03-02-2024, 02:16 PM | #71 |
@ max.i.s.cool
Drives: 2015 1/LE Join Date: Dec 2016
I have a bunch of pictures on my Instagram @Max.i.s.cool of the process, but here's a few, hopefully they will upload.
03-02-2024, 06:20 PM | #72 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
That looks awesome sir. Nice job!
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-02-2024, 08:11 PM | #73 | |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Beautiful car!
03-02-2024, 08:23 PM | #74 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
There is your inspiration Brian!
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
03-03-2024, 07:29 AM | #75 |
Finally taking time to reading some build threads - your car and build is awesome and totally bad ass. I can appreciate a fellow wrench who knows how to push through frustration in a extensive and involved build and get the end result right, even though there are F-Ups and re-do's in the process. It's part of the Mod game. You may not be a "body man" but count your blessings - body work is maddening. I wish I could find a GFX set of Rockers like you did.
Keep the goods coming!!! Last edited by hesster; 03-03-2024 at 09:01 AM. |
03-03-2024, 08:36 AM | #76 | |
@ max.i.s.cool
Appreciate that! I'm excited to see yours with some fresh paint! And I found a guy on eBay that sells hood struts at different lengths and pressures. Grabbed a couple ball studs from my local AutoZone. I had some left over steel strips and welded an L shape. I did have to cut a little of the hook that's near the windshield, I'll try to find some decent pictures. The green area I circled is a hook piece that I did have to cut a bit so the ball stud wouldn't hit it when I shut the hood. |
03-03-2024, 08:38 AM | #77 |
@ max.i.s.cool
I'd like to redo them, to make them more aestheticly pleasing to me, but they're functional and soothe my OCD being two struts instead of just one on the strut tower
03-03-2024, 06:08 PM | #78 |
03-03-2024, 06:14 PM | #79 | |
It is a process, suffer through it to reach the reward! And yes, body work is maddening. I can do a lot of things, but body work is one of those things that I just don't like. And I don't want to do enough to be good at it! LOL.
03-03-2024, 06:23 PM | #80 |
I get the OCD thing. The single strut has always bothered me too! Still trying to decide if I want to ditch it and do something like you did.
03-03-2024, 08:14 PM | #81 |
@ max.i.s.cool
03-03-2024, 11:31 PM | #82 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I love seeing other cars with Torqstorm superchargers. I love mine, and your setup is legit. Sorry to thread jack SlowLs1.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
03-04-2024, 06:46 AM | #83 |
I'm leaning towards doing this. I'm still in the filling/sanding stage and would be easy enough to prepare for this. Just have to come up with a nice looking shock mount solution.
03-04-2024, 06:47 AM | #84 |
It's all good brother.
