03-24-2017, 02:14 AM | #71 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
UPDATES:
I took the tires and wheels to our local Discount Tire store to have them mounted and balanced. They also installed the TPMS sensors. Can you tell which one is the wider? ( both 305/30/19 but the one on the left is a 11" wheel vs a 10.5" on the right) took another look for the front fitment with the tires mounted. Again, this is with 5mm spacer and -2.2 camber up front. The fitment would be a lot easier with street alignment and even with 3mm spacer. As you can see the strut arm bottom side is a bit too close and some grinding will hopefully fix that and here are some pictures with them on the car .. Front poke was minimal compared to rear. Rear is also not too bad but they stick out about 18mm. Soon to be installed: C7 Z06 fender flares After I drove around the block, as I suspected, I had slight rubbing on the inner wheel so I decided to come back and wait for the extended wheel studs install and grinding. I also stacked 3mm and 5mm spacer to see if the 3mm grinding on that closer edge would give enough space and it looks it will fix my issue. Worst case scenario, I will still have it grinded and add 7mm spacer as I am already going with longer studs If my mechanic tells me I can get away with more camber after the grinding, I will go ahead and change the camber to -2.5 upfront (from -2.2) since Trofeo R and NT01 tires work better with more camber up front, and I already lose some of that camber when cornering due the fact that I have strut setup instead of a double wishbone
03-24-2017, 07:56 AM | #72 |
Drives: 1LEs Join Date: May 2009
Thanks for the detailed updates and pics.
03-24-2017, 08:44 AM | #73 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
How are you going to achieve more than -2.2? I'm maxed @ -2.2. No camber plates are on the market for the 6th gen. |
03-24-2017, 09:08 AM | #74 |
Drives: 2017 Camaro 1LE Join Date: Sep 2016
Thank you for the update!
2017 Hyper Blue 1LE
03-24-2017, 02:29 PM | #75 | |
Sure
you're welcome
03-25-2017, 02:48 AM | #76 |
Drives: 2017 1le Join Date: Mar 2017
[QUOTE=glamcem;9631837]
How much room is left on the inside on the rear? I'm thinking of trying to order a set of 19x12 but I'm not 100% sure they'll work. Thoughts anyone? |
03-26-2017, 02:51 AM | #77 | |
[QUOTE=6thGen1leLA;9633735]
To Answer your question; The rear wheels actually stick out 18mm compared to OEM setup. So inner clearance is not even an issue
03-26-2017, 02:58 AM | #78 |
Not an apex wheel. I'm considering running a new forged company I came across. I'm scheduled to bring my car down to the shop for th to measure and see exactly what will and won't work but I need to do my homework till then.
I'm trying to stay inside the fender. From what I've been seeing online guys are running 20x11 +45 I'm thinking 19x12 at about +53 based on my math. The only issue is will I hit on the inside? Seems like we have less room on the 6th gen than the 5th gen guys. With your current setup how much room is there left inbound? [QUOTE=glamcem;9635270] |
03-26-2017, 01:13 PM | #79 |
[QUOTE=6thGen1leLA;9635272]Not an apex wheel. I'm considering running a new forged company I came across. I'm scheduled to bring my car down to the shop for th to measure and see exactly what will and won't work but I need to do my homework till then.
I'm trying to stay inside the fender. From what I've been seeing online guys are running 20x11 +45 I'm thinking 19x12 at about +53 based on my math. The only issue is will I hit on the inside? Seems like we have less room on the 6th gen than the 5th gen guys. With your current setup how much room is there left inbound? Any specific reason for going 12" instead of 11 or 11.5"? I highly doubt that will fit with that offset and size. That would put the wheel 20mm closer to the suspension and I am almost sure it won't work, especially with the OEM struts. If you look at the Z28 OEM wheels (19x11.5) the offset is +26mm in the rear vs +43mm for the 20x11" OEM wheels. In other words, to fit wider wheels they lower the offset so that it sits further out not the other way around. In your case you're not only losing the inner space but also go with 1" wider wheels. I highly doubt the clearance is different between 5th and 6th gen also.
03-30-2017, 02:04 AM | #80 |
UPDATE:
Took the car to my mechanic for some grinding, longer wheel stud install and Diff/transmission fluid change since the rotors were removed I weighed them on the scale while they were working on the car. Our front rotors are really heavy :/ I will see how much the slotted OEM rotors that come with the OEM Brembo kit weigh new longer OEM studs are installed and trimmed to be used with OEM lug nuts: some grinding on the strut arms gave enough clearance with the wheels and painted: And now with the Apex wheels and 305/30/19 tires for a testfit .. plenty of clearance now
03-30-2017, 08:47 AM | #81 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Yea it's a lot of rotor for a lot of car.
Did I miss it or can you please post the part number for the longer studs?
03-30-2017, 10:08 AM | #82 |
SABIO
If those are the Cadillac ones. 11588810.
7mm more thread. Good for 10mm spacer Have a couple numbers that will work. Slip in a 25mm spacer if you want.
03-30-2017, 10:10 AM | #83 |
2017 Hyper Blue 1LE
03-30-2017, 01:25 PM | #84 | ||
I agree with you it needs more rotor but keep in mind Girodisc also had lighweight 2 piece rotors for Gen 5 Camaros which are even heavier than our cars and the slotted rotors for Brembo 6 piston kit are much likely lighter than our rotors. This is the same exact weight with the previous Gen ZL1 rotors so there is a good chance that they may be overbuilt for our cars. I will post the weight of those rotors once I buy it or learn it for sure. My apologies btw, I forgot to include the link where I got the idea from. Unlike the previous gen, no need to grind the knuckles which is a plus http://www.camaro5.com/forums/showthread.php?t=130651 Quote:
My mechnanic (also race car builder) told me that I can get away with 7mm spacer if I want to but for track use I want to make sure that I am a notch above the safety zone. If I ever want to give more camber I might try 7mm spacers though
