Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 01-05-2011, 09:20 PM   #71
MClarenF1
Drives: 2011 CGM 2SS/RS A6
Originally Posted by Rcfiddy1 View Post
Any date yet on release?
i wanna know that soooo badly!!
but i'd first like to see the feel of the shifters
MClarenF1 is offline   Reply With Quote
Old 01-05-2011, 09:35 PM   #72
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Originally Posted by 1BADLS3 View Post
Do the paddle shifters in true paddle-shift cars even move with the steering wheel?
C'mon, of course they do or they could never shift when turning! Ever watch F1? Ever since the intro of paddle shift they have always been on the wheel and move with it...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-05-2011, 09:41 PM   #73
CFD
Drives: 2SS/RS L99 BLACK
Damn right. Shuffle steer and use the console mounted shifter.
Does the auto not have a gate where the car can be manually shifted, i.e. (+/-) ? If not so, bad on GM...
The one pictured above looks like wings for your steering wheel. They will inadvertently get bumped.
Gm doesn't make one for the Camaro but I do.
http://www.camaro5.com/forums/showthread.php?t=116908.
The tap shift buttons that GM uses can come apart fairly easy, with extended levers attached to them I can see where if bumbed with some force they could pop off.
CFD is offline   Reply With Quote
Old 01-05-2011, 09:43 PM   #74
CFD
F1 cars as do most race cars have much different steering than do our Camaros, they require minumal turning of the steering wheel to make full turns.
Old 01-05-2011, 10:17 PM   #75
MClarenF1
my cousin's gtr doesnt hav steering mounted paddleshifters
Old 01-05-2011, 10:19 PM   #76
Entaille
Drives: 2018 Camaro 2SS
I bought CFD's revised pistrol grip shifter with tap shift buttons. Hopefully installing this weekend. I don't think anyone's going to make a steering column mounted paddle set up.
Excited, this is a quality piece..
Entaille is offline   Reply With Quote
Old 01-05-2011, 10:27 PM   #77
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
cant you invent a module for shifting that picks up your brainwaves like the movie "Firefox"?
cmon, you know you wanna.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 01-06-2011, 09:23 PM   #78
MClarenF1
bump!
when are these coming out??
Old 01-07-2011, 06:55 AM   #79
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
just don't do it in russian.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 02-01-2011, 05:01 PM   #80
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
Dude! I do it no problem. Don't know what your problem is. I never bad mouthed your product or even this one, so chill out. I only pointed out that I have no problems using the buttons in any steering wheel position up to 180 off center... Don't hate cuz you can't do it or wrap your mind around doing it safely....
PS And I forgot to ask since you pissed me off about this. Why do you think it is safer to drive with one hand on the wheel while reaching for your shifter?
THANK YOUUUUU for someone finally asking that. Yes, they move with the wheel and you don't need to keep your hands at 9 and 3. Here's a simple trick, when turning everything is on the opposite side. BAM.
StlRomAniaN is offline   Reply With Quote
Old 02-15-2011, 05:45 PM   #81
MyIBMssRS
Drives: 10 IBM SS RS/14 1500 Z71
Are these ever coming out or did it fall through????
MyIBMssRS is offline   Reply With Quote
Old 02-15-2011, 05:52 PM   #82
hypurone
hypurone's Avatar
Drives: ...
I called B&M the other day for shits and giggles and they said, "still in R&D"... Seems pretty simple to me. Can't see much R&D needed really, after you have a prototype....
Old 02-15-2011, 06:11 PM   #83
CFD
Not trying to promote my products here but a few things I noticed with the prototype. First if you look at the size of the levers and how they are mounted and then look at how they would fit with the steering wheel mounted on the car there is not enough clearence between the levers and other controls (directionals, wipers, etc) Second I am very familiar with the switches and the way they are designed with large levers mounted on them it seems that if they were tapped or bumped haphazardly the outer portion of the switch could easily pop off or after continuous useage break. The switches are activated with a rocking motion by pushing on the outer edge, with the levers attached the motion would be more top to bottom possibly causing the switch not to activate and the last thing internally there is not a lot of room for fasteners so it may be possible that they are relying on adhesives or at least on the prototypes. Again I'm not sure but these are the things that caught my attention, they are all things that could probably be overcome but to take it from prototype to a working unit would probably need these issues addressed and that takes time, if it was that easy someone would have done it already I would think.
Old 02-15-2011, 06:18 PM   #84
MontanaKnight
MontanaKnight's Avatar
Drives: Dreaming Of the 2011 SS2 A6 - Soon
Count me in.
MontanaKnight is offline   Reply With Quote
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
Raptor Peformance Dual / Single Mode Shift Lights Now Available At APEX Motorsports!! Apex Motorsports Interior Parts & Accessories 144 07-03-2011 09:14 PM
Pic's of Aftermarket Shift Knob on Stock shifter stalk jammer174 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 12-04-2010 08:49 PM
Tap Shift When to Use NoFatChx V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 03-24-2010 09:18 AM
