08-23-2016, 07:23 AM | #71 | |
I tell all my customers, power comes from the parts tuning makes the parts work properly. Your right tuning alone does not produce additional power but there are a host of benefits. Tuning frees up power you don't have access to through torque management reductions. Keeps power available through engine temp controls. Turns off skip shift. Turns off AFM Removes speed limiters for those in competition. Raises rev limit to increase power range. Optimizes AFR for max power through the rev range. Optimizes timing for the fuel your running. Improves overall feel of car. Adjusts all necessary parameters for addition of aftermarket parts be it a simple cai or a full on build with forced induction, cams etc. Ted.
www.jannettyracing.com
08-23-2016, 10:29 AM | #72 |
Drives: SS 6 speed of course Join Date: Jan 2016
heck, I go back to Hutch starting LS1.com LOL LS1Tech, they are the newbies.
08-23-2016, 10:32 AM | #73 | |
08-23-2016, 10:42 AM | #74 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
08-24-2016, 02:29 AM | #75 | |
Drives: 16 Camaro 2SS Join Date: Aug 2016
All of the above worked great for the most part on a 2013 Corvette (as it did on my 5 other previous cars) However 75% of the above did not on a 2016 stingray (using a tuner that rhymes with Biablo). The Camaro is basically the 2016 stingray with a few different internal parts. I have not yet found a vendor that can optimize a car with mode options - nor even get them to work properly. Track mode is still better than any tune on a 2016, without the needless risk of waranatee loss and damage to the vehicle. Tearing out Cams, adding FI...etc - you have no choice than to tune. Pulling out of my driveway and into the street, while losing my ability to use the gas peddle was a bit concerning. (the 3 disabled modes I mentioned after the tune). So basically for the $400 I paid for the rhymes with "Biablosport" tuner and the additional $150 for the CUSTOM tune I received these working items: + Turn off AFM (one of the silliest items to turn off - does not apply to tracking whatsoever. Less MPG is better for no HP gain?) + Turn off speed limiter (in case driving 170+ mph wasnt enough - you will NOT reach that speed on a typical 1/4 - 1/2 mile track, nor probably ever unless you find an abandoned runway and have balls of steel) + Turn off skip shift - now that was a plus no doubt + Ramping up RPMs and messing with the fuel table - ahhh, no thx I like to keep my car out of the shop. + Thats it Ive always said tuning is the #1 best mod, however that doesnt apply to many of the newer 2016 performance cars. This is from actual hands on testing on the cars mentioned - 2016 SS and Stingray. I have the worlds best side job, but am not allowed to mention what that job is specifically, hype or Rip a product name or else I risk losing that most excellent, non-paying side job. ------ Last edited by DisturbedSS; 08-24-2016 at 02:44 AM. |
08-24-2016, 02:56 AM | #76 |
On the bright side, my new CAI (sigh, that I cant mention) and Borla Stingers (one I can mention) really made a difference without tuning. Stingers more so for sound on a non NPP system. The nameless CAI made a difference in performance at the higher RPMs, as do most CAIs installed on a stock system. Its normally as far as I go aftermarket anymore on the 2016s - sans cosmetic upgrades.
As Ive learned (the hard way) over the years...dont waste a ton of money swapping out majorly expensive parts on a new car - just save the money and go FI later. In the long run it will cost the same and give you far better performance. You are tearing your car apart anyways and giving that power-train warantee the 1 finger salute, so go for broke. Tune till your fingers bleed! |
08-24-2016, 09:29 AM | #77 | |
Try tuning with SCT or HPtuners and it is a whole new world. Ted.
08-24-2016, 12:43 PM | #78 | |
Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
You realize that Track mode literally does nothing to increase horsepower. It tightens up the steering, adjusts the MRC if equipped, and opens the exhaust. The car will dyno the same from Tour to Sport to Track. Every single 2016 performance vehicle benefits from a tune. Some more than others. If you just tune your vehicle the gains are minimal, but after adding an intake and exhaust the gains are exponentially more. Just because you had a bad experience with possibly one of the worst tuning devices on the market does not make you an expert on what does and does not work on this platform. Get a real tuning device and then formulate an opinion - the rest of us are enjoying it.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
08-24-2016, 01:07 PM | #79 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
I believe Track also advances throttle response and firms shifts on the automatic as well, which could be giving him the illusion.
08-26-2016, 02:09 AM | #80 | |
Im pretty sure every 2016 Camaro SS is pretty much the same when it comes to stock internals. You definitely cant tune handling and package options. Theres nothing wrong with canned tunes on a stock or mostly stock setup (simple CAI swap and/or axle back swap). Ive tuned 8 different make/model sports cars and NEVER had an issue until I got to the 2016 models - especially Chevy. Camaro SS and Corvette Stingray. Why tune a brand new car when it comes with pre-loaded factory tunes already - touring/sport and track. My tuned 2016 Corvette was slower on every run at the track against the factory Track setting. Granted it was a canned tune, but then again a dyno tune is ultra expensive and you dont always have the luxury of going back to stock - and you WILL need to go back to stock at some point. Im still amazed that people will risk voiding warantees, running too rich or too lean or putting greater load on an engine to gain 10HP - maybe, in some cases LOSE 10HP on a 50K car fresh off the lot. Im not going to tune to turn the limiter off and drive 200MPH or turn off something that gets me better gas mileage while maintaining 100% of the performance (AFM)- stupid. Hell the 2016 SS auto camaro is a gear shifting king, why would you jack with near transmission perfection? The safest and biggest bang for the buck has always been exhaust swaps (WITH cats) and a CAI. Your warantee is intact and you gain butt dyno performance. No vendor will ever admit it, but the 2016 cars dont really improve much with tunes unless you gut the car and THEN tune the enhanced parts. By then you are 100% on your own for fixing the inevitable issues that 3rd party parts bring. Honestly I see the benefits of tuning, just playing devils advocate. Tuning older model cars (2015 and older) makes sense in most cases when craving quick and easy performance gains - 100% agreement on that. Until proven otherwise 2016 has become my first year of ditching the tuning - thumbs up to the engineers at Chevy for saving me $650! Last edited by DisturbedSS; 08-26-2016 at 02:20 AM. |
08-26-2016, 02:43 AM | #81 | |
Thats a very subjective blanket statement and my ACTUAL hands on experience says otherwise so far this year. Im NOT saying there is no benefit, just that the minor gains do not justify the steep cost of a tuner, tune and loss of warantee (in some cases). Its an opinion based on a different set of vendors/cars. You can certainly tune and gain a few HP with stock components, but the benefits are getting slimmer every year because car makers are playing the performance number game - aka HP numbers. Its a reach to the top while keeping federal mandates in place. Auto engineers are opening up past restrictive settings then adding better handling components and noise control. So far this year... Driven and tuned a 2016 Stingray Driven and tuned a 2016 Challenger R/T Driven and tuned a 2016 Mustang GT Owned and driven a 2016 Camaro SS Used the preferred vendor tuning device for each model above as well( minus the SS). We all know the SS internals are nothing more than slightly dialed down Corvette internals, so I see no need to test a tune this go-round of the exact same engine. Its a glorious experience, driving these beasts - vs the polar opposite when I no longer have access to them. Like smacking an iPhone from a 3 year olds hand and the subsequent cries from temporary loss of internet access. 2016 is a unique year for stock vehicle overall performance - AS IS - probably the best year Ive seen in a very long time. Last edited by DisturbedSS; 08-26-2016 at 03:33 AM. |
08-26-2016, 03:06 AM | #82 | |
...better throttle response translates to faster 0-60 and quarter mile runs. If you push a peddle and it responds faster, you will probably get to the next stop light a little faster. What happens when Teslas family Sedan S and "minivan" wing door X model go mainstream (maybe) and a soccer mom "X" full of groceries and screaming 2 year olds blows by your muscle car like it was standing still. Just listen for the "WOOSH". It will be a sad day when a gas induced V8 becomes 2nd fiddle to a battery operated autonomous car. Ludicrous! <pun intended> C'mon Tesla, let me test one of these self driving double DD batteries! Im not worthy. Way off topic. Yea, sorry I'm trolling too much in this forum. I love you guys, you drive what I drive! OK, lets not get carried away here...I enjoy responses to unpopular opinions. All BS aside...I do literally love my fully loaded SS (2SS package) with its aftermarket Performance CAI, Borla Stinger axle backs, lots of cosmetic bling and zero visibility when changing lanes. Best car Ive driven to date IMO (even better the Corvette) and thats saying a LOT! Last edited by DisturbedSS; 08-26-2016 at 03:20 AM. |
08-26-2016, 08:03 AM | #83 |
Drives: 2019 zl1 Join Date: Jul 2016
So from this thread it seems like its a waste of time to do either a dyno tune or e mail unless you plan on doing some heavy mods to the car?
08-26-2016, 08:07 AM | #84 |
マスタング = 遅い
At this point yes. An auto down the road will have the advantage of more specific shift tuning, but all those tables are yet to be fully explored. IMO at this point it is not worth taking the chance of losing your powertrain warranty for a few ponies and maybe a little less torque management here and there.
