05-05-2021, 09:15 AM | #8261 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I don't really think that is slow for a bone stock GT500 under normal/average conditions. Magazine best times for a ZL1 are 11.4 while I would say the average for most users is about mid to high 11s. So if a regular driver can get am 11.25 out of a stock GT500 then that is pretty good. I would expect to see them running low to mid 11s bone stock which would put them just slower than a Hellcat on a tire.
05-05-2021, 12:23 PM | #8262 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
I am very impressed you can get a 1.8 60 foot on runflats though
Old Ride: 2016 Callaway SC630 Camaro SS
05-05-2021, 03:24 PM | #8263 |
Well, ZL1 has 305 street tires and 650 hp, and guys are reporting 1.7 short times for them. So the GT500 with 315 street tires and 760 hp should be able to run better than 2 second short times.
05-05-2021, 03:36 PM | #8264 |
Drives: like an old lady Join Date: Jun 2012
corrected for accuracy.
05-05-2021, 04:00 PM | #8265 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
112 on a bolt on car is a little suspect imo. Having said that I did have an arbitrary 110 trap speed on one of the 12.6 runs, so sometimes shit happens lol. You also see a ton of our muscle cars that should be low to mid 12 second cars not get out of the 13s, especially stick cars.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
05-05-2021, 04:08 PM | #8266 |
13s is slow for an auto Scat.. I wouldn't say 11.25 is slow for a 500, just not the fastest or a sketchy hero time. Seems par with mag times if we use those as references.
05-06-2021, 06:24 AM | #8267 | |
Go find the GT500 hero times Plus the Camaro is a better car so it hooks up better and a 650hp car is easier to get traction than a 760hp car. See how that works HUH? if you were trying to change my crank numbers to wheel numbers you kinda forgot about the Mustang
05-06-2021, 07:25 AM | #8268 |
i was being sarcastic. although i think even 480 crank is generous for the camaro at this point.
05-06-2021, 10:59 AM | #8269 | |
Agree with the Camaro being a better car. However I don't think that the 650hp vs 760hp means as much with these 2 cars when launching as you are implying. I think if we examined how much torque each car is making at the launch rpm, we'd find the GT500 is not making more torque than the ZL1. I checked and in fact, the GT500 is making less torque at 4000rpm than the ZL1 is making at 3000rpm, according to rear wheel dynos that I've seen. Much less torque at 3000rpm for the Ford. Conclusion, the GT500 should probably be able to walk out of the hole (less brutal torque hitting the street tires at a standstill), and then as it really revs up, it should start pulling hard. Opposite situation of what you implied with your get traction with 760 hp comment, since it was specifically the short time that I was talking about with these cars being on street tires. |
05-06-2021, 11:20 AM | #8270 | |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
Anyway, drag racing 400HP+ cars on street tires is silly, at minimum, a second set of rear wheels with proper DRs, or slick is the only way to get a decent launch on cars at these power levels.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
05-06-2021, 12:28 PM | #8271 | |||
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
1st gear peak torque delivered to the rear wheels (not taking into account drivetrain losses) for the ZL1 and GT500: ZL1: 4.7 (1st gear ratio) x 2.85 x 650 ft-lbs = 8,707 ft-lbs GT500: 3.14 (1st gear) x 3.73 x 625 ft-lbs = 7,320 ft-lbs So, technically, the ZL1 is putting more torque to the rear wheels at peak torque ratings for both cars in 1st gear than the GT500, which could be argued that it makes it harder to get traction. That said, the ZL1 has a better front/rear weight distribution (54/46, rounded), compared to the GT500 (56/44, rounded), and is lighter, thus, tilting the traction advantage to the ZL1 from a chassis standpoint. This is one reason why the Hellcats are so hard to get traction, since they have skinnier tires, much heavier, AND an even worse 57/43 weight distribution. Quote:
Torque to rear tires at peak power in 1st gear: ZL1: 4.7 (1st gear) x 2.85 x 533 ft-lbs (650 hp at 6,400 rpm) = 7,139 ft-lbs GT500: 3.14 (1st gear) x 3.73 x 547 (760 hp at 7,300 rpm) = 6,406 ft-lbs So the answer is...No, the GT500 never sends as much torque in 1st gear to the rear tires as the ZL1 (assuming similar drivetrain efficiency). Do the ZL1's chassis and weight distribution advantages offset the extra torque and make hooking up easier in the ZL1? I'm not sure. Interesting thing to note is from peak torque to peak hp, the ZL1 drops by 18%, while the GT500 drops by only 12.5% - meaning a flatter high rpm torque curve with the Predator vs the LT4. Anyway, that's some torque analysis for y'all.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
05-06-2021, 12:40 PM | #8272 |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
Forum needs a “like” button.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
05-06-2021, 02:56 PM | #8273 | |
Looking at numbers alone (like he tried to do) is silly at best. It is an entire car with different engine styles that apply power in much different ways, different programming, trans and rear ratios, etc. |
05-06-2021, 06:35 PM | #8274 | |
and as much as i like the ZL1, i dont think there is much in comparison with a gt500. if i recall correctly, you were also the one comparing your bolt on gt mustang to ZL1s from 40-70 or whatever. my car ran 40-70 in <3 seconds and that included a shift (m6)
