03-28-2019, 09:58 PM | #71 | |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
03-29-2019, 05:24 AM | #72 | |
Did you zero out the shocks with the DSC controller prior to this test? (just to verify)
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
03-29-2019, 05:36 AM | #73 | |
I think what this just means is that we need a community like the 997 group to tweak the settings for our cars to take the 90% base map and make it better for individual use/individual tracks. If it were a hardware limitation (it shouldn't be), i'd be more inclined to agree but this seems like software that needs some user changes much like if you were to take some 4 ways out of the box.
03-29-2019, 08:43 AM | #74 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
03-29-2019, 07:35 PM | #75 |
The unit needs some tweaking to make it better. This unit wasn't zeroed out either. Not sure about the interface to do that procedure. I believe out of the box it would benefit an autocross scenario.
03-29-2019, 07:43 PM | #76 | ||
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
03-29-2019, 09:06 PM | #77 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
Zeroing ride heights is absolutely critical and would explain the pogo effect.
I’m moving on from mine, as I want to run a lot more rate than I can on the MRC, so I’ve ordered some MCS 2WNR. My controller, 300lb front springs, and Moreno camber plates will be for sale when the MCS stuff goes on. It all worked great, but my car basically only gets driven on One Lap and to and from motorsports events. Big power and big aero, time to run a real motorsports suspension.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
03-30-2019, 04:15 PM | #78 |
Quick update on mine:
DSC Sport Loader can find my device on COM1, but the DSC Tuner software cannot. The WiFi on the DSC device shows as available too. Ive tried rebooting, disconnecting the device, trying different ports, checking driver settings, and reloading the software repeatedly. All software is set to COM1. I’m running out of patience. Why can’t DSC write better software? I need to zero this thing out but won’t put it in my car until I know it’ll work with my laptop.
03-30-2019, 08:42 PM | #79 |
I will see Mr. Veritas at VIR next week and ask him about the Camaro platform. Hopefully, he can guide us to a solution or direction.
03-31-2019, 10:32 AM | #80 | |
Drives: gas powered Join Date: Jan 2019
I know your frustrated but thats how computers work sometime. I have certain laptops that I only use on certain machines. Same thing port compatibility etc Alan Bradley is the worst for this. If you had something else to try it on it might work out. Its really why I don't have tuners on any of my modern cars. After doing it at work last thing I want to do is get in my car flip up a lap top and start checking cold idle loops because its a wierd temperature day or what ever. I just want to get in it and drive. And as stated Canbus is the worst thing to come into the automotive world in a while...... |
03-31-2019, 03:07 PM | #81 | |
Drives: 2018 Chevy Camaro ZL1 M6 Join Date: Oct 2018
connect wifi to dsc open browser, go to 10.10.10.1 ip adress go to record, start recording, check your ride heights... they should be way off!!! go to settings, hit the zero travel box (you may have to do it a couple times) go back to record, check your ride heights note, I do not know if the "Reset Board" is required for this procedure... I did not do it and it seemed to work fine! |
04-01-2019, 02:01 PM | #82 |
MCFLY
Out-of-box calibration you're using is for SS 1LE, not the heavier, more powerful ZL1. You only need to make some calibration adjustments to your compression and rebound. You can datalog your run to determine if you need to adjust velocity with compression and/or rebound. I wish there was a "One Size Fits All" calibration, but it doesn't exist. DSC provides calibrations as a place to start, so only minor tuning may be necessary for what type of driving you do. DSC Sport gives you the tools to adjust your own shocks. I've tested the SS 1LE, with accomplished drivers behind the wheel, and it was quicker on all accounts, road course and autocross. It can do the same for ZL1, but additional weight over nose and power, have to be taken into account. Happy to help with adjustments if you need, plug in, read all, look at calibration, and increase your compression and rebound in the needed ranges.
04-01-2019, 02:11 PM | #83 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
DSC should provide a recommended initial setting for both platforms with clear instructions of how to do so, so the results are not worse than the stock settings, if there is indeed improvements all around. It all feels and seems like a half-assed release to me.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
04-01-2019, 02:16 PM | #84 | |
MCFLY
Tags |
dsc controller, dsc sport, mag ride, zl1 |
