Old 05-07-2013, 10:16 AM   #71
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
Originally Posted by danl View Post
i think this forum should stay as is.
I dont think the 6th gen will do as well as this one has. Gen 5, is the last of the beautiful, muscle car called Camaro.
I think in time, these cars will out sell gen 6 at the Barret Jackson auctions many years from now...it is easily the most eye pleasing of all camaros since 1980 and on.
It's OK to be biased since you own the car, but just note that your opinion is not the same as that of the rest of the population. The 6th gen will likely outperform the 5th gen in every metric, performance and otherwise.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 05-07-2013, 10:46 AM   #72
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
In performance? Well... maybe since its a lighter platform. But you wont have the ZL-1, the COPO or this type of Z/28. And you probably wont see a 6th gen camaro with 500+ HP unless they S/C the LT1. But then what will they call it? It wont be a ZL-1.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-07-2013, 12:32 PM   #73
meissen
meissen's Avatar
100% speculation, but I doubt that GM would come out with a new generation that doesn't outperform the previous generation. Look at the 'Vette... C6 400hp base, C7 450hp base. Even if they kept the HP the same, like you said because it's a lighter platform it'd probably still outperform.
That said though, I haven't seen anything speculation on the ZL-1, COPO, or Z/28 -- I can see why the COPO and ZL-1 might not be back for the 6th gen Camaro but I would definitely hope the Z/28 comes back. At this point it's anyone's guess.
Old 05-07-2013, 02:41 PM   #74
Wizard1183
Wizard1183's Avatar
Right as for the Z/28? They'll def have one. But it wont be anything near this one. Remember, these cars are modern muscle and since history repeats itself, you honestly think performance will stay on a steady increase? Lets look back at where these modern muscle cars came from. 1967-69, most notibly 1969. After 1972, the high perfomance started to drop. In '72 you had the LS-3 "396" as the big perfomer. 1973 "SS" was dropped to "LT" and largest engine was a 350 with 243HP max. This is where performance is headed. May not be this drastic since theyre including DI plus Turbos, Twin Turbos/SuperChargers on them to obtain fuel economy and have the HP behind them. But dont expect a plethora of naturally aspirated engines with too high of HP in the next gen as compared to these 5th gens. They do have one engine to get there and thats the LT1 which will have equal or greater HP than the current SS. After this, I dont see it increasing but actually decreasing in displacement and running FI to stay near the HP numbers if they decide they want to stay near it. The 6th gen will probably outperform the 5th because of reduction in weight and the LT1. After this engine, displacement will drop and so will HP.
Old 05-07-2013, 03:22 PM   #75
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
I think of it as a chapter... once the 6th Gen comes out, the 5th gen's will already have had most of the questions, opinions, rumors, and highlights answered in a searchable way... it would make sense to make a Camaro6.com as a means to separate the new from the prior(s)..
Then again, Camaro5 can transition into a title of establishment time frame rather than a title of generations (i'm newer here than most, so not sure if Camaro5 was the first major Camaro forum, becoming heavily popularized by the 5th gen Camaro...)
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 05-07-2013, 03:28 PM   #76
Mkn95u0
Mkn95u0's Avatar
Imagine the future a little more the California strict way... Camaro 1EV - with an electric option. Rather than fully reliant on gasoline... I wouldn't count on history repeating it self in power decrease, but it would be like the transition into the 3rd gens, they were more or less the first gen with major smog fitments and a more outlook in aerodynamics (some may argue... feel free to correct me if i'm wrong)... the 5th gen to 6th gen could follow with stricter smog requirements and transitioning into electric.
Just a food for thought, not necessarily my hopes or what not..
Robert
Old 05-08-2013, 07:25 AM   #77
Wizard1183
Wizard1183's Avatar
I would think GM discontinues the camaro name before going to electric with it. I wont be the least bit surprised if after the 6th gen, they discontinue it.
Old 05-10-2013, 05:24 PM   #78
Mkn95u0
Mkn95u0's Avatar
I would hope not... but you're probably right, i honestly cant see them putting an electric motor in a Camaro nor or ever in the future...
Robert
Old 05-10-2013, 09:02 PM   #79
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
I WILL BRING MY gen 5 to C6Fest ^5 And they can all look BACK and say YEP GEN5 was the best looking GEN <<< LOL
skipinminn is offline   Reply With Quote
Old 05-12-2013, 02:06 AM   #80
2012-1822
2012-1822's Avatar
Drives: Black ZL1
If Ferrari can go hybrid then maybe anything is possible
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 05-12-2013, 07:54 AM   #81
alanhurst
Master Chief
alanhurst's Avatar
Drives: 2011 Camaro SS RS L99
pfft 20 yrs from now when some 16 yr old kid picks up one of these cars for like 1k, he's gonna come here and ask what?
"will a cold air intake void my warranty?"
You know it's gonna happen,calling it now.
alanhurst is offline   Reply With Quote
Old 05-13-2013, 04:42 AM   #82
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
I think the warranty will be long gone by then.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten!
Bad@ssCamaro is offline   Reply With Quote
Old 05-13-2013, 07:29 AM   #83
revychevy
revychevy's Avatar
Drives: 2010 2SS RS LS3
They didn't just reduce HP in a vacuum in the '70s. There was the clean air act that got rid of leaded 100 octane gas, (which was everywhere). Catalytic converters, the OPEC oil embargo, rising insurance rates (since they made it mandatory). And Govt surcharges on muscle cars. A perfect storm of fun killing dooky that ruined the US auto industry in my opinion. I was a young man then but remember after the early 70's they started making little compact cheap wanna-be Japanese economy cars, and big oversized underpowered boats. Both of which had little appeal to me.
2SS RS bone stock for now...
revychevy is offline   Reply With Quote
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
