whp on turbos only. Since I pulled and sold the heartbeat supercharger from my ZL1 I have seen a forum post where a builder achieved 1400+ whp using compound boost through a LS9 supercharger. The LS9 supercharger has much less restrictive cooling bricks than the Heartbeat and I suspect that is the main difference, but it is really hard to say. My ZL1 is still not running with twin turbos and a 1.9 in harmony, but it will be. I really like your comment on the OEM parts not giving Kudos for extra power, they are specifically engineered to optimize efficiency at a certain power level. When we get it in the aftermarket, then we figure out what happens when you run it until something fails or can't keep up. I must admit that the GM engineers have been giving us Camaro owners a lot of room to play by making parts much more durable than stock could even begin to stress. What started my comment to LesBaer is really the information that when you buy a supercharger it has a limited range, really more like a max amount of air and power. If you take a supercharger and put it on your car and just keep adding pulley size one step at a time, you will find the point when spinning it faster will no longer give you more power. If you want to make the absolute most power possible, in general you will want a bigger supercharger. If you know going into your build that you are going to be under the 700whp mark then the smaller supercharger may actually be more cost effective and efficient. Having said all of this I loved my ZL1 when it was on the Heartbeat, that was a great supercharger. I drove it all the way to Arizona and averaged over 100mph including my time for fuel stops (and I made a lot of fuel stops). But the factory GM superchargers are awesome also.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#73 | |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
#74 | |
are you running SuperTurbo or TurboSuper? (naming convention by the order of the devices) I normally wouldn't recommend TurboSuper for a gasoline engine as its benefits are mainly focused at boost levels that are higher than that which is capable with gas (think diesel here). Since you are using the factory SC I have to assume TurboSuper, which pretty much requires a capable control system including electronic bypass system to control. SuperTurbo like what is used by VW in Europe and the new Volvo XC60 her in the US is much easier to control. In a TurboSuper system you have to think of the SC as a multiplier, which is what it really does all of the time anyway, it takes the inlet pressure/flow, multiplies it by the Pressure Ratio that it is pullied for, and provides an outlet pressure/flow. It continues to do this under ALL circumstances and the input power for the device is the combination of the following 4 items; pressure ratio, mass flow, thermal efficiency, and mechanical efficiency. With the turbocharger feeding the SC you probably want to unload the SC with the bypass system as the turbocharger comes on line. If the SC is not unloaded it continued to do what it was designed to do - multiply. For example let's say we have the SC set to a 1.8 PR (~12psi boost at atm) and we add the turbo. To calculate the SC output pressure we take: Inlet pressure x PR = Outlet pressure for each device – remember that PR is based off absolute pressure. So at sea level with an ideal inlet we would have (14.7*1.8) =26.46psia absolute pressure (then subtract 14.7 if you want boost pressure) Adding the turbo to the system also set at 1.8 PR we would find: (14.7*1.8) = 26.46psia for the turbo then the SC would be (26.46 * 1.8) = 47.63psia (subtract 14.7psi) and we have a boost pressure of 32.9psi. With this arrangement it’s easy to see how things can get out of control in a hurry without a good control system, especially with a nonlinear device upstream of the multiplier. This is the reason that the Superturbo the more favorable solution, you pin the nonlinear device between 2 positive displacement devices (SC and engine) which in turn sets some bounds during transient operation. Also we noted that the input power of the SC is influenced by PR and mass flow. While the PR is controlled by the drive system, the mass flow is increased through the SC by the TC which will require additional drive power (for back of the envelope calcs you could assume the PR and mass flow are 50% each) so drive power will increase by up to 40% as the inlet pressure to the SC is increased to 26.46 psia from 14.7 psia. To try and control the SC bypass in a turbosuper system is difficult, I was not successfully able to do it with a vacuum operate PWM controlled bypass due to the hysteresis and lack of feedback. An electronic bypass is pretty much required. Since the SC is a volumetric device, it shouldn’t really become an “air restriction” in the path of the turbocharger, but if it ends up doing unnecessary work, it will requires input power, which will then impact your results. You'd also have to measure the IC pressure loss to understand the impact in your application. Compound boosting systems look to take the strongest points of each device and capitalize on them. In this cases I’d expect to be running a pair of non wastegated turbine housings sized for the maximum boost and power that I was planning to run and then devise the control system to have the SC provide the transient response and fill in the “hole” from the turbochargers at the low-mid engine speed. It truly creates a boosting system that cannot be matched by any other means but will require some development to make it right. Sorry for the long winded response, I presented a paper on SuperTurbo at the 2005 Dresden Boosting Conference in Germany, if you have interested in the topic send me a PM with your email and I’d be happy to send the paper to you. Happy Boosting! Mike |
#75 |
Drives: 2016 2SS Join Date: Mar 2014
Why is this kit so much more expensive than the procharger?
#76 |
Drives: Anything I want Join Date: Oct 2008
#77 |
About $5,400
#78 |
Can't speak specifically for Andy's kit, but when compared to a Magnuson it's about quality. I've attached a couple photos that I found here on the forums that can help show the differences.
Notice the differences in things like clamps, fittings, hoses, air filter, etc. The Magnuson uses all OEM quality components, has a calibration which delivers 550+ RWHP with perfect drivability as daily driver, is CARB pending, features an included 3 yr / 36000 mile powertrain warranty, and an optional 5yr / 60000 mi powertrain warranty. Now I'm sure there will be plenty of arguments about how long some people have run their centrifugal systems, so many miles, so many years, etc. The Eaton TVS based units are what the OEMs like GM, Jaguar, Ford, Audi, Nissan, VW, Volvo and Mercedes have used in production, it is the most efficient and reliable SC available today. |
#79 |
/2016-camaro-lt1-supercharger-kit-625-hp
This says there is a one year warantee which just that is enough to make me believe the kit is junk. Separate question: I remember procharger as being a reputable company with gray products, is that no longer the case? |
#80 |
Legos
I often wonder why Legos cost $100+ dollars.Its because they come with
1500 pieces. Pretty sure each piece cost somethingjust like pieces to a supercharger. My join date was 8 years ago and my son is 8 years old Hmmmmm. "Is it good enough,the customer will decide" |
#81 | |
#82 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
I thought I smelled something....Andy, good to see you sorting the 6th gen's out. What do you think the power ceiling is on these engines, I know they have been around for more than a day or so, but the LS3 was also when it was shoved into a 5th gen.
After all the years, it seems the sweet spot for the LS3 is around 750 to 850whp, (I am aware that topic is debatable). What do you think the new 6th gen is good for, before cracking it open and forging the internals?
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
#83 |
![]() Drives: 16 Camaro Join Date: Aug 2015
Not to feed the troll but, after reading tons of articles because my car is going FI I didn't understand why to go roots or PD. After my car is done I would love to do a comparison with anyone with a maggie blower they are right down the street from my place.
#84 |
![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
I don't know which is better, but I order the Edelbrock E-Force TVS 2300, for my 2SS. It came with a free 3 yr. 36000 mile Power Train warranty. And no maintenance for 100,000 miles. For my daily driver the power it will produce will be ok with me.
