07-04-2021, 08:17 PM | #71 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
07-04-2021, 09:27 PM | #72 |
Drives: 2017 ZL1 Join Date: Aug 2020
That's it. I'm building a 632 ci twin turbo monster with 15" wide slicks to put down that 2500 rwhp...and I've got the $100k to do it too!!!
NOT! |
07-04-2021, 09:46 PM | #73 |
Go for it dbs! Lol....
07-04-2021, 10:01 PM | #74 |
You do what’s best for you dbs and enjoy that ZL1. That’s my advice to you and anyone else.
07-04-2021, 10:08 PM | #75 |
Greg, can I count on you for the first $99k? I'll cover the rest! Hahaha.
07-05-2021, 07:16 AM | #76 | |
Dyno Show Queen LOL
There no reason you can't add Toohighpsi's fuel spacers, injectors, and swap out the DSX pump for a AEM 400lp or larger aux pump to add port injection. even introduce full E if you wanted. or just port the Blower add the TB I don't think your at the power lever to need a big gulp. you can always make the same power more efficiently with the porting!
07-05-2021, 04:17 PM | #77 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I like how whenever someone asks about porting the stock S/C, it starts off with great info and others who have done it chime in.... but in the end turns always turns into a pissing match of going to a 2650 or not.
For me, even though I haven't done it, yet, ill be porting my stock s/c. I dont have any desire to go past the 700whp mark as im just wanting to pretty much do full exhaust/pulley/103/tune. I may or may not go E but again, im not looking to go "all out". I have a 86 iroc with a 406 w/ nitrous also in the garage. While it's a fun car, its also the poster child for unreliable. Im not trying to turn my zl1 into that. so, again, for me, just porting the stocker is plenty. I won't be going "stage x" or whatever it is, mostly because I FEEL the possible little I gain doing that vs a reg port,wouldn't benefit since I'm not going "all out" with this car. That all being said, if my goal is over 700whp (more like over 800whp) then I'd suggest going 2650. |
07-05-2021, 04:58 PM | #78 | |
However, IF there is even the slightest thought that 700-ish to the wheels won't be enough or that the stock blower might have cooling issues and/or you might want more or the potential for more in the future or you want a setup that will be much more efficient, then you should go with a bigger blower from the start. Even tho it will cost more money than a ported setup initially, you'll save money and downtime in the long run. That has been my only point this entire time. Well, that and the possibility that the ported blower will have cooling issues. Unfortunately people these days lack comprehension so it turned into some kind of 1.7 vs 2650 thing or whatever. |
07-05-2021, 07:15 PM | #79 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
You are exactly right. It ends up that way every damn time because there’s always a 2650 owner or 2 who pops in to tell everyone that porting the OEM blower is wrong and is a waste of money and that their way is the only way that’s right. I guess that’s why Kong and Jokerz went broke from a lack of business. Oh wait…..
07-06-2021, 12:31 AM | #80 |
Hahaha. Well that's a bummer. Now who am I gonna have port the lowly 1.7?
Ha! |
07-06-2021, 06:12 AM | #81 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
If you ask all these guys here if they did their own work in modding, you might be surprised. Most work is done by shops that give advice on what they should install to meet their goals. Of course they are going to parrot what they have been told by their tuner and of course it's also the best, right way. I myself have had work done by others and relied on their opinion. But, I have also done my own building of engines over the years. I have not done any LS or LT engines and would take advice on those. Keep this in mind when posters give advice.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
07-06-2021, 06:49 AM | #82 | |
07-06-2021, 08:27 AM | #83 |
Not anymore. I could do Kong's Stage X and surpass 800 wheel, but I'm not sure I want it at this point. My car's a lot of fun.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
07-06-2021, 09:39 AM | #84 |
Drives: 2019 ZL1 Join Date: Mar 2019
It still doesn’t change the fact that the 1.7 stock blower is a heat pump and heat soaks like crazy. That’s the main problem with the stock blower is the tiny bricks.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
