#71 |
![]() Drives: 2017 Summit White Chevy Camaro 2SS Join Date: Jul 2016
that's the shit right there!!!!!!!! ^
#72 |
Drives: Camaro Join Date: Jan 2016
MRR M017 1Le style in Flow Forge
#73 |
Help
Has anyone powder coated or painted the 2016 Camaro rims yet? Need ideas. I had to downsize from 21s to 20s. Need help!
#74 |
MRR FS01 Flowforged
Here is a quick look at our Flagship FS01/ Classic concave mesh design.
Gloss black lite weight Flowforge construction. |
#75 | |
![]() Drives: 3015 300s Join Date: Mar 2016
2016 Mosaic Black Metallic 1SS NPP M6
#76 |
Drives: Turbo 4, SC V8 and Twin Turbo V8 Join Date: Jan 2014
6th Gen Chevrolet Camaro with FlowForm FF15 Wheels in Fog thanks to Davenport Motorsports!
20x9 ET25 Fronts with 20x11 ET45 Rears ![]() ![]() ![]() ![]() ![]() |
#77 |
![]() Drives: 2016 Camaro SS w/2ss (mosaic black) Join Date: Jul 2016
lots of nice wheels and rides in this thread, hope to be able to post mine in here some day...hahaha
I have a question about some wheels i was looking at, verde v99 bronze wheels, specs are as follows: fronts: 20x9 +20 running 265/275 tire rears: 20x10.5 +42 running 295/305 bolt pattern: 5 x 120 Question is will these wheels fit and will any spacers be needed for them to run a 295/305 tire in the rear. also will the fronts stick out to far with +20. other options include +35 for front(guessing spacers would be needed) and +27 for rears, these any better for offsets? thanks in advance for any replies. did a quick photoshop of how these wheels would look like on my mosaic black. Last edited by zapdon; 12-02-2016 at 09:58 AM. |
#78 |
SABIO
A 295 on a 9"!! That is pretty wide.
The offsets are fine. About 11.5mm in the front and 10mm in the back. If you want more just add a 5mm spacer. You should look into a 265 and 285 combo for tires
#79 | |
and thanks for the reply |
#80 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Dec 2015
9" width with ET20 is actually perfect for the front. That's what mine are, only in 19" and 245 section width tires. The rears should be ET35-37 to match that front offset though, otherwise your front track will be wider.
#81 |
![]() Drives: 2017 50th SS convertible Join Date: Oct 2016
Hello,
Here are a couple of pictures of the Mighty HABU with her new shoes. Kindest, Donner |
#82 |
so adding a 5mm spacer to the rears should put me where i wanna be. with a 5 mm spacer would i need longer studs or should they be fine.
#83 |
That really depends on how much thread is left after you install, and that depends on wheel construction. A 5mm spacer shouldn't require new studs... but if it does, get ARP bolts or some other quality brand.
#84 | |
![]() Drives: 2019 ZL1 Camaro Join Date: Oct 2016
Can you please pm me a price shipped to 48323. 1LE/ZL1 sizes Front 20 X 10 (25mm offset) Rear 20 X 11 (43mm offset) Thanks, John |
