Old 05-02-2024, 02:49 PM   #71
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
Originally Posted by keep_hope_alive View Post
I'm treating it like it needs the same procedure.
Good luck, Sir! Any updates on your engine break-in or any anomalies?
Tara
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 05-03-2024, 02:33 PM   #72
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Tara
So it's been about 1,800 miles so far. I did an oil change at 1,500 and am sending it to BlackStone Labs for analysis.
I still haven't gotten above 5k rpm. Car feels like it has more power than before, but it could be the 2 months I went without also. Hard to say. It's fast regardless.
Car is ok. I feel like the transmission behaves a bit rougher at times than before. I had to fix a window seal issue. And I've lost communication with the Telematics unit (OnStar, Internet). Dealer won't touch the Telematics issue since I used a PAC-Audio breakout harness, they are saying that somehow, 7 months after I installed it, and after being with them for 2 months, that it's because that harness compromised the pins in the radio harness.
I think it's an antenna communication issue, but the only way to confirm is to remove the shark fin and test it. I measured resistance of the coax cable/antenna combo from the Telematics unit and one had 10k ohms (expected) and one had 500k ohms (likely an open circuit). So, it's either a failed antenna or the coax cable has a broken internal wire. Regardless, my acoustical treatment and audio efforts place this issue in m lap, not theirs.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
