Old 05-09-2020, 10:25 PM   #8359
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Originally Posted by CHV2SS View Post
Ok but to get it installe? I live kern california and dont really know any shop to do mods etc..
That I'd guess you'd have to find a car accessory/stereo/service shop of some kind, if you cant do it. The Camera mounts out front, anywhere you can fit it. The video switch plugs inline with the stereo harness. I don't think its terribly difficult.
Zaqwert6 is offline   Reply With Quote
Old 05-10-2020, 02:19 AM   #8360
CHV2SS
Drives: '19 camaro 2ss
Aight thanks
CHV2SS is offline   Reply With Quote
Old 05-10-2020, 02:38 PM   #8361
Aboynamedsue
Aboynamedsue's Avatar
Drives: 2017 Camaro SS
Originally Posted by cdrptrks View Post
Nice! If you have the same gray plug underneath each seat as the cars that come with Recaros, definitely consider this kit to enable the seat cooling fans if you have a 1SS!
https://www.gen5diy.com/collections/...23134969135162
Thanks, but there is no way I’m putting more work into this seat project.
2017 SS manual ordered through the one and only Becky!
For sale: https://www.camaro6.com/forums/showthread.php?t=612154
Aboynamedsue is offline   Reply With Quote
Old 05-10-2020, 03:13 PM   #8362
FarmerFran
FarmerFran's Avatar
Today, the wife and I drove to the next town over and grabbed some Indian food. ~65°F out with the top down.
Old 05-10-2020, 05:40 PM   #8363
caSStro18
Drives: 2018 Camaro SS
Painted and installed my inexpensive strut tower brace from eBay. Since it’s not really functional, I just bought a cheap one off eBay and painted it to give the engine compartment a little more visual appeal.
caSStro18 is offline   Reply With Quote
Old 05-10-2020, 06:46 PM   #8364
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
Installed a killer chiller,with an electronic HE bypass valve and an electronic cabin ac bypass valve.
Dan82679 is offline   Reply With Quote
Old 05-10-2020, 07:46 PM   #8365
GroundhogSS
GroundhogSS's Avatar
We went out to Circuit of the Americas today to do a lap with the top down. They were collecting donations for the local food bank and letting everyone on the track. They had a 20mph speed limit so no quick laps. I think I hit 38 one time. Nice day, temp around 80.
Out of the pit lane and up to turn 1.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 05-10-2020, 08:25 PM   #8366
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
We went out to Circuit of the Americas today ... They had a 20mph speed limit so no quick laps. I think I hit 38 one time.
Scofflaw
17rsvert is offline   Reply With Quote
Old 05-10-2020, 09:14 PM   #8367
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
I ceramic coated the wheels. In about two weeks I'll be painting the calipers.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 05-11-2020, 12:29 AM   #8368
CHV2SS
Took her out today went to target 👌
Old 05-11-2020, 07:03 AM   #8369
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
<sigh> You guys are making me really miss mine. Cannot wait to get her back...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 05-11-2020, 11:20 AM   #8370
Redlinez
Shifts under load
Redlinez's Avatar
Installed SMG Speed bumper marker smoked lights (cheapies) and McGard black lug nuts. I should have swapped them off my 2017 that I traded. Totally forgot about them.
22 Suzuki GSX-S 1000GT blue
Old 05-11-2020, 11:46 AM   #8371
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Ordered the LED backup lights and harness from Wildhammer Motorsports. Will install tomorrow when it comes in.
dmcmahan60 is offline   Reply With Quote
Old 05-11-2020, 12:19 PM   #8372
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Originally Posted by 17rsvert View Post
I installed reverse LEDs on my 17 using 1.4k ohm resistors in parallel. I found that my battery was being drained to the point of reading 4 volts after sitting a few weeks. I had it at the dealer for the free oil change and asked them to check it and they couldn't find any drain, but said they would need to put it in a recording meter for a day to see what was waking the BCM. I took it home, put the OEM bulbs back, and have not had an issue since. Coincidence?
incandescent bulbs are basically short circuits. The current leaked from the reverse switch that turns the reverse bulbs on is just not high enough to heat the metal so it glows.
Adding a parallel resistor to the bulb will not result in any additional battery drain than the incandescent bulb would cause. So either it wasn't wired in parallel or something else was an issue. The circuit only has what the switch is giving it in terms of power to waste unless you've changed the circuit.
The reverse circuit is quite different from the issues experienced in turn signal led conversions (pre 2019).
1.The reverse circuit doesn't have a bcm monitoring load and doing something about it.
2. The reverse circuit does leak power when off, all the time.
3. Led lights require so little current to light up, that many led bulbs will glow or flicker from this current leakage.
4. All that's required to eliminate that is a shunt that can drop what's available to the led bulbs down enough so that they dont glow/flicker. The range that can be done in goes from load resistor levels up to plain old quarter watt kOhm resistors.
5. You only need one resistor as the reverse lights are wired in parallel. However, if using a load resistor, some people may notice one bulb being slightly brighter than the other since whichever bulb is further away from the load resistor will be getting slightly less power than the one closer.
As for you wanting to test if a battery drain was caused by your reverse light swap.. You could test the battery draw while sitting with the oem bulbs. then take the oem bulbs out and test the draw again (open circuit). If you see less draw or no change, then your problem was either in the installation or coincidental. If a bcm was being kept awake due to low draw on the reverse circuit you'd see it there. But I'm nearly 100% sure that if the draw was due to an active bcm, it was coincidental or due to an installation mistake that led to a circuit that was supposed to be off to remain on (you were powering it via the shunted positive reverse line)
