05-23-2017, 01:34 AM | #71 | |
Drives: 2017 zl1 Join Date: May 2017
05-23-2017, 07:46 AM | #72 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
If you're driving it hard, you should feel it start to "wake up" soon but don't expect anything close to full power 'til at least 800 to 1200 miles. You'll want to change the engine oil/filter and differential fluid every 400-500 miles during break-in. Inspect the first few ounces of oil and contents of filter for particles on 1st oil change. I waited 'til 600 and mine was slightly dark already. You may want to replace the OEM engine oil drain plug with a magnetic plug to capture any suspended or settled particles. Differential already has one. A small amount of fine particles is normal during break-in. If driving it hard and for racing, use engine oil that meets the Dexos 2 spec. I use Amsoil 5W-40 ESP European formula. My sources for engine oil, filter, and diff lube. If you're going to break it in hard, allow the engine to warm up to operating temp before you go WOT. Avoid engine braking (down-shifting with zero or low throttle). This will allow oil to get sucked passed the rings into the cylinders, slowing the break-in. Don't wind it out all the way to red-line either and no popping the clutch. When done accelerating through 3rd gear (5th or 6th in A10) at most (depending on where you're driving), clutch in and coast or brake to slow down (higher gear or N with brake for A10). Be sure to give it a chance to cool between sessions - at least 2-3 hrs after intense loading of the motor (8-12 high-power runs). When you're done with break-in, slowing from high speed is a good chance to finish "bedding" the brakes (see "brake burnishing" in owners manual pg 205). I began this after about 800 miles. How you break-in your car is up to you, read-up on it and make your own choice. This is always a hot topic so you'll find fervent believers in both "slow-and-easy" and "fast-and-hard" methods. Use common sense and you should be okay. Protecting the drive train from excessive wear with more frequent oil changes will go a long way. --Cal |
05-23-2017, 10:50 AM | #73 | |
05-23-2017, 11:52 AM | #74 | |
Cal
Did you bring it back to the same shop? What kind of numbers are you seeing now? |
05-23-2017, 03:24 PM | #75 | |
05-25-2017, 01:58 PM | #76 | |
Drives: 2017 ZL1 Join Date: Mar 2017
05-25-2017, 07:01 PM | #77 |
Drives: 2017 camaro ZL1 A10 Krypton green Join Date: Apr 2017
I have now seen 3 different ZL1'S put down 600+ to the wheels. Hoping to have mine dynoed mid june
06-04-2017, 02:58 PM | #78 |
06-06-2017, 06:53 PM | #79 |
Drives: 2017 Black ZL1 (6spd) Join Date: Dec 2016
Mine was crap, 505 torque, not a happy camper
07-31-2017, 07:37 PM | #80 |
Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
Stock run on a non-portable dyno. Better numbers than before.....
07-31-2017, 08:44 PM | #81 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
08-02-2017, 12:17 PM | #82 |
Mine put down 575whp on a mustang dyno in 90° heat.
08-02-2017, 12:51 PM | #83 |
Drives: 2017 ZL1 Join Date: Nov 2016
I posted my bone stock dyno in mid November, '16.
2017 Camaro ZL1
Instagram: @ZL1_Tommy Youtube: ZL1 Tommy |
08-02-2017, 03:29 PM | #84 | |
Drives: Duramax Join Date: May 2017
What type of Fuel and Octane rating where you running> |
